Mesa Zink trouble since 23.3.3
Since mesa update to 23.3.3 I get this when trying to use zink.
ex: MESA_LOADER_DRIVER_OVERRIDE=zink glmark2
DRI3 not available
failed to load driver: zink
DRI3 not available
DRI3 not available
Error: glXChooseFBConfig() failed
Error: Error: Couldn't get GL visual config!
Error: main: Could not initialize canvas
I’m running Manjaro KDE Plasma on AMD Ryzen 7 4700U with integrated Radeon RX Vega 6.
I’m running all the latest packages on kernel 6.1.80-1.
Any tips on how to solve this problem?
can you report
inxi -Fza
sudo mhwd-kernel -li
Sure, here they are:
inxi -Fza         ✔
  Kernel: 6.1.80-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: hpet avail: acpi_pm
    root=UUID=9c42cfb3-dce0-435a-b1cd-52b87a19b63b rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
    v: 5.115.0 wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: LENOVO product: 81W4 v: IdeaPad 3 15ARE05
    serial: <superuser required> Chassis: type: 10 v: IdeaPad 3 15ARE05
  Mobo: LENOVO model: LNVNB161216 v: No DPK serial: <superuser required>
    part-nu: LENOVO_MT_81W4_BU_idea_FM_IdeaPad 3 15ARE05
    uuid: <superuser required> UEFI: LENOVO v: DZCN44WW date: 05/16/2022
  ID-1: BAT0 charge: 23.5 Wh (56.6%) condition: 41.5/45.0 Wh (92.2%)
    volts: 11.7 min: 11.3 model: Celxpert L19C3PF7 type: Li-poly
    serial: <filter> status: not charging cycles: 116
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
    status: discharging
  Device-2: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter>
    charge: 55% (should be ignored) rechargeable: yes status: discharging
  Info: model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP
    arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
    microcode: 0x8600106
  Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
    desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1623 high: 2000 min/max: 1400/2000 boost: enabled
    scaling: driver: acpi-cpufreq governor: userspace cores: 1: 1397 2: 1397
    3: 2000 4: 1397 5: 1397 6: 1397 7: 2000 8: 2000 bogomips: 31953
  Type: spec_rstack_overflow mitigation: SMT disabled
  Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
    disabled, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: AMD Renoir [Radeon RX Vega 6 ] vendor: Lenovo driver: amdgpu
    v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 off: eDP-1
    empty: none bus-ID: 03:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 30.0 C
  Device-2: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:4 chip-ID: 5986:1135
  Display: x11 server: X.Org v: 21.1.11 compositor: kwin_x11 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
    s-diag: 581mm (22.86") monitors: <missing: xrandr>
  Monitor-1: HDMI-A-1 model: Samsung S22B350 serial: <filter> built: 2013
    res: 1920x1080 dpi: 102 gamma: 1.2 size: 477x268mm (18.78x10.55")
    diag: 547mm (21.5") ratio: 16:9 modes: max: 1920x1080 min: 720x400
  Monitor-2: eDP-1 model: BOE Display 0x0812 built: 2018 res: 1920x1080
    dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
    ratio: 16:9 modes: max: 1920x1080 min: 640x480
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
    renoir LLVM 16.0.6 DRM 3.49 6.1.80-1-MANJARO) device-ID: 1002:1636
    memory: 1.95 GiB unified: no
  API: Vulkan v: 1.3.279 layers: 1 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.0.2-manjaro1.1
    device-ID: 1002:1636 surfaces: xcb,xlib
  Device-1: AMD Renoir Radeon High Definition Audio vendor: Lenovo
    bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo driver: N/A
    alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
    snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
    snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.1.80-1-MANJARO status: kernel-api with: aoss
  Server-1: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli
  Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
    vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 01:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 38.0 C
  Device-1: Qualcomm Atheros QCA61x4 Bluetooth 4.0 driver: btusb v: 0.8
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:2
    chip-ID: 0cf3:e300 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 5 state: up address: see --recommends
  Local Storage: total: 931.51 GiB used: 408.45 GiB (43.8%)
    model: WD Blue SN570 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 234110WD temp: 20.9 C scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
    used: 408.45 GiB (44.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 45.2 C mobo: N/A gpu: amdgpu temp: 31.0 C
  Fan Speeds (rpm): N/A
  Memory: total: 20 GiB note: est. available: 17.43 GiB used: 3.06 GiB (17.6%)
  Processes: 295 Power: uptime: 3h 29m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 2 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 6.96 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: pm: pacman pkgs: 1269 libs: 346 tools: pamac pm: flatpak pkgs: 0
    Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.26 running-in: konsole inxi: 3.3.33
and
sudo mhwd-kernel -li         ✔
[sudo] password for cbs:
Currently running: 6.1.80-1-MANJARO (linux61)
   * linux61
   * linux66
   * linux67
I get the same on RX 6800 + 6.6 kernel + kwin_x11.
It looks like this regression is the fault because if you add LIBGL_KOPPER_DRI2=1 then it works fine.
EDIT Just tested in Wayland and no problem there so it’s something specific to X11.
Thank you MrLavender. Solved.
