Meta key trigger host startmenu in VMWare
Hey !
I’m not running into a real issue, but this problem is quite annoying :
when I press the meta key (Windows key) in a VMWare Window, to open the start menu of the guest, it also opens the start menu of the Manjaro host.
I don’t really know where to put this question, so please tell me if I should ask this on VMWare forums
Thanks !
Use different keys on both? (I use Ctrl+Esc)
:thinking:
You could disable global shortcuts on the VMware window. (At least on KDE).
Hi ! I’m sorry, but I never went deep into KDE configuration. Could you send me a link, or a hint on how to do that ?
You can change shortcut just in VMWare window ? Or are you talking to change it for the window-wide ?
Click on the top left application icon, then More Actions and then Special Application settings
Then click on add properties
And finally ignore global shortcuts:
Change do not affect to force, and thats it. Downside is that you will no longer be able to Alt+Tab, Alt+F4, etc (Only on VMware). Screen edges will still work so you could use the top-left one instead of alttabbing (by default it shows your open windows).
Whatever you want as long as both are different but @adelpozoman 's system is better.
:clap:
Thanks you, it works ! I will check this menu deeper to see if I can specifically disable the meta shortcut
