Hi, I wanted to submit a little fix for mhwd-fb
, even if it has not really the topmost focus…
Since I couldn’t create a merge request in gitlab, I have mirrored the repo in github and created this push request:
Would anyone take care of that?
Apart from that, I also need to report that mhwd-fb
is not working correctly with the standard installation because it needs uvesafb
, but this latter is not available in Manjaro: only v86d
is.
So, in order to work with that, you need to:
pacman -Rdd v86d
- install
uvesafb
from the AUR
