Hello, I got a cheap mechanical USB keyboard for my laptop, but I have some issues where holding down any key doesn’t acknowledge it as a “long press” but instead keeps pressing / spamming the same key
For example, using the arrow keys to move in any game makes the character movement jerky instead of the normal walk you’d expect.
Laptop’s internal keyboard doesn’t have this problem, and changing the Delay and Rate settings only affect the Laptop’s internal keyboard and not the USB one ( activating Slow Keys or Bounce Keys on Settings > Accessibility > Keyboard Filters does affect the USB keyboard but doesn’t fix the problem )
> inxi --full --admin --filter --width
Kernel: 6.3.5-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.3-x86_64
root=UUID=c3b6eb7e-c8fc-4def-870c-11c57c023d2c rw quiet
resume=UUID=c8a5270a-f9d1-4482-90ed-fef5bf02b181
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
Type: Portable System: Dell product: Inspiron N5050 v: N/A
serial: <superuser required> Chassis: type: 8 serial: <superuser required>
Mobo: Dell model: 01HXXJ v: A01 serial: <superuser required> BIOS: Dell
v: A01 date: 07/22/2011
Info: model: Intel Core i5-2430M bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2073 high: 2194 min/max: 800/3000 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2188 2: 2194 3: 1731
4: 2182 bogomips: 19167
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Dell driver: i915 v: kernel arch: Gen-6 code: Sandybridge
process: Intel 32nm built: 2011 ports: active: LVDS-1
empty: DP-1,HDMI-A-1,VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0116
class-ID: 0300
Device-2: Realtek Integrated Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.5:4 chip-ID: 0bda:58c0
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: intel dri: i965 gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 mapped: LVDS1 model: Seiko Epson 0x5441 built: 2010
res: 1366x768 hz: 60 dpi: 102 gamma: 1.2 size: 340x190mm (13.39x7.48")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
API: OpenGL v: 3.3 Mesa 23.0.4 renderer: Mesa Intel HD Graphics 3000 (SNB
GT2) direct-render: Yes
vendor: Dell 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
API: ALSA v: k6.3.5-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 05:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp5s0 state: down mac: <filter>
Device-2: Broadcom BCM4313 802.11bgn Wireless Network Adapter vendor: Dell
driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 09:00.0 chip-ID: 14e4:4727 class-ID: 0280
IF: wlp9s0 state: up mac: <filter>
Device-1: Broadcom BCM2070 Bluetooth 2.1 + EDR driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-1.4:3 chip-ID: 0a5c:21bc
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: N/A rfk-block:
hardware: no software: no address: see --recommends
Local Storage: total: 232.89 GiB used: 181 GiB (77.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: MBR
ID-1: / raw-size: 224.6 GiB size: 220.01 GiB (97.96%)
used: 180.99 GiB (82.3%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 8.29 GiB used: 9 MiB (0.1%) priority: -2
dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 67.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3099
Processes: 211 Uptime: 2h 8m wakeups: 3 Memory: available: 7.67 GiB
used: 4.16 GiB (54.3%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 2016 libs: 491 tools: pamac,yay pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
running-in: konsole inxi: 3.3.27
