Mesa-enable-h264 gone
The mesa-enable-h264 package suddenly disappeared from AUR…why?
on what branch are you ?
pacman-mirrors -G
i’m on stable and it’s avaiable
pacman search mesa
I’m on unstable.
pacman search mesa                                               ✔
Fehler: Keine Operation angegeben (benutzen Sie -h für Hilfe)
touche, my mistake
pamac search mesa
pamac not pacman, sorry
Its gone from the AUR. However, I think judging from the name that the mesa-git package also adds h264 de- and encoding.
You could also use nonfree.eu for manjaro-specific builds.
I’ve never used it, didn’t even know it exists. But it was likely a manjaro specific one, so …RIP!
You could also try installing the relevant amdonly-gaming-mesa-git packages instead. You may also have to replace the repo version of directx-headers with directx-headers-git to successfully build the amdonly-gaming packages.
I’ve been using amdonly-gaming-mesa-git on my Stable system for several months without any issues, but as the AUR is more suited to Unstable branch, I am fully aware that I could run into problems in the future. So far, the half-dozen or so times I have rebuilt the packages after system updates have all been problem-free. As you are on Unstable branch, you have less to worry about than me when it comes to building AUR packages.
I don’t use 32-bit libraries on my mini-PC (I removed the multilib repo from pacman), so the command I run to build the amdonly packages is:
pamac build directx-headers-git amdonly-gaming-mesa-git amdonly-gaming-libva-mesa-driver-git amdonly-gaming-mesa-vdpau-git amdonly-gaming-vulkan-radeon-git
A list of all the amdonly-gaming packages on the AUR: AUR (en) - Packages
the to is on unstable
Oops - I’ll fix my original post
To answer your question:
“I don’t care, and I don’t give a darn!”
– Abbott & Costello (1938)
…but, seriously… I believe it’s likely related to licensing issues of certain codecs; but I won’t engage in any extended debate about that.
Cheers.
Here you see the why: [PRQ#53879] Deletion Request for mesa-enable-h264 - Aur-requests - lists.archlinux.org
Arch doesnt care about that, and the AUR even less so.
Manjaro cares because of Manjaro GmbH.
Indeed; and it probably deserves some closure.
