Is this a strange new bug? Or nvidia drivers are required for AMD GPU’s today for Linux?
Is it fine to install it?
inxi --admin --verbosity=7 --filter --no-host --width:
Kernel: 5.15.72-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/vmlinuz-5.15-x86_64
root=UUID=117a5f35-5599-4992-850a-7d04cb4bca27 rw quiet apparmor=1
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: TUXEDO product: TUXEDO Pulse 15 Gen1 v: Standard
serial: <superuser required>
Mobo: NB02 model: PULSE1501 v: Standard serial: <superuser required>
BIOS: American Megatrends v: N.1.07.A03 date: 05/11/2021
ID-1: BAT0 charge: 91.6 Wh (100.0%) condition: 91.6/91.6 Wh (100.0%)
volts: 12.7 min: 11.6 model: standard type: Li-ion serial: <filter>
status: full
RAM: total: 15.05 GiB used: 2.32 GiB (15.4%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7
(7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600103
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1397 high: 1403 min/max: 1400/2900 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1398
3: 1397 4: 1397 5: 1397 6: 1400 7: 1397 8: 1397 9: 1392 10: 1398 11: 1397
12: 1397 13: 1403 14: 1397 15: 1392 16: 1397 bogomips: 92664
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Renoir vendor: Tongfang Hongkong driver: amdgpu v: kernel
arch: GCN-5.1 code: Vega-2 process: TSMC n7 (7nm) built: 2018-21 pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 03:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 29.0 C
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: BOE Display 0x0900 built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.42 5.15.72-1-MANJARO) v: 4.6
Mesa 22.1.7 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Tongfang Hongkong
bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Tongfang Hongkong
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Tongfang Hongkong
bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k5.15.72-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: yes
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp1s0 state: down mac: <filter>
vendor: Tongfang Hongkong driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-4.4:4 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 465.76 GiB used: 20.71 GiB (4.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO M.2 500GB
type: SSD serial: <filter> rev: 4B6Q scheme: MBR
ID-1: / raw-size: 240.66 GiB size: 235.82 GiB (97.99%) used: 16.09 GiB
(6.8%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 117a5f35-5599-4992-850a-7d04cb4bca27
ID-2: /boot raw-size: 500 MiB size: 458.3 MiB (91.67%) used: 63.2 MiB
(13.8%) fs: ext3 dev: /dev/sda1 maj-min: 8:1 label: Boot
uuid: be5baa10-5f66-4e30-b9c6-a1788e510c69
ID-3: /home raw-size: 175.78 GiB size: 171.96 GiB (97.83%) used: 4.56 GiB
(2.7%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: Home
uuid: 71a27b4e-f3fb-43e1-8e9d-8f5eec561bdd
ID-1: /dev/sda4 maj-min: 8:4 size: 2.93 GiB fs: swap label: N/A
uuid: a5d2ba7c-3b01-46f0-8f71-ebab43cf0582
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-2: 1-4:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 1-4.3:3 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-2: 1-4.4:4 info: Intel AX200 Bluetooth type: Bluetooth
Hub-3: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-5: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 42.4 C mobo: N/A gpu: amdgpu temp: 30.0 C
Processes: 323 Uptime: 1h 33m wakeups: 1 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1358 libs: 349 tools: pamac pm: flatpak pkgs: 0
Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.22
