MHWD creates empty xorg configuration files
$inxi -G
Graphics:  Device-1: Intel Haswell-ULT Integrated Graphics driver: i915 v: kernel
           Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] driver: N/A
           Device-3: Realtek USB Camera type: USB driver: uvcvideo
           Display: x11 server: X.Org 1.20.9 driver: modesetting resolution: 1366x768~60Hz
           OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2) v: 4.5 Mesa 20.1.8
I have used the GUI variant of MHWD to install the 450xx drivers for my Nvidia GPU (“Auto Install Proprietary Driver”).
I started my laptop with every installed kernel, one after another (5.8, 5.7, 5.4, 4.19, 4.14), but it doesn’t work.
$nvidia-settings
ERROR: NVIDIA driver is not loaded
In /etc/X11/mhwd.d/nvidia.conf, there is just a comment:
## Generated by mhwd - Manjaro Hardware Detection
The same in /etc/X11/xorg.conf.d/90-mhwd.conf. Could that be the cause of the problem?
can you please return
inxi -Fza
mhwd -li
you are messing up videos drivers if this is a laptop
inxi -Fza
System:    Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64
           Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4 dm: LightDM 1.30.0
           Distro: Manjaro Linux
Machine:   Type: Laptop System: ASUSTeK product: X555LD v: 1.0 serial: <filter>
           Mobo: ASUSTeK model: X555LD v: 1.0 serial: <filter> UEFI: American Megatrends v: X555LD.307
           date: 07/02/2014
Battery:   ID-1: BAT0 charge: 19.2 Wh condition: 19.5/37.3 Wh (52%) volts: 7.5/7.5
           model: ASUSTeK X555-50 type: Li-ion serial: N/A status: Not charging cycles: 621
CPU:       Topology: Dual Core model: Intel Core i5-4210U bits: 64 type: MT MCP arch: Haswell family: 6
           model-id: 45 (69) stepping: 1 microcode: 26 L2 cache: 3072 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19160
           Speed: 798 MHz min/max: 800/2700 MHz Core speeds (MHz): 1: 798 2: 798 3: 798 4: 798
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP:
           conditional, RSB filling
Graphics:  Device-1: Intel Haswell-ULT Integrated Graphics vendor: ASUSTeK driver: i915 v: kernel
           bus ID: 00:02.0 chip ID: 8086:0a16
           vendor: ASUSTeK driver: N/A alternate: nouveau, nvidia_drm, nvidia bus ID: 04:00.0
           chip ID: 10de:1140
           Device-3: Realtek USB Camera type: USB driver: uvcvideo bus ID: 2-5:2 chip ID: 0bda:57b5
           serial: <filter>
           Display: x11 server: X.Org 1.20.9 driver: modesetting alternate: fbdev,intel,vesa
           display ID: :0.0 screens: 1
           Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0") s-diag: 414mm (16.3")
           Monitor-1: eDP-1 res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.5x7.6")
           diag: 394mm (15.5")
           OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2) v: 4.5 Mesa 20.1.8 compat-v: 3.0
           direct render: Yes
Audio:     Device-1: Intel Haswell-ULT HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus ID: 00:03.0 chip ID: 8086:0a0c
           Device-2: Intel 8 Series HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
           bus ID: 00:1b.0 chip ID: 8086:9c20
           Sound Server: ALSA v: k5.8.11-1-MANJARO
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK
           driver: r8168 v: 8.048.03-NAPI modules: r8169 port: e000 bus ID: 02:00.0 chip ID: 10ec:8168
           Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Lite-On driver: ath9k
           v: kernel port: e000 bus ID: 03:00.0 chip ID: 168c:0032
           IF-ID-1: br-95d45472e8b9 state: down mac: <filter>
           IF-ID-2: docker0 state: down mac: <filter>
Drives:    Local Storage: total: 465.76 GiB used: 408.93 GiB (87.8%)
           ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB block size:
           physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter> rev: 3B6Q scheme: GPT
           SMART Message: Unknown smartctl error. Unable to get data.
Partition: ID-1: / raw size: 452.74 GiB size: 444.64 GiB (98.21%) used: 408.93 GiB (92.0%) fs: ext4
           block size: 4096 B dev: /dev/dm-0
Swap:      Kernel: swappiness: 60 (default) cache pressure: 100 (default)
           ID-1: swap-1 type: partition size: 12.72 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1
Sensors:   System Temperatures: cpu: 57.0 C mobo: N/A
           Fan Speeds (RPM): cpu: 4100
Info:      Processes: 243 Uptime: 35m Memory: 11.16 GiB used: 3.83 GiB (34.3%) Init: systemd v: 246
           Compilers: gcc: 10.2.0 clang: 10.0.1 Packages: 2390 pacman: 2345 lib: 457 flatpak: 42 snap: 3
           Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.05
$mhwd -li
> Installed PCI configs:
video-hybrid-intel-nvidia-450xx-prime            2019.10.25               false            PCI
         network-r8168            2016.04.20                true            PCI
video-hybrid-intel-nouveau-prime            2017.05.29                true            PCI
And yes, it is a laptop. And no, I’m not messing up video drivers (intentionally) - I’m just using MHWD tool and would expect it doing it right. But maybe that’s the same :wink: - I don’t know.
manjaro installation in case of hybrid cards choose open-soure intel ( or amd )
if you need to check hybrid nvidia cards, then this is a prime command
prime-run nvidia-settings
prime-run vulkaninfo
prime-run glxinfo ( prime offload)
$prime-run glxinfo
name of display: :0.0
X Error of failed request:  BadValue (integer parameter out of range for operation)
  Major opcode of failed request:  152 (GLX)
  Minor opcode of failed request:  24 (X_GLXCreateNewContext)
  Value in failed request:  0x0
  Serial number of failed request:  39
  Current serial number in output stream:  40
primerun: Command not found.
Why are both installed? If you want the proprietary drivers, uninstall video-hybrid-intel-nouveau-prime and reinstall the other: sudo mhwd -f -i pci video-hybrid-intel-nvidia-450xx-prime
Here we go again…
  1. Purge PRIME. (Will not work!)
  2. Install bumblebee:
sudo  mhwd -r pci video-hybrid-intel-nvidia-450xx-prime
sudo  mhwd -r pci video-hybrid-intel-nouveau-prime
sudo  mhwd -i pci video-hybrid-intel-nvidia-390xx-bumblebee
sudo gpasswd -a $USER bumblebee
sudo systemctl enable bumblebeed
Reboot.
Check if all is fine:
optirun -b none nvidia-settings -c :8
optirun nvidia-smi
optirun glxinfo|grep Open
Indeed, I didn’t even check the gpu model, PRIME won’t work, so you’re left with bumblebee.
MHWD with lastest live isos is stupid and cannot handle older nvidia’s chips. They cannot support PRIME, but when MHWD find INTEL + NVIDIA, then installing in default PRIME based profile, but should install legacy bumblebee instead FOR OLDER devices.
$optirun glxinfo
[  573.914225] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) No devices detected.
[  573.914284] [ERROR]Aborting because fallback start is disabled.
$inxi -G
           Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] driver: nvidia
           v: 390.132
           Display: x11 server: X.Org 1.20.9 driver: nvidia resolution: 1366x768~60Hz
Tried this: https://wiki.archlinux.org/index.php/Bumblebee#[ERROR]Cannot_access_secondary_GPU:_No_devices_detected
I have added
Section "Device"
    Identifier "nvidiagpu1"
    Driver "nvidia"
    BusID "PCI:4:0:0"
EndSection
to the bottom of the /etc/X11/xorg.conf.d/90-mhwd.conf file after checking the bus with
$lspci | grep GeForce
04:00.0 3D controller: NVIDIA Corporation GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] (rev a1)
but after a restart it doesn’t change anything.
Solved the issue by adding
BusID "PCI:4:0:0"
to the
Section "Device"
in
/etc/bumblebee/xorg.conf.nvidia
