Short version:
What: mhwd detects and installs old version of nvidia driver(390xx)
Goal: Install the latest(4.6) one as my videocard is still supported, can I do it using mhwd in order to not mess up some configs?
Info: GeForce GTX660, kernel 5.10
A little bit of context:
I discovered this when trying to run a game via PoL and then switching to Lutris, it gave me an alert that my drivers are outdated, so I decided to use mhwd to automatically install them, however the version that it installed is video-nvidia-390xx, however the latest version which is for unix system of the driver listed in the nvidia website is 460.39. I’m using a GeForce GTX660 and it’s being supported by the latest version, however mhwd is automatically installing video-nvidia-390xx.
Note: I kind of understand how to manually install it from reading how-to-install-the-nvidia-drivers-on-manjaro-18-linux on linux config, but I prefer doing it via mhwd, if it is possible
@linux-aarhus , @pobrn
Thank you, guys. the combination of reinstalling mhwd-db and sudo mhwd -i pci video-nvidia solved my problem. Wish I could mark two options as solutions, but I’ll give it to the first one. Again, thanks a lot.
