Hi all,
For the past ~2 weeks I’ve been having troubles building mesa-git. Usually I build a new development version every 3-4 weeks and stick with it if it works OK for my needs.
Generally I use this repo https://github.com/Frogging-Family/mesa-git . Currently neither the TkG, nor the Manjaro mesa-git packages cab be bullt.
The last working version for me is mesa-tkg-git-22.0.0_devel.147458.a46d1553292-1 from 25.11.2021. Then the mesa repo was cleaned - some obsolete drivers were removed and after that all my attempts to build a new git package fail.
pamac build mesa-git lib32-mesa-git
----cut---
==> Updated version: mesa-git 22.0.0_devel.147991.abace2b8a45.d41d8cd98f00b204e9800998ecf8427e-1
==> Removing existing $pkgdir/ directory...
==> Starting build()...
The Meson build system
Version: 0.60.2
Source dir: /var/tmp/pamac-build-neckfreak/mesa-git/src/mesa
Build dir: /var/tmp/pamac-build-neckfreak/mesa-git/src/_build
Build type: native build
Program python3 found: YES (/usr/bin/python3)
Project name: mesa
Project version: 22.0.0-devel
C compiler for the host machine: ccache cc (gcc 11.1.0 "cc (GCC) 11.1.0")
C linker for the host machine: cc ld.bfd 2.36.1
C++ compiler for the host machine: ccache c++ (gcc 11.1.0 "c++ (GCC) 11.1.0")
C++ linker for the host machine: c++ ld.bfd 2.36.1
Host machine cpu family: x86_64
Host machine cpu: x86_64
Checking if "-mtls-dialect=gnu2" runs: YES
Checking if "split TLSDESC" : links: YES
Found pkg-config: /usr/bin/pkg-config (1.8.0)
Run-time dependency vdpau found: YES 1.4
Run-time dependency vulkan found: YES 1.2.199
Program glslangValidator found: YES (/usr/bin/glslangValidator)
Run-time dependency libomxil-bellagio found: YES 0.9.3
Run-time dependency libva found: YES 1.13.0
Header <va/va.h> has symbol "VASurfaceAttribDRMFormatModifiers" with dependency libva: YES
Run-time dependency libclc found: YES 0.2.0
Fetching value of define "ETIME" : 62
Checking for function "bswap32" : YES
Checking for function "bswap64" : YES
Checking for function "clz" : YES
Checking for function "clzll" : YES
Checking for function "ctz" : YES
Checking for function "expect" : YES
Checking for function "ffs" : YES
Checking for function "ffsll" : YES
Checking for function "popcount" : YES
Checking for function "popcountll" : YES
Checking for function "unreachable" : YES
Checking for function "types_compatible_p" : YES
Compiler for C supports function attribute const: YES
Compiler for C supports function attribute flatten: YES
Compiler for C supports function attribute malloc: YES
Compiler for C supports function attribute pure: YES
Compiler for C supports function attribute unused: YES
Compiler for C supports function attribute warn_unused_result: YES
Compiler for C supports function attribute weak: YES
Compiler for C supports function attribute format: YES
Compiler for C supports function attribute packed: YES
Compiler for C supports function attribute returns_nonnull: YES
Compiler for C supports function attribute alias: YES
Compiler for C supports function attribute noreturn: YES
Compiler for C supports function attribute visibility:hidden: YES
Checking if "__uint128_t" : compiles: YES
Compiler for C supports link arguments -Wl,--gc-sections: YES
Compiler for C supports arguments -Werror=implicit-function-declaration: YES
Compiler for C supports arguments -Werror=missing-prototypes: YES
Compiler for C supports arguments -Werror=return-type: YES
Compiler for C supports arguments -Werror=empty-body: YES
Compiler for C supports arguments -Werror=incompatible-pointer-types: YES
Compiler for C supports arguments -Werror=int-conversion: YES
Compiler for C supports arguments -Wimplicit-fallthrough: YES
Compiler for C supports arguments -Wno-missing-field-initializers: YES
Compiler for C supports arguments -Wno-format-truncation: YES
Compiler for C supports arguments -fno-math-errno: YES
Compiler for C supports arguments -fno-trapping-math: YES
Compiler for C supports arguments -Qunused-arguments: NO
Compiler for C supports arguments -fno-common: YES
Compiler for C supports arguments -Wno-microsoft-enum-value: NO
Compiler for C supports arguments -Werror=format: YES
Compiler for C supports arguments -Wformat-security: YES
Compiler for C supports arguments -Werror=thread-safety: NO
Compiler for C supports arguments -ffunction-sections: YES
Compiler for C supports arguments -fdata-sections: YES
Compiler for C++ supports arguments -Werror=return-type: YES
Compiler for C++ supports arguments -Werror=empty-body: YES
Compiler for C++ supports arguments -Wno-non-virtual-dtor: YES
Compiler for C++ supports arguments -Wno-missing-field-initializers: YES
Compiler for C++ supports arguments -Wno-format-truncation: YES
Compiler for C++ supports arguments -fno-math-errno: YES
Compiler for C++ supports arguments -fno-trapping-math: YES
Compiler for C++ supports arguments -Qunused-arguments: NO
Compiler for C++ supports arguments -flifetime-dse=1: YES
Compiler for C++ supports arguments -Wno-microsoft-enum-value: NO
Compiler for C++ supports arguments -Werror=format: YES
Compiler for C++ supports arguments -Wformat-security: YES
Compiler for C++ supports arguments -ffunction-sections: YES
Compiler for C++ supports arguments -fdata-sections: YES
Compiler for C supports arguments -Wno-override-init: YES
Compiler for C supports arguments -Wno-initializer-overrides: NO
Compiler for C supports arguments -Werror=pointer-arith: YES
Compiler for C supports arguments -Werror=gnu-empty-initializer: NO
Compiler for C++ supports arguments -Werror=pointer-arith: YES
Compiler for C++ supports arguments -Werror=gnu-empty-initializer: NO
Checking if "GCC atomic builtins" : compiles: YES
Checking if "GCC atomic builtins required -latomic" : links: YES
Checking if "GCC 64bit atomics" with dependency not-found: links: YES
Library ws2_32 found: NO
Header <sys/sysmacros.h> has symbol "major" : YES
Header <sys/sysmacros.h> has symbol "minor" : YES
Header <sys/sysmacros.h> has symbol "makedev" : YES
Header <sys/mkdev.h> has symbol "major" : NO
Check usable header "sched.h" : YES
Checking for function "sched_getaffinity" : YES
Check usable header "xlocale.h" : NO
Check usable header "linux/futex.h" : YES
Check usable header "endian.h" : YES
Check usable header "dlfcn.h" : YES
Check usable header "sys/shm.h" : YES
Check usable header "cet.h" : YES
Check usable header "pthread_np.h" : NO
Checking for function "strtof" : YES
Checking for function "mkostemp" : YES
Checking for function "timespec_get" : YES
Checking for function "memfd_create" : YES
Checking for function "random_r" : YES
Checking for function "flock" : YES
Checking for function "strtok_r" : YES
Checking for function "getrandom" : YES
Checking for function "qsort_r" : YES
Checking for function "qsort_s" : NO
Header <errno.h> has symbol "program_invocation_name" : YES
Checking for function "posix_memalign" : YES
Checking whether type "struct dirent" has member "d_type" : YES
Checking if "strtod has locale support" : links: YES
Checking if "Bsymbolic" : links: YES
Checking if "gc-sections" : links: YES
Checking if "version-script" : links: YES
Checking if "dynamic-list" : links: YES
Compiler for C supports link arguments -Wl,--build-id=sha1: YES
Checking for function "dlopen" : NO
Library dl found: YES
Checking for function "dladdr" with dependency -ldl: YES
Checking for function "dl_iterate_phdr" : YES
Checking for function "clock_gettime" : YES
Run-time dependency zlib found: YES 1.2.11
Run-time dependency libzstd found: YES 1.5.0
Run-time dependency threads found: YES
Checking for function "pthread_setaffinity_np" with dependency threads: YES
Run-time dependency expat found: YES 2.4.1
Library m found: YES
Run-time dependency libdrm_amdgpu found: YES 2.4.109
Run-time dependency libdrm_radeon found: YES 2.4.109
Run-time dependency libdrm_nouveau found: YES 2.4.109
Run-time dependency libdrm found: YES 2.4.109
Run-time dependency libudev found: YES 249
Found CMake: /usr/bin/cmake (3.22.1)
WARNING: CMake: Dependency rt for LLVM target LLVMSupport was not found
WARNING: CMake: Dependency dl for LLVM target LLVMSupport was not found
WARNING: CMake: Dependency m for LLVM target LLVMSupport was not found
WARNING: Ignoring LLVM CMake dependency because dynamic was requested
llvm-config found: YES (/usr/bin/llvm-config) 13.0.0
Run-time dependency LLVM (modules: amdgpu, asmparser, bitreader, bitwriter, core, coverage, engine, executionengine, instcombine, instrumentation, ipo, irreader, linker, lto, mcdisassembler, mcjit, native, objcarcopts, option, profiledata, scalaropts, transformutils, coroutines, frontendopenmp) found: YES 13.0.0
Run-time dependency libelf found: YES 0.186
Run-time dependency libglvnd found: YES 1.3.4
Program bison found: YES (/usr/bin/bison)
Program bison found: YES 3.8.2 (/usr/bin/bison)
Program flex found: YES (/usr/bin/flex)
Run-time dependency libunwind found: YES 1.5.0
Build-time dependency wayland-scanner found: YES 1.19.0
Program /usr/bin/wayland-scanner found: YES (/usr/bin/wayland-scanner)
Run-time dependency wayland-protocols found: YES 1.24
Run-time dependency wayland-client found: YES 1.19.0
Run-time dependency wayland-server found: YES 1.19.0
Run-time dependency wayland-egl-backend found: YES 3
Run-time dependency OpenMP found: YES 4.5
Run-time dependency x11 found: YES 1.7.2
Run-time dependency xext found: YES 1.3.4
Run-time dependency xfixes found: YES 6.0.0
Run-time dependency xcb-glx found: YES 1.14
Run-time dependency xcb-shm found: YES 1.14
Run-time dependency xcb found: YES 1.14
Run-time dependency x11-xcb found: YES 1.7.2
Run-time dependency xcb-dri2 found: YES 1.14
Run-time dependency xcb-dri3 found: YES 1.14
Run-time dependency xcb-present found: YES 1.14
Dependency xcb-shm found: YES 1.14 (cached)
Run-time dependency xcb-sync found: YES 1.14
Run-time dependency xshmfence found: YES 1.3
Run-time dependency glproto found: YES 1.4.17
Run-time dependency dri2proto found: YES 2.8
Run-time dependency xxf86vm found: YES 1.1.4
Run-time dependency xcb-xfixes found: YES 1.14
Run-time dependency xcb-randr found: YES 1.14
Run-time dependency xrandr found: YES 1.5.2
Library sensors found: YES
Program nm found: YES (/usr/bin/nm)
Program symbols-check.py found: YES (/usr/bin/python /var/tmp/pamac-build-neckfreak/mesa-git/src/mesa/bin/symbols-check.py)
Program install_megadrivers.py found: YES (/usr/bin/python /var/tmp/pamac-build-neckfreak/mesa-git/src/mesa/bin/install_megadrivers.py)
Checking for function "mmap" : YES
Program decode.py found: YES (/var/tmp/pamac-build-neckfreak/mesa-git/src/mesa/src/compiler/isaspec/decode.py)
Program encode.py found: YES (/var/tmp/pamac-build-neckfreak/mesa-git/src/mesa/src/compiler/isaspec/encode.py)
Compiler for C supports link arguments -Wl,-Bsymbolic-functions: YES
Compiler for C supports link arguments -Wl,-z,relro: YES
Compiler for C supports link arguments -Wl,-Bsymbolic-functions: YES (cached)
Compiler for C supports link arguments -Wl,-z,relro: YES (cached)
Compiler for C++ supports arguments -Wno-unused-variable: YES
Compiler for C++ supports arguments -Wno-unused-local-typedefs: YES
Compiler for C++ supports arguments -Wno-unused-but-set-variable: YES
Compiler for C++ supports arguments -Wno-maybe-uninitialized: YES
Compiler for C++ supports arguments -Wno-self-assign: NO
Compiler for C++ supports arguments -fno-exceptions: YES
Compiler for C++ supports arguments -fno-rtti: YES
Compiler for C++ supports arguments -Wimplicit-fallthrough: YES
Compiler for C++ supports arguments -Wshadow: YES
Compiler for C++ supports arguments -DNOMINMAX: YES
Compiler for C supports arguments -Wimplicit-fallthrough: YES (cached)
Compiler for C supports arguments -Wshadow: YES
Compiler for C++ supports arguments -Wno-ignored-attributes: YES
Library Polly found: YES
Library PollyISL found: YES
Library clang-cpp found: YES
Compiler for C++ supports link arguments -Wl,--rpath=/usr/lib: YES
Checking if "dep-clang-usable" with dependencies LLVM, -lclang-cpp, threads runs: YES
Configuring mesa.icd using configuration
Program /var/tmp/pamac-build-neckfreak/mesa-git/src/mesa/bin/install_megadrivers.py found: YES (/usr/bin/python /var/tmp/pamac-build-neckfreak/mesa-git/src/mesa/bin/install_megadrivers.py)
WARNING: Library target 'OSMesa' has 'name_prefix' set. Compilers may not find it from its '-lOSMesa' linker flag in the 'osmesa.pc' pkg-config file.
WARNING: Library target 'OSMesa' has 'name_prefix' set. Compilers may not find it from its '-lOSMesa' linker flag in the 'osmesa-uninstalled.pc' pkg-config file.
Configuring xa_tracker.h using configuration
Checking for function "mincore" : YES
Configuring 50_mesa.json using configuration
Message: Configuration summary:
prefix: /usr
libdir: lib
includedir: include
OpenGL: yes (ES1: no ES2: yes)
OSMesa: libOSMesa
DRI platform: drm
DRI drivers: no
DRI driver dir: /usr/lib/dri
GLX: DRI-based
EGL: yes
EGL drivers: builtin:egl_dri2 builtin:egl_dri3
EGL/Vulkan/VL platforms: x11 wayland surfaceless drm xcb
GBM: yes
GBM backends path: /usr/lib/gbm
Vulkan drivers: amd intel swrast virtio-experimental
Vulkan ICD dir: share/vulkan/icd.d
Vulkan layers: device-select overlay
llvm: yes
llvm-version: 13.0.0
Gallium drivers: r300 r600 radeonsi nouveau svga swrast virgl iris zink crocus
Gallium st: mesa xa vdpau omxbellagio va nine clover
HUD lmsensors: yes
Shared-glapi: yes
Perfetto: no
Perfetto ds: auto
Build targets in project: 257
mesa 22.0.0-devel
User defined options
buildtype : plain
prefix : /usr
sysconfdir : /etc
wrap_mode : nofallback
b_lto : true
b_ndebug : true
dri3 : enabled
egl : enabled
gallium-drivers : r300,r600,radeonsi,nouveau,svga,swrast,virgl,iris,zink,crocus
gallium-extra-hud: true
gallium-nine : true
gallium-omx : bellagio
gallium-opencl : icd
gallium-va : enabled
gallium-vdpau : enabled
gallium-xa : enabled
gallium-xvmc : disabled
gbm : enabled
gles1 : disabled
gles2 : enabled
glvnd : true
glx : dri
libunwind : enabled
llvm : enabled
lmsensors : enabled
microsoft-clc : disabled
osmesa : true
platforms : x11,wayland
shared-glapi : enabled
tools : []
valgrind : disabled
vulkan-drivers : amd,intel,swrast,virtio-experimental
vulkan-layers : device-select,overlay
zstd : enabled
Found ninja-1.10.2 at /usr/bin/ninja
Core properties:
Source dir /var/tmp/pamac-build-neckfreak/mesa-git/src/mesa
Build dir /var/tmp/pamac-build-neckfreak/mesa-git/src/_build
Main project options:
Core options Current Value Possible Values Description
auto_features auto [enabled, disabled, Override value of all 'auto' features
auto]
backend ninja [ninja, vs, vs2010, Backend to use
vs2012, vs2013,
vs2015, vs2017,
vs2019,
xcode]
buildtype plain [plain, debug, Build type to use
debugoptimized,
release, minsize,
custom]
cmake_prefix_path [] List of additional prefixes for cmake to
search
debug false [true, false] Debug
default_library shared [shared, static, both] Default library type
force_fallback_for [] Force fallback for those subprojects
install_umask 0022 [preserve, 0000-0777] Default umask to apply on permissions of
installed files
layout mirror [mirror, flat] Build directory layout
optimization 0 [0, g, 1, 2, 3, s] Optimization level
pkg_config_path [] List of additional paths for pkg-config to
search
strip false [true, false] Strip targets on install
unity off [on, off, subprojects] Unity build
unity_size 4 >=2 Unity block size
warning_level 1 [0, 1, 2, 3] Compiler warning level to use
werror false [true, false] Treat warnings as errors
wrap_mode nofallback [default, nofallback, Wrap mode
nodownload,
forcefallback,
nopromote]
Backend options Current Value Possible Values Description
backend_max_links 0 >=0 Maximum number of linker processes to run or
0 for no limit
Base options Current Value Possible Values Description
b_asneeded true [true, false] Use -Wl,--as-needed when linking
b_colorout always [auto, always, never] Use colored output
b_coverage false [true, false] Enable coverage tracking.
b_lto true [true, false] Use link time optimization
b_lto_threads 0 Use multiple threads for Link Time
Optimization
b_lundef true [true, false] Use -Wl,--no-undefined when linking
b_ndebug true [true, false, if- Disable asserts
release]
b_pch true [true, false] Use precompiled headers
b_pgo off [off, generate, use] Use profile guided optimization
b_pie false [true, false] Build executables as position independent
b_sanitize none [none, address, Code sanitizer to use
thread, undefined,
memory,
address,undefined]
b_staticpic true [true, false] Build static libraries as position
independent
Compiler options Current Value Possible Values Description
c_args [-march=x86-64, Extra arguments passed to the c compiler
-mtune=generic, -O2,
-pipe, -fno-plt,
-fexceptions, -Wp,-D_F
ORTIFY_SOURCE=2,
-Wformat,
-Werror=format-
security, -fstack-
clash-protection,
-fcf-protection]
c_link_args [-Wl,-O1,--sort- Extra arguments passed to the c linker
common,--as-needed,-z,
relro,-z,now,
-march=x86-64,
-pipe, -fno-plt,
ORTIFY_SOURCE=2,
-Wformat,
-Werror=format-
security, -fstack-
clash-protection,
-fcf-protection]
c_std c11 [none, c89, c99, c11, C language standard to use
c17, c18, c2x, gnu89,
gnu99, gnu11,
gnu17, gnu18, gnu2x]
cpp_args [-march=x86-64, Extra arguments passed to the cpp compiler
-pipe, -fno-plt,
ORTIFY_SOURCE=2,
-Wformat,
-Werror=format-
security, -fstack-
clash-protection,
-fcf-protection, -Wp,-
D_GLIBCXX_ASSERTIONS]
cpp_debugstl false [true, false] STL debug mode
cpp_eh default [none, default, a, s, C++ exception handling type.
sc]
cpp_link_args [-Wl,-O1,--sort- Extra arguments passed to the cpp linker
relro,-z,now,
-march=x86-64,
-pipe, -fno-plt,
ORTIFY_SOURCE=2,
-Wformat,
-Werror=format-
security, -fstack-
clash-protection,
cpp_rtti true [true, false] Enable RTTI
cpp_std c++14 [none, c++98, c++03, C++ language standard to use
c++11, c++14, c++17,
c++1z, c++2a, c++20,
gnu++03, gnu++11,
gnu++14, gnu++17,
gnu++1z, gnu++2a,
gnu++20]
python module Current Value Possible Values Description
options
python.platlibdir Directory for site-specific, platform-
specific files.
python.purelibdir Directory for site-specific, non-platform-
specific files.
Directories Current Value Possible Values Description
bindir bin Executable directory
datadir share Data file directory
includedir include Header file directory
infodir share/info Info page directory
libdir lib Library directory
libexecdir libexec Library executable directory
localedir share/locale Locale data directory
localstatedir /var Localstate data directory
mandir share/man Manual page directory
prefix /usr Installation prefix
sbindir sbin System executable directory
sharedstatedir /var/lib Architecture-independent data directory
sysconfdir /etc Sysconf data directory
Testing options Current Value Possible Values Description
errorlogs true [true, false] Whether to print the logs from failing tests
stdsplit true [true, false] Split stdout and stderr in test logs
Project options Current Value Possible Values Description
android-stub false [true, false] Build against android-stub
build-aco-tests false [true, false] Build ACO tests. These require RADV and
glslang but not an AMD GPU.
build-tests false [true, false] Build unit tests. Currently this will build
*all* unit tests except the ACO tests, which
may build more than expected.
custom-shader- Enable a custom shader replacement
replacement mechanism. Note that enabling this option
requires adding/generating a
shader_replacement.h file that can be
included (see shaderapi.c).
d3d-drivers-path Location of D3D drivers. Default:
$libdir/d3d
datasources [auto] [auto, panfrost, List of Perfetto datasources to build. If
intel, freedreno] this is set to `auto`, datasources that can
not be build are skipped. Default: [`auto`]
draw-use-llvm true [true, false] Whether to use LLVM for the Gallium draw
module, if LLVM is included.
dri-drivers [] DEPRECATED: List of dri drivers to build. If
this is set to auto all drivers applicable
to the target OS/architecture will be built
dri-drivers-path Location to install dri drivers. Default:
$libdir/dri.
dri-search-path Locations to search for dri drivers, passed
as colon separated list. Default: dri-
drivers-path.
dri3 enabled [auto, true, false, enable support for dri3
disabled, enabled]
egl enabled [auto, true, false, Build support for EGL platform
enabled, disabled]
egl-lib-suffix Suffix to append to EGL library name.
Default: none.
egl-native-platform auto [auto, x11, wayland, the window system EGL assumes for
haiku, android, EGL_DEFAULT_DISPLAY
windows, surfaceless,
drm]
execmem true [true, false] Enable execmem support. Without execmem,
glapi will fail to generate dynamic glapi
stubs when entrypoints unknown to glapi but
known to DRI drivers are requested in
eglGetProcAddress or glXGetProcAddress.
This should be enabled unless the platform
can guarantee glapi and DRI drivers are
always built from the same source tree.
freedreno-kgsl false [true, false] use kgsl backend for freedreno vulkan driver
gallium-d3d10umd false [true, false] build gallium D3D10 WDDM UMD frontend.
gallium-drivers [r300, r600, radeonsi, [auto, kmsro, List of gallium drivers to build. If this is
nouveau, svga, swrast, radeonsi, r300, r600, set to auto all drivers applicable to the
virgl, iris, zink, nouveau, freedreno, target OS/architecture will be built
crocus]
swrast, v3d, vc4,
etnaviv, tegra, i915,
svga, virgl,
panfrost, iris, lima,
zink, d3d12, asahi,
crocus]
gallium-extra-hud true [true, false] Enable HUD block/NIC I/O HUD status support
gallium-nine true [true, false] build gallium "nine" Direct3D 9.x frontend.
gallium-omx bellagio [auto, disabled, enable gallium omx frontend.
bellagio, tizonia]
gallium-opencl icd [icd, standalone, build gallium "clover" OpenCL frontend.
disabled]
gallium-va enabled [auto, true, false, enable gallium va frontend.
enabled, disabled]
gallium-vdpau enabled [auto, true, false, enable gallium vdpau frontend.
enabled, disabled]
gallium-xa enabled [auto, true, false, enable gallium xa frontend.
enabled, disabled]
gallium-xvmc disabled [auto, true, false, enable gallium xvmc frontend.
enabled, disabled]
gbm enabled [auto, true, false, Build support for gbm platform
enabled, disabled]
gbm-backends-path Locations to search for gbm backends, passed
$libdir/gbm.
gles-lib-suffix Suffix to append to GLES library names.
Default: none.
gles1 disabled [auto, true, false, Build support for OpenGL ES 1.x
enabled, disabled]
gles2 enabled [auto, true, false, Build support for OpenGL ES 2.x and 3.x
enabled, disabled]
glvnd true [true, false] Enable GLVND support.
glvnd-vendor-name mesa Vendor name string to use for glvnd
libraries
glx dri [auto, disabled, dri, Build support for GLX platform
xlib]
glx-direct true [true, false] Enable direct rendering in GLX and EGL for
DRI
glx-read-only-text false [true, false] Disable writable .text section on x86
(decreases performance)
install-intel-gpu- false [true, false] Build and install Intel unit tests which
tests require the GPU. This option is for
developers and the Intel CI system only.
libunwind enabled [auto, true, false, Use libunwind for stack-traces
enabled, disabled]
llvm enabled [auto, true, false, Build with LLVM support.
enabled, disabled]
lmsensors enabled [auto, true, false, Enable HUD lmsensors support.
enabled, disabled]
microsoft-clc disabled [enabled, disabled, Build support for the Microsoft CLC to DXIL
auto] compiler
moltenvk-dir Location of the MoltenVk SDK. Default:
omx-libs-path path to put omx libraries. defaults to omx-
bellagio pkg-config pluginsdir.
opencl-native true [true, false] build gallium "clover" OpenCL frontend with
native LLVM codegen support.
opencl-spirv false [true, false] build gallium "clover" OpenCL frontend with
SPIR-V binary support.
opengl true [true, false] Build support for OpenGL (all versions)
osmesa true [true, false] Build OSmesa.
osmesa-bits 8 [8, 16, 32] Number of channel bits for OSMesa.
perfetto false [true, false] Enable performance analysis with Perfetto.
Default: false
platform-sdk-version 25 >=25, <=31 Android Platform SDK version. Default:
Nougat version.
platforms [x11, wayland] [auto, x11, wayland, window systems to support. If this is set to
haiku, android, `auto`, all platforms applicable will be
windows] enabled.
power8 auto [auto, true, false, Enable power8 optimizations.
enabled, disabled]
selinux false [true, false] Build an SELinux-aware Mesa. This currently
disables execmem support at runtime unless
SELinux is configured with allow_execmem.
shader-cache auto [auto, true, false, Build with on-disk shader cache support.
enabled, disabled]
shader-cache-default true [true, false] If set to false, the feature is only
activated when environment variable
MESA_GLSL_CACHE_DISABLE is set to false
shader-cache-max- Default value for MESA_GLSL_CACHE_MAX_SIZE
size enviroment variable. If set, determines
the maximum size of the on-disk cache of
compiled GLSL programs, can be overriden
by enviroment variable if needed. Should be
set to a number optionally followed by
``K``, ``M``, or ``G`` to specify a size in
kilobytes, megabytes, or gigabytes. By
default, gigabytes will be assumed. And if
unset, a maximum size of 1GB will be
used.
shared-glapi enabled [auto, true, false, Whether to build a shared or static glapi.
enabled, disabled] Defaults to false on Windows, true elsewhere
shared-llvm auto [auto, true, false, Whether to link LLVM shared or statically.
enabled, disabled]
spirv-to-dxil false [true, false] Build support for the SPIR-V to DXIL library
sse2 true [true, false] use msse2 flag for x86. Uses sse/sse2
instead of x87. Default: true
static-libclc [] [spirv, spirv64, all] Link libclc SPIR-V statically.
tools [] [drm-shim, etnaviv, List of tools to build. (Note: `intel-ui`
freedreno, glsl, selects `intel`)
intel, intel-ui, nir,
nouveau, xvmc, lima,
panfrost, asahi, all]
va-libs-path path to put va libraries. defaults to
$libdir/dri.
valgrind disabled [auto, true, false, Build with valgrind support
enabled, disabled]
vdpau-libs-path path to put vdpau libraries. defaults to
$libdir/vdpau.
vmware-mks-stats false [true, false] Build gallium VMware/svga driver with
mksGuestStats instrumentation.
vulkan-beta false [true, false] Build vulkan drivers with BETA extensions
enabled.
vulkan-drivers [amd, intel, swrast, [auto, amd, broadcom, List of vulkan drivers to build. If this is
virtio-experimental] freedreno, intel, set to auto all drivers applicable to the
panfrost, swrast, target OS/architecture will be built
vulkan-icd-dir Location relative to prefix to put vulkan
icds on install. Default:
$datadir/vulkan/icd.d
vulkan-layers [device-select, [device-select, intel- List of vulkan layers to build
overlay] nullhw, overlay]
xlib-lease auto [auto, true, false, Enable VK_EXT_acquire_xlib_display.
enabled, disabled]
xvmc-libs-path path to put xvmc libraries. defaults to
$libdir.
zlib enabled [enabled, disabled, Use ZLIB to build driver. Default: enabled
auto]
zstd enabled [auto, true, false, Use ZSTD instead of ZLIB in some cases.
enabled, disabled]
ninja: Entering directory `_build'
[453/2369] Generating src/vulkan/overlay-layer/overlay.frag.spv.h with a custom command
../mesa/src/vulkan/overlay-layer/overlay.frag
[471/2369] Generating src/vulkan/overlay-layer/overlay.vert.spv.h with a custom command
../mesa/src/vulkan/overlay-layer/overlay.vert
[914/2369] Compiling C object src/loader/libloader.a.p/loader.c.o
FAILED: src/loader/libloader.a.p/loader.c.o
ccache cc -Isrc/loader/libloader.a.p -Isrc/loader -I../mesa/src/loader -Iinclude -I../mesa/include -Isrc -I../mesa/src -Isrc/util -I../mesa/src/util -I/usr/include/libdrm -fvisibility=hidden -flto=auto -fdiagnostics-color=always -DNDEBUG -D_FILE_OFFSET_BITS=64 -Wall -Winvalid-pch -std=c11 -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS '-DPACKAGE_VERSION="22.0.0-devel"' '-DPACKAGE_BUGREPORT="https://gitlab.freedesktop.org/mesa/mesa/-/issues"' -DHAVE_X11_PLATFORM -DHAVE_WAYLAND_PLATFORM -DHAVE_SURFACELESS_PLATFORM -DHAVE_DRM_PLATFORM -DHAVE_XCB_PLATFORM -DUSE_ELF_TLS -DHAVE_ST_VDPAU -DENABLE_ST_OMX_BELLAGIO=1 -DENABLE_ST_OMX_TIZONIA=0 -DHAVE_VA_SURFACE_ATTRIB_DRM_FORMAT_MODIFIERS -DGLX_INDIRECT_RENDERING -DGLX_DIRECT_RENDERING -DGLX_USE_DRM -DENABLE_SHADER_CACHE -DHAVE___BUILTIN_BSWAP32 -DHAVE___BUILTIN_BSWAP64 -DHAVE___BUILTIN_CLZ -DHAVE___BUILTIN_CLZLL -DHAVE___BUILTIN_CTZ -DHAVE___BUILTIN_EXPECT -DHAVE___BUILTIN_FFS -DHAVE___BUILTIN_FFSLL -DHAVE___BUILTIN_POPCOUNT -DHAVE___BUILTIN_POPCOUNTLL -DHAVE___BUILTIN_UNREACHABLE -DHAVE___BUILTIN_TYPES_COMPATIBLE_P -DHAVE_FUNC_ATTRIBUTE_CONST -DHAVE_FUNC_ATTRIBUTE_FLATTEN -DHAVE_FUNC_ATTRIBUTE_MALLOC -DHAVE_FUNC_ATTRIBUTE_PURE -DHAVE_FUNC_ATTRIBUTE_UNUSED -DHAVE_FUNC_ATTRIBUTE_WARN_UNUSED_RESULT -DHAVE_FUNC_ATTRIBUTE_WEAK -DHAVE_FUNC_ATTRIBUTE_FORMAT -DHAVE_FUNC_ATTRIBUTE_PACKED -DHAVE_FUNC_ATTRIBUTE_RETURNS_NONNULL -DHAVE_FUNC_ATTRIBUTE_ALIAS -DHAVE_FUNC_ATTRIBUTE_NORETURN -DHAVE_FUNC_ATTRIBUTE_VISIBILITY -DHAVE_UINT128 -D_GNU_SOURCE -DUSE_SSE41 -DUSE_GCC_ATOMIC_BUILTINS -DUSE_X86_64_ASM -DMAJOR_IN_SYSMACROS -DHAS_SCHED_H -DHAS_SCHED_GETAFFINITY -DHAVE_LINUX_FUTEX_H -DHAVE_ENDIAN_H -DHAVE_DLFCN_H -DHAVE_SYS_SHM_H -DHAVE_CET_H -DHAVE_STRTOF -DHAVE_MKOSTEMP -DHAVE_TIMESPEC_GET -DHAVE_MEMFD_CREATE -DHAVE_RANDOM_R -DHAVE_FLOCK -DHAVE_STRTOK_R -DHAVE_GETRANDOM -DHAVE_QSORT_R -DHAVE_PROGRAM_INVOCATION_NAME -DHAVE_POSIX_MEMALIGN -DHAVE_DIRENT_D_TYPE -DHAVE_STRTOD_L -DHAVE_DLADDR -DHAVE_DL_ITERATE_PHDR -DHAVE_ZLIB -DHAVE_ZSTD -DHAVE_COMPRESSION -DHAVE_PTHREAD -DHAVE_PTHREAD_SETAFFINITY -DHAVE_LIBDRM -DHAVE_LIBUDEV -DLLVM_AVAILABLE '-DMESA_LLVM_VERSION_STRING="13.0.0"' -DLLVM_IS_SHARED=1 -DDRAW_LLVM_AVAILABLE -DUSE_LIBGLVND=1 -DMESA_EXECMEM -DHAVE_LIBUNWIND -DWL_HIDE_DEPRECATED -DHAVE_OPENMP -DHAVE_DRI3 -DHAVE_DRI3_MODIFIERS -DHAVE_GALLIUM_EXTRA_HUD=1 -DHAVE_LIBSENSORS=1 -DVK_USE_PLATFORM_WAYLAND_KHR -DVK_USE_PLATFORM_XCB_KHR -DVK_USE_PLATFORM_XLIB_KHR -DVK_USE_PLATFORM_XLIB_XRANDR_EXT -DVK_USE_PLATFORM_DISPLAY_KHR -mtls-dialect=gnu2 -Werror=implicit-function-declaration -Werror=missing-prototypes -Werror=return-type -Werror=empty-body -Werror=incompatible-pointer-types -Werror=int-conversion -Wimplicit-fallthrough -Wno-missing-field-initializers -Wno-format-truncation -fno-math-errno -fno-trapping-math -fno-common -Werror=format -Wformat-security -ffunction-sections -fdata-sections -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -fexceptions -Wp,-D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security -fstack-clash-protection -fcf-protection -fPIC -pthread -DUSE_DRICONF '-DDEFAULT_DRIVER_DIR="/usr/lib/dri"' -MD -MQ src/loader/libloader.a.p/loader.c.o -MF src/loader/libloader.a.p/loader.c.o.d -o src/loader/libloader.a.p/loader.c.o -c ../mesa/src/loader/loader.c
../mesa/src/loader/loader.c: In function ‘loader_get_render_node’:
../mesa/src/loader/loader.c:187:8: error: implicit declaration of function ‘drmGetDeviceFromDevId’ [-Werror=implicit-function-declaration]
187 | if (drmGetDeviceFromDevId(device, 0, &dev_ptr) < 0)
cc1: some warnings being treated as errors
[923/2369] Linking target src/virtio/vulkan/libvulkan_virtio.so
ninja: build stopped: subcommand failed.
==> ERROR: A failure occurred in build().
Aborting...
This happens every time for every way I have tried to build the package
❯ inxi -GSa
System: Host: manjaro Kernel: 5.15.7-227-tkg-pds x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: intel_pstate=passive BOOT_IMAGE=/boot/vmlinuz-linux515-tkg-pds
root=UUID=9f256c65-627c-4f76-ae60-ac82eabbb8c1 rw quiet apparmor=1 security=apparmor
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.30.0
Graphics: Device-1: AMD Navi 10 [Radeon RX 5600 OEM/5600 XT / 5700/5700 XT] driver: amdgpu v: kernel
bus-ID: 03:00.0 chip-ID: 1002:731f class-ID: 0300
Device-2: Suyin Acer/HP Integrated Webcam [CN0314] type: USB driver: uvcvideo bus-ID: 1-7:4
chip-ID: 064e:a103 class-ID: 0e02 serial: CN0314-SN30-OV03-VA-R02.03.02
Display: x11 server: X.Org 1.21.1.1 compositor: xfwm4 v: 4.16.1 driver: loaded: amdgpu,ati
unloaded: modesetting,radeon alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 2944x1080 s-dpi: 96 s-size: 778x285mm (30.6x11.2") s-diag: 829mm (32.6")
Monitor-1: DisplayPort-0 res: 1920x1080 dpi: 92 size: 531x299mm (20.9x11.8") diag: 609mm (24")
Monitor-2: HDMI-A-0 res: 1024x768 dpi: 85 size: 307x230mm (12.1x9.1") diag: 384mm (15.1")
OpenGL: renderer: AMD Radeon RX 5700 XT (NAVI10 DRM 3.42.0 5.15.7-227-tkg-pds LLVM 13.0.0)
v: 4.6 Mesa 21.2.5 direct render: Yes
What can be done to remedy the situation? Let me know if more info is needed.
Thanks.
