Hello,
MEGAsync tray icon crashs in Gnome 3.36 after reboot.
because it does not find the system tray.
It’s an AUR
package - did you rebuild it after the latest update?
Yes, it does not work again
I tried to remove all MEGA and configuration files. then new installation. No luck
It works randomly when I disabled all other Gnome extensions.
I think Megasync Tray Icon need delay min. 3 sec at startup. but delay doesn’t work.
How can I fix delay of application at startup?
I solved the issue:
A file .config/autostart/megasync.desktop
was changed:
Old command Exec=megasync
was removed.
Add new command: Exec=sh -c "sleep 3 && megasync"
It works fine!
