Messy nautilus shortcuts
Hello,
When I installed Manjaro, I used to have a clean shortcuts panel in nautilus, with home folder, downloads, images, videos, etc on the top, a separating line, and custom shortcuts in the bottom.
After an update, everything have been messed up :
I can said wich update exactly, because it was some months ago, and I didn’t had time search more at this moment.
I use aur’s nautilus-typehead. I already checked the ~/.config/user-dirs.dirs which has nothing special. I found nothing in dconf about this. The menu is ok when another software open a “save file” or “select file” window.
How to get back the normal behaviour ?
Thanks for your help
A custom package build using AUR recipe is unsuppored.
This is most possibly caused by an incompatible extension.
If you already know which extension - then remove it.
So - the way forward is to disable all custom extensions - then enable one by one until you find the cause.
Thanks for you answer.
I just tried :
  1. disable all gnome extensions
  2. uninstall nautilus-typehead and reinstall default nautilus from the repository
  3. uninstall all nautilus extensions
  4. reboot.
The problem persists.
I’m not following. Your screenshot looks “normal” to me. It’s possible you noticed upstream design changes that looked different from previous versions.
Either way, neither using nautilus-typeahead nor extensions will make a difference.
Downloads, Images, Videos, Documents, etc folders used to be in the above part, with Home, Dustbin, and Networks. Which is a more logical place as these are not custom bookmarks.
So we are in an “It’s not a bug. It’s a feature” syndrome ? Is there a way to restore the old behavior ?
@Weg
recently-used.xbel
❱ ls -l $HOME/.local/share/recently-used.xbel
-rw------- 1 687870 2025-04-19 23:29 /home/USERNAME/.local/share/recently-used.xbel
#backp
cp -v  /home/USERNAME/.local/share/recently-used.xbel{,original}
As you like it.
The entries are registered in the following file.
I think this will work.
Just to be sure, nemo and nautilus refer to the same file.
Make a backup and try deleting it,
registering a new one, deleting it, and testing it in various ways.
This will solve the problem, right?
If this is correct, congratulations.
Otherwise.
I tried to rename the recently-used.xbel file in recently-used.xbel.save. Nothing happen. A new recently-used.xbel file is just recreated with same content. Is there something else I should try with this file ?
The content of the file is :
<?xml version="1.0" encoding="UTF-8"?>
<xbel version="1.0"
      xmlns:bookmark="http://www.freedesktop.org/standards/desktop-bookmarks"
      xmlns:mime="http://www.freedesktop.org/standards/shared-mime-info"
></xbel>
