I was trying to install optimus manager on manjaro kde plasma but i got messed up and now my external monitor is also not working …please help
[hackgod@hackgod ~]$ inxi -Fazy
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=dab9d69d-20e4-426c-a928-27ca2c674374 ro quiet apparmor=1
security=apparmor resume=UUID=0db58c1f-3ed1-4e0f-88ed-02bfc84ed629
udev.log_priority=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
dm: SDDM Distro: Manjaro Linux
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-cx0xxx
v: Type1ProductConfigId serial: Chassis: type: 10 serial:
Mobo: HP model: 8478 v: 70.51 serial: UEFI: Insyde v: F.18
date: 01/21/2019
ID-1: BAT1 charge: 12.6 Wh condition: 41.1/52.8 Wh (78%) volts: 10.4/11.6
model: Hewlett-Packard PABAS0241231 type: Li-ion serial:
status: Discharging
Info: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 9E (158) stepping: A (10)
microcode: DE L2 cache: 9 MiB
bogomips: 52815
Speed: 800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
Type: l1tf
Device-1: Intel UHD Graphics 630 vendor: Hewlett-Packard driver: i915
v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard
driver: N/A alternate: nouveau bus ID: 01:00.0 chip ID: 10de:1c8d
Device-3: Lite-On HP Wide Vision FHD Camera type: USB driver: uvcvideo
bus ID: 1-5:3 chip ID: 04ca:7086 serial:
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: modesetting display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.3
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus ID: 00:1f.3 chip ID: 8086:a348
Device-2: NVIDIA GP107GL High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0fb9
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
port: 4000 bus ID: 02:00.0 chip ID: 10ec:b822
IF: wlo1 state: up mac:
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 05:00.0
chip ID: 10ec:8168
IF: eno1 state: down mac:
Local Storage: total: 1.36 TiB used: 12.84 GiB (0.9%)
model: WDS500G2B0C-00PXH0 size: 465.76 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: rev: 211070WD
temp: 38.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-60Z10T0
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: rev: 1A04
ID-1: / raw size: 39.06 GiB size: 38.2 GiB (97.79%) used: 11.35 GiB (29.7%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot/efi raw size: 99 MiB size: 95 MiB (95.96%)
used: 85.7 MiB (90.2%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw size: 126.95 GiB size: 124.46 GiB (98.04%)
used: 1.41 GiB (1.1%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
ID-1: swap-1 type: partition size: 11.72 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p8 maj-min: 259:8
System Temperatures: cpu: 48.0 C mobo: 29.8 C
Processes: 294 Uptime: 17m wakeups: 1 Memory: 11.59 GiB
used: 3.93 GiB (33.9%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: 1260 pacman: 1256 lib: 376 flatpak: 0 snap: 4 Shell: Bash v: 5.1.0
running in: yakuake inxi: 3.2.02
Please do not hijack other’s topics, especially if they are months old.
Moved to a new topic.
Also, please encapsulate terminal output with the </>
button or within 3 backticks so it is easier to read.
Please post the output of head -n999 /etc/X11/xorg.conf /etc/X11/xorg.conf.d/*
