Meta+shift draws unremovable red lines on screen
In addition, meta+ctrl+shift draws red arrows. On KDE plasma x11. The lines persist between desktops and activities - the only way I have found to remove them is to reboot the PC.
I would appreciate any help in getting rid of the lines without rebooting or stopping them happening in the first place.
This?
//EDIT: ahaha too slow my dear Aragorn, too slow :stuck_out_tongue:
//EDIT2: you can also change its settings when enabled, to modify the shortcut and other options.
It’s a desktop effect.
System Settings ─ Workspace → Workspace Behavior → Desktop Effects → Appearance
Deselect “Mouse Mark”.
Thank you so much - I had no idea how to search for this.
