My mic stopped working after the last stable update.
It is being displayed in the PulseAudio Plugin:
but not working in Chrome, Firefox or zoom:
$ inxi -Fazy
Kernel: 5.17.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=38422d63-8f74-4526-8fc7-5323de68cca6 rw apparmor=1
security=apparmor resume=UUID=9ce2076f-8ca5-4041-85e1-bfef8888b750
udev.log_priority=3
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Inspiron 15 3511 v: N/A
Mobo: Dell model: 0042CN v: A00 serial: <superuser required> UEFI: Dell
v: 1.9.0 date: 01/17/2022
ID-1: BAT0 charge: 41.4 Wh (100.0%) condition: 41.4/40.4 Wh (102.4%)
volts: 12.8 min: 11.2 model: SMP DELL MGCM51A type: Li-poly serial: <filter>
status: full
Info: model: 11th Gen Intel Core i5-1135G7 bits: 64 type: MT MCP
arch: Tiger Lake family: 6 model-id: 0x8C (140) stepping: 1 microcode: 0x9A
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 714 high: 1149 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1031 2: 636 3: 488 4: 590
5: 1149 6: 659 7: 599 8: 565 bogomips: 38720
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Dell
driver: i915 v: kernel ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 0000:00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 0c45:6d1a class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: LG Display 0x06ff built: 2021 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Dell
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
Sound Server-1: ALSA v: k5.17.6-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: 3000
bus-ID: 0000:01:00.0 chip-ID: 10ec:c821 class-ID: 0280
Device-1: Realtek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-10:4 chip-ID: 0bda:c829 class-ID: e001 serial: <filter>
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 48.27 GiB (10.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel
model: 670p SSDPEKNU512GZ NVMe 512GB size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 7002 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 331.35 GiB size: 325.08 GiB (98.11%)
used: 48.27 GiB (14.8%) fs: ext4 dev: /dev/nvme0n1p9 maj-min: 259:9
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p4 maj-min: 259:4
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p8 maj-min: 259:8
System Temperatures: cpu: 61.0 C mobo: N/A
Processes: 251 Uptime: 52m wakeups: 22 Memory: 15.37 GiB
used: 2.39 GiB (15.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1179 lib: 322 flatpak: 0
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.15
$ pacmd list-cards
1 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0x6003238000 irq 157"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "a0c8"
device.product.name = "Tiger Lake-LP Smart Sound Technology Audio Controller"
device.string = "0"
device.description = "Built-in Audio"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
input:analog-stereo: Analog Stereo Input (priority 32833, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 39268, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 39333, available: unknown)
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (priority 5965, available: unknown)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (priority 865, available: unknown)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI) Output + Analog Stereo Input (priority 865, available: unknown)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
output:hdmi-stereo-extra1+input:analog-stereo: Digital Stereo (HDMI 2) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround-extra1+input:analog-stereo: Digital Surround 5.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround71-extra1+input:analog-stereo: Digital Surround 7.1 (HDMI 2) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-stereo-extra2+input:analog-stereo: Digital Stereo (HDMI 3) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround-extra2+input:analog-stereo: Digital Surround 5.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2+input:analog-stereo: Digital Surround 7.1 (HDMI 3) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
output:hdmi-stereo-extra3+input:analog-stereo: Digital Stereo (HDMI 4) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround-extra3+input:analog-stereo: Digital Surround 5.1 (HDMI 4) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround71-extra3+input:analog-stereo: Digital Surround 7.1 (HDMI 4) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (priority 5700, available: no)
output:hdmi-stereo-extra4+input:analog-stereo: Digital Stereo (HDMI 5) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround-extra4+input:analog-stereo: Digital Surround 5.1 (HDMI 5) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround71-extra4+input:analog-stereo: Digital Surround 7.1 (HDMI 5) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-stereo-extra5: Digital Stereo (HDMI 6) Output (priority 5700, available: no)
output:hdmi-stereo-extra5+input:analog-stereo: Digital Stereo (HDMI 6) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra5: Digital Surround 5.1 (HDMI 6) Output (priority 600, available: no)
output:hdmi-surround-extra5+input:analog-stereo: Digital Surround 5.1 (HDMI 6) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra5: Digital Surround 7.1 (HDMI 6) Output (priority 600, available: no)
output:hdmi-surround71-extra5+input:analog-stereo: Digital Surround 7.1 (HDMI 6) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-stereo-extra6: Digital Stereo (HDMI 7) Output (priority 5700, available: no)
output:hdmi-stereo-extra6+input:analog-stereo: Digital Stereo (HDMI 7) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra6: Digital Surround 5.1 (HDMI 7) Output (priority 600, available: no)
output:hdmi-surround-extra6+input:analog-stereo: Digital Surround 5.1 (HDMI 7) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra6: Digital Surround 7.1 (HDMI 7) Output (priority 600, available: no)
output:hdmi-surround71-extra6+input:analog-stereo: Digital Surround 7.1 (HDMI 7) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-stereo-extra7: Digital Stereo (HDMI 8) Output (priority 5700, available: no)
output:hdmi-stereo-extra7+input:analog-stereo: Digital Stereo (HDMI 8) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra7: Digital Surround 5.1 (HDMI 8) Output (priority 600, available: no)
output:hdmi-surround-extra7+input:analog-stereo: Digital Surround 5.1 (HDMI 8) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra7: Digital Surround 7.1 (HDMI 8) Output (priority 600, available: no)
output:hdmi-surround71-extra7+input:analog-stereo: Digital Surround 7.1 (HDMI 8) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-stereo-extra8: Digital Stereo (HDMI 9) Output (priority 5700, available: no)
output:hdmi-stereo-extra8+input:analog-stereo: Digital Stereo (HDMI 9) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra8: Digital Surround 5.1 (HDMI 9) Output (priority 600, available: no)
output:hdmi-surround-extra8+input:analog-stereo: Digital Surround 5.1 (HDMI 9) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra8: Digital Surround 7.1 (HDMI 9) Output (priority 600, available: no)
output:hdmi-surround71-extra8+input:analog-stereo: Digital Surround 7.1 (HDMI 9) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-stereo-extra9: Digital Stereo (HDMI 10) Output (priority 5700, available: no)
output:hdmi-stereo-extra9+input:analog-stereo: Digital Stereo (HDMI 10) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra9: Digital Surround 5.1 (HDMI 10) Output (priority 600, available: no)
output:hdmi-surround-extra9+input:analog-stereo: Digital Surround 5.1 (HDMI 10) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra9: Digital Surround 7.1 (HDMI 10) Output (priority 600, available: no)
output:hdmi-surround71-extra9+input:analog-stereo: Digital Surround 7.1 (HDMI 10) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-stereo-extra10: Digital Stereo (HDMI 11) Output (priority 5700, available: no)
output:hdmi-stereo-extra10+input:analog-stereo: Digital Stereo (HDMI 11) Output + Analog Stereo Input (priority 5765, available: unknown)
output:hdmi-surround-extra10: Digital Surround 5.1 (HDMI 11) Output (priority 600, available: no)
output:hdmi-surround-extra10+input:analog-stereo: Digital Surround 5.1 (HDMI 11) Output + Analog Stereo Input (priority 665, available: unknown)
output:hdmi-surround71-extra10: Digital Surround 7.1 (HDMI 11) Output (priority 600, available: no)
output:hdmi-surround71-extra10+input:analog-stereo: Digital Surround 7.1 (HDMI 11) Output + Analog Stereo Input (priority 665, available: unknown)
off: Off (priority 0, available: unknown)
active profile: <output:analog-stereo+input:analog-stereo>
sinks:
alsa_output.pci-0000_00_1f.3.analog-stereo/#0: Built-in Audio Analog Stereo
sources:
alsa_output.pci-0000_00_1f.3.analog-stereo.monitor/#0: Monitor of Built-in Audio Analog Stereo
alsa_input.pci-0000_00_1f.3.analog-stereo/#2: Built-in Audio Analog Stereo
ports:
analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
properties:
analog-input-headphone-mic: Microphone (priority 8700, latency offset 0 usec, available: unknown)
properties:
analog-input-headset-mic: Headset Microphone (priority 8800, latency offset 0 usec, available: unknown)
properties:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: unknown)
properties:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
properties:
hdmi-output-5: HDMI / DisplayPort 6 (priority 5400, latency offset 0 usec, available: no)
properties:
hdmi-output-6: HDMI / DisplayPort 7 (priority 5300, latency offset 0 usec, available: no)
properties:
hdmi-output-7: HDMI / DisplayPort 8 (priority 5200, latency offset 0 usec, available: no)
properties:
hdmi-output-8: HDMI / DisplayPort 9 (priority 5100, latency offset 0 usec, available: no)
properties:
hdmi-output-9: HDMI / DisplayPort 10 (priority 5000, latency offset 0 usec, available: no)
properties:
hdmi-output-10: HDMI / DisplayPort 11 (priority 4900, latency offset 0 usec, available: no)
properties:
