Hello guys I reinstalled kde manjaro 20.03 and put updates to install and I slept for a while for some strange reason I was not able to login even after I gave correct password… so I forced shutdown my laptop… now everytime I switch on laptop it runs memtest 86 5.01 and it’s not allowing me to boot into desktop not sure how to Bypass this
any help would be appreciated
Welcome to Manjaro.
You should have read the current announcements known issue, perhaps this hit you:
- Try booting from usb and
manjaro-chroot -ainto your installation - fix the pam issues as described in the mentioned post above
- for good measure update the system
sudo pacman -Syu - and
sudo update grub
finally:
Please don’t ever do that to your system, Try this next time:
problem solved… i re installed manjaro kde from usb …i know its a pain but i had nothing to loose as it was a fresh install… i updated all latest updates via terminal not via interface… now running smoothly thanks for your input and i learnt something new thanks …i installed time shift so now need not have worry about breaking stuff lol… newbie to manjaro and linux loving manjaro kde …
