Messed up prime installation, no Nvidia driver active
I think I have messed up my graphics drivers and need help. Does anyone of you know a solution?
I seem to have an orphan (?) bumblebee installation that breaks prime and my Nvidia driver. Or is it something else?
When I re-install via:
mhwd -f -i pci video-hybrid-intel-nvidia-prime
Everything works fine.
But prime-run doesn’t work, and the Nvidia driver is shown as “N/A”.
Output to mhwd -li is:
> Installed PCI configs:
video-hybrid-intel-nvidia-prime            2020.11.30               false            PCI
           video-linux            2018.05.04                true            PCI
Output to inxi -Fazy is:
  Kernel: 5.10.7-3-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
  root=UUID=56a980d9-4378-40af-8e32-d0c7df8b6d97 rw quiet apparmor=1
  security=apparmor resume=UUID=b914514e-cfba-4360-8c09-99ed20c052cd
  udev.log_priority=3
  Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
  Distro: Manjaro Linux
  Type: Laptop System: ASUSTeK product: ZenBook UX333FN_UX333FN v: 1.0
  serial: <filter>
  Mobo: ASUSTeK model: UX333FN v: 1.0 serial: <filter>
  UEFI: American Megatrends v: UX333FN.308 date: 07/23/2019
  ID-1: BAT0 charge: 42.9 Wh condition: 42.9/50.1 Wh (86%) volts: 11.9/11.9
  model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Not charging
  cycles: 52
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K540/K545
  serial: <filter> charge: 100% (should be ignored) rechargeable: yes
  status: Discharging
  Info: Quad Core model: Intel Core i7-8565U bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: B (11)
  microcode: DE L2 cache: 8 MiB
  bogomips: 32012
  Speed: 800 MHz min/max: 400/4600 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800 7: 800 8: 800
  Device-1: Intel UHD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:3ea0
  Device-2: NVIDIA GP108M [GeForce MX150] driver: N/A
  alternate: nouveau, nvidia_drm, nvidia bus ID: 02:00.0 chip ID: 10de:1d12
  Device-3: IMC Networks USB2.0 HD IR UVC WebCam type: USB driver: uvcvideo
  bus ID: 1-5:7 chip ID: 13d3:56cb serial: <filter>
  Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
  loaded: modesetting unloaded: intel alternate: fbdev,vesa display ID: :0
  screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.7x15.0")
  s-diag: 777mm (30.6")
  Monitor-1: HDMI-1 res: 2560x1440 hz: 60 dpi: 118
  size: 553x311mm (21.8x12.2") diag: 634mm (25")
  OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2) v: 4.6 Mesa 20.3.3
  direct render: Yes
  Device-1: Intel Cannon Point-LP High Definition Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
  bus ID: 00:1f.3 chip ID: 8086:9dc8
  Device-2: Licensed by Sony Entertainment America Wireless Stereo Headset
  type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-1.2:4
  chip ID: 12ba:0034
  Sound Server: ALSA v: k5.10.7-3-MANJARO
  Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi v: kernel
  port: 4000 bus ID: 00:14.3 chip ID: 8086:9df0
  chip ID: 12ba:0034
  Local Storage: total: 238.47 GiB used: 177.3 GiB (74.3%)
  model: PC SN520 SDAPNUW-256G-1002 size: 238.47 GiB block size:
  physical: 512 B logical: 512 B speed: 15.8 Gb/s lanes: 2 serial: <filter>
  rev: 20110000 temp: 45.9 C
  ID-1: / raw size: 221.14 GiB size: 216.67 GiB (97.98%)
  used: 177.3 GiB (81.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
  used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-1: swap-1 type: partition size: 17.03 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 53.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 0
  Processes: 221 Uptime: 12m wakeups: 3 Memory: 15.45 GiB
  used: 3.09 GiB (20.0%) Init: systemd v: 247 target: graphical.target
  Compilers: gcc: 10.2.0 clang: 11.0.1 Packages: apt: 0 pacman: 1473 lib: 445
  rpm: 0 flatpak: 0 Shell: Bash v: 5.1.0 running in: konsole inxi: 3.2.02
What can I do to solve the problem? Thank you so much for any suggestions!
According to the nVidia Product page the GeForce MX150 is not compatible with the driver you installed, which you can see here:
so you’ll have to get rid of the 460 and install one of the 390 series that still supports your card::
video-hybrid-intel-nvidia-390xx-bumblebee            2020.11.30               false            PCI
video-nvidia-390xx            2020.11.30               false            PCI
:sob:
Thank you so much for helping me, Fabby!
The strange thing is, when I enter by hand:
modprobe nvidia
And afterwards inxi -G, then the driver seems to be loaded:
Graphics:  Device-1: Intel UHD Graphics 620 driver: i915 v: kernel
           Device-2: NVIDIA GP108M [GeForce MX150] driver: nvidia v: 460.32.03
           Display: x11 server: X.Org 1.20.10 driver: loaded: modesetting unloaded: intel resolution: 2560x1440~60Hz
And it seems to be version 460.32.03. Up to version 460.39 is supporting my GeForce MX150, according to this page:
https://www.nvidia.com/Download/driverResults.aspx/170134/en-us
But if you say, it won’t work with this, I’ll go back to the 390 series. I just wonder … I bought my notebook September 2019, it doesn’t seem that old to me.
Even with the driver loaded, trying to start nvidia-settings says:
(nvidia-settings:105746): Gtk-WARNING **: 17:51:02.700: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used any
more. It will be removed in a future version
ERROR: Unable to load info from any available system
And when I try prime-run steam, I get
Running Steam on manjarolinux 20.2.1 64-bit
STEAM_RUNTIME is enabled automatically
Pins up-to-date!
Steam client's requirements are satisfied
/home/titus/.local/share/Steam/ubuntu12_32/steam
[2021-02-09 17:52:31] Startup - updater built Feb  8 2021 05:16:36
Installing breakpad exception handler for appid(steam)/version(1612763122)
SteamUpdateUI: An X Error occurred
X Error of failed request:  BadValue (integer parameter out of range for operation)
Thank you very much for your time and effort! It is so great not to be left alone with the problem.
My bad! (And why I include my sources, so you can verify) :+1:
What’s the output of prime-run nvidia-smi and lsmod | grep nvidia
:question:
There is still hope then? That’s great!
Before I do sudo modprobe nvidia after reboot, both commands don’t work (the first gives out: NVIDIA-SMI has failed because it couldn’t communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.)
After the modprobe command, prime-run nvidia-smi gives out:
Wed Feb 10 10:01:41 2021
| NVIDIA-SMI 460.39       Driver Version: 460.39       CUDA Version: 11.2     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  GeForce MX150       Off  | 00000000:02:00.0 Off |                  N/A |
| N/A   34C    P0    N/A /  N/A |      0MiB /  2002MiB |      2%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|  No running processes found                                                 |
And lsmod | grep nvidia tells me:
nvidia 34144256 0
(“nvidia” is printed in red color.)
Thank you a lot for your time and help!
That’s weird that you have to do a modprobe.
Do you have anything blacklisted? (I.E. What are the contents of /etc/modprobe.d/)
:thinking:
In /etc/modprobe.d/ there is mhwd-bbswitch.conf containing
## Generated by mhwd - Manjaro Hardware Detection
options bbswitch load_state=0 unload_state=0
and there is mhwd-gpu.conf containing
blacklist nouveau
blacklist ttm
blacklist drm_kms_helper
blacklist drm
options nvidia "NVreg_DynamicPowerManagement=0x02"
and there is mhwd-nvidia.conf containing
blacklist nouveau
blacklist nvidia
blacklist nvidia-modeset
blacklist nvidia-uvm
blacklist ttm
blacklist drm
A lot of blacklisting … :wink:
Is anything of this harmful? Blacklist nvidia in mhwd-nvidia.conf is strange, isn’t it?
Yup: Remove the blacklists for nVidia in mhwd-nvidia.conf and reboot and try again.
:+1:
Strange. I removed all three blacklist-commands for nvidia, mhwd-nvidia.conf now reads:
blacklist nouveau
blacklist ttm
blacklist drm
Still, the driver is not loaded (“N/A” in inxi -G), until I do modprobe nvidia.
I cannot do prime-run nvidia-smi before I did that. Afterwards it now reads:
Wed Feb 10 13:43:28 2021
|                               |                      |               MIG M. |
| N/A   50C    P0    N/A /  N/A |      0MiB /  2002MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|        ID   ID                                                   Usage      |
It might be nothing, but I noticed since the reboot the ventilation of my notebook is on a high level (already before I did modprobe nvidia), as if it would be heavily working, even though I don’t do much. And in prime-run nvidia-smi it now says 50C, while before it were 34C.
Did I delete too much, should I put blacklist nvidia-modeset and blacklist nvidia-uvm back in?
On the contrary: apparently on my system:
lsmod | grep drm
nvidia_drm             69632  14
nvidia_modeset       1232896  35 nvidia_drm
drm_kms_helper        274432  1 nvidia_drm
cec                    69632  1 drm_kms_helper
drm                   569344  17 drm_kms_helper,nvidia_drm
agpgart                53248  1 drm
syscopyarea            16384  1 drm_kms_helper
sysfillrect            16384  1 drm_kms_helper
sysimgblt              16384  1 drm_kms_helper
so remove the blacklist for drm_kms_helper and drm as well and try again.
:crossed_fingers:
That didn’t do anything bad, but didn’t do anything good either. My mhwd-nvidia.conf now looks like this:
blacklist nouveau
blacklist ttm
The driver still isn’t loaded, until I do modprobe nvidia by hand. I would gladly do that every time I boot up, if only prime-run would work! But it doesn’t, even after his modprobe command.
On my system, lsmod | grep drm now looks like this.
lsmod | grep drm
drm_kms_helper        274432  1 i915
cec                    69632  2 drm_kms_helper,i915
drm                   569344  14 drm_kms_helper,i915
agpgart                53248  2 intel_gtt,drm
fb_sys_fops            16384  1 drm_kms_helper
It’s a difficult case, right?
Should I try to remove the following from my mhwd-gpu.conf?
blacklist drm
I’ll do that and report back. Thank you so much for your patience, Fabby!
Regrettably, that didn’t help. I also deleted from mhwd-gpu.conf the line
But it didn’t help the driver to be loaded. (I thought it might be from a different version of the driver and somehow hinder the new version to load properly.)
Now that it isn’t blacklisted anymore, could it be that the nvidia driver needs to be added somewhere? I wish I knew more about all this … Thank you for fighting through the thicket together with me.
OK, I’m officially all out of bright ideas now!
:sob:
@philm what was messed up here?? :alien:
Some others have issue with lastest nvidia and 5.10.x kernel. Regards
Since we dropped the support of old Nvidia drivers, it seems it got worse. At some point we might need to drop also 390, which will leave us with only the latest Nvidia drivers in rolling. So we have to see on how that will go.
seems there was some issues with extramodules. pushed now a new kernel:
https://lists.manjaro.org/pipermail/manjaro-packages/Week-of-Mon-20210208/036022.html
https://lists.manjaro.org/pipermail/manjaro-packages/Week-of-Mon-20210208/036023.html
For me, the kernel update wasn’t the solution. But I love Manjaro and I thank you for making it better and better!
A big thank you also to Fabby, thanks for trying so hard and all your solution ideas! All the best to you.
Titus
