Hello,
I was just checking up if everything is alright with my laptop until I check my dmesg and i have some warnings, can someone tell it’s not serious or something.
inxi
$ inxi -Fxxz -no-host
System: Host: Homelaptop Kernel: 5.8.5-2-MANJARO x86_64 bits: 64 compiler: N/A
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: Dell product: Latitude E5430 non-vPro v: 01 serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Dell model: 0F5PHF v: A00 serial: <filter> BIOS: Dell v: A03 date: 06/03/2012
Battery: ID-1: BAT0 charge: 0.1 Wh condition: 1.5/62.2 Wh (2%) volts: 9.0/11.1
model: LGC-LGC2.8 DELL HMYXT28 serial: <filter> status: Charging
CPU: Topology: Dual Core model: Intel Core i5-3320M bits: 64 type: MT MCP arch: Ivy Bridge
rev: 9 L2 cache: 3072 KiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20743
Speed: 1429 MHz min/max: 1200/3300 MHz Core speeds (MHz): 1: 1196 2: 1196 3: 1196 4: 1197
Graphics: Device-1: Intel 3rd Gen Core processor Graphics vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:0166
Device-2: Microdia type: USB driver: uvcvideo bus ID: 1-1.5:3 chip ID: 0c45:6449
Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: intel
unloaded: modesetting alternate: fbdev,vesa resolution: 1366x768~60Hz s-dpi: 96
OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 20.1.6
compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20
Sound Server: ALSA v: k5.8.5-2-MANJARO
Network: Device-1: Intel Centrino Ultimate-N 6300 driver: iwlwifi v: kernel port: f040
bus ID: 02:00.0 chip ID: 8086:422b
Device-2: Broadcom and subsidiaries NetXtreme BCM5761 Gigabit Ethernet PCIe vendor: Dell
driver: tg3 v: kernel port: f040 bus ID: 0c:00.0 chip ID: 14e4:1681
IF: enp12s0 state: down mac: <filter>
Drives: Local Storage: total: 465.76 GiB used: 201.88 GiB (43.3%)
ID-1: /dev/sda vendor: Western Digital model: WD5000LPLX-75ZNTT0 size: 465.76 GiB
speed: 6.0 Gb/s serial: <filter>
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0
bus ID: 00:1f.2 chip ID: 8086.282a
Partition: ID-1: / size: 457.45 GiB used: 201.88 GiB (44.1%) fs: ext4 dev: /dev/sda1
Swap: ID-1: swap-1 type: file size: 256.0 MiB used: 0 KiB (0.0%) priority: 50
file: /var/lib/systemd-swap/swapfc/1
Unmounted: Message: No unmounted partitions found.
Sensors: System Temperatures: cpu: 56.0 C mobo: 44.0 C sodimm: 44.0 C
Fan Speeds (RPM): cpu: 2806
Info: Processes: 233 Uptime: 21m Memory: 3.73 GiB used: 1.39 GiB (37.4%) Init: systemd v: 246
Compilers: gcc: 10.2.0 clang: 10.0.1 Packages: 1421 pacman: 1401 flatpak: 4 snap: 16
Shell: Bash v: 5.0.18 running in: konsole inxi: 3.1.05
dmesg
sudo dmesg -l emerg,alert,crit,err,warn
[ 0.101900] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[ 0.101900] #3
[ 0.103996] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 2.080213] i8042: Warning: Keylock active
[ 2.138774] mmc0: Internal clock never stabilised.
[ 2.138775] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 2.138783] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x0000c001
[ 2.138791] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 2.138798] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 2.138804] mmc0: sdhci: Present: 0x01f70000 | Host ctl: 0x00000000
[ 2.138812] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 2.138819] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00001003
[ 2.138826] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 2.138834] mmc0: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[ 2.138841] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 2.138848] mmc0: sdhci: Caps: 0x21e608b2 | Caps_1: 0x00002077
[ 2.138856] mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000064
[ 2.138863] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 2.138871] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 2.138875] mmc0: sdhci: Host ctl2: 0x00000000
[ 2.138875] mmc0: sdhci: ============================================
[ 2.158898] mmc0: Internal clock never stabilised.
[ 2.158899] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 2.158906] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x0000c001
[ 2.158914] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 2.158921] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 2.158928] mmc0: sdhci: Present: 0x01f70000 | Host ctl: 0x00000000
[ 2.158935] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 2.158942] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00001003
[ 2.158950] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 2.158956] mmc0: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[ 2.158964] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 2.158970] mmc0: sdhci: Caps: 0x21e608b2 | Caps_1: 0x00002077
[ 2.158978] mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000064
[ 2.158985] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 2.158992] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 2.158995] mmc0: sdhci: Host ctl2: 0x00000000
[ 2.158996] mmc0: sdhci: ============================================
[ 2.209475] mmc0: Internal clock never stabilised.
[ 2.209476] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 2.209484] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x0000c001
[ 2.209491] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 2.209498] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 2.209514] mmc0: sdhci: Present: 0x01f70000 | Host ctl: 0x00000000
[ 2.209521] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 2.209528] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00001003
[ 2.209534] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 2.209542] mmc0: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[ 2.209549] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 2.209555] mmc0: sdhci: Caps: 0x21e608b2 | Caps_1: 0x00002077
[ 2.209563] mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000064
[ 2.209570] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 2.209577] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 2.209581] mmc0: sdhci: Host ctl2: 0x00000000
[ 2.209581] mmc0: sdhci: ============================================
[ 2.229600] mmc0: Internal clock never stabilised.
[ 2.229601] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 2.229609] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x0000c001
[ 2.229617] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 2.229624] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 2.229631] mmc0: sdhci: Present: 0x01f70000 | Host ctl: 0x00000000
[ 2.229638] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 2.229645] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00001003
[ 2.229653] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 2.229660] mmc0: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[ 2.229667] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 2.229675] mmc0: sdhci: Caps: 0x21e608b2 | Caps_1: 0x00002077
[ 2.229682] mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000064
[ 2.229690] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 2.229697] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 2.229701] mmc0: sdhci: Host ctl2: 0x00000000
[ 2.229702] mmc0: sdhci: ============================================
[ 2.282874] mmc0: Internal clock never stabilised.
[ 2.282876] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 2.282885] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x0000c001
[ 2.282892] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 2.282900] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 2.282907] mmc0: sdhci: Present: 0x01f70000 | Host ctl: 0x00000000
[ 2.282915] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 2.282923] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00002003
[ 2.282930] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 2.282938] mmc0: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[ 2.282945] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 2.282953] mmc0: sdhci: Caps: 0x21e608b2 | Caps_1: 0x00002077
[ 2.282961] mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000064
[ 2.282968] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 2.282976] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 2.282980] mmc0: sdhci: Host ctl2: 0x00000000
[ 2.282981] mmc0: sdhci: ============================================
[ 2.303010] mmc0: Internal clock never stabilised.
[ 2.303012] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 2.303019] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x0000c001
[ 2.303027] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 2.303034] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 2.303042] mmc0: sdhci: Present: 0x01f70000 | Host ctl: 0x00000000
[ 2.303049] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 2.303056] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00002003
[ 2.303064] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 2.303071] mmc0: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[ 2.303079] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 2.303086] mmc0: sdhci: Caps: 0x21e608b2 | Caps_1: 0x00002077
[ 2.303093] mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000064
[ 2.303101] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 2.303107] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 2.303111] mmc0: sdhci: Host ctl2: 0x00000000
[ 2.303112] mmc0: sdhci: ============================================
[ 2.357862] mmc0: Internal clock never stabilised.
[ 2.357863] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 2.357872] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x0000c001
[ 2.357880] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 2.357887] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 2.357895] mmc0: sdhci: Present: 0x01f70000 | Host ctl: 0x00000000
[ 2.357903] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 2.357911] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00004003
[ 2.357918] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 2.357926] mmc0: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[ 2.357934] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 2.357941] mmc0: sdhci: Caps: 0x21e608b2 | Caps_1: 0x00002077
[ 2.357949] mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000064
[ 2.357957] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 2.357964] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 2.357969] mmc0: sdhci: Host ctl2: 0x00000000
[ 2.357970] mmc0: sdhci: ============================================
[ 2.377996] mmc0: Internal clock never stabilised.
[ 2.377997] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 2.378005] mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x0000c001
[ 2.378012] mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
[ 2.378019] mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
[ 2.378026] mmc0: sdhci: Present: 0x01f70000 | Host ctl: 0x00000000
[ 2.378034] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
[ 2.378041] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00004003
[ 2.378049] mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
[ 2.378056] mmc0: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
[ 2.378064] mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
[ 2.378071] mmc0: sdhci: Caps: 0x21e608b2 | Caps_1: 0x00002077
[ 2.378079] mmc0: sdhci: Cmd: 0x00000000 | Max curr: 0x00000064
[ 2.378086] mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
[ 2.378094] mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
[ 2.378098] mmc0: sdhci: Host ctl2: 0x00000000
[ 2.378098] mmc0: sdhci: ============================================
[ 14.414105] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20200528/utaddress-204)
[ 14.414116] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200528/utaddress-204)
[ 14.414121] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200528/utaddress-204)
[ 14.414127] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20200528/utaddress-204)
[ 14.414131] lpc_ich: Resource conflict(s) found affecting gpio_ich
[ 14.550442] i801_smbus 0000:00:1f.3: Accelerometer lis3lv02d is present on SMBus but its address is unknown, skipping registration
[ 14.734521] wmi_bus wmi_bus-PNP0C14:00: WQBC data block query control method not found
[ 14.981246] dell-smbios PNP0C14:00-A80593CE-A997-11DA-B012-B622A1EF5492: WMI SMBIOS userspace interface not supported(0), try upgrading to a newer BIOS
[ 15.203863] iwlwifi 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 15.207444] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-6000-6.ucode failed with error -2
[ 15.207478] iwlwifi 0000:02:00.0: Direct firmware load for iwlwifi-6000-5.ucode failed with error -2
[ 15.310561] iwlwifi 0000:02:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
[ 16.501208] kauditd_printk_skb: 35 callbacks suppressed
[ 20.575451] uvcvideo 1-1.5:1.0: Entity type for entity Extension 4 was not initialized!
[ 20.575454] uvcvideo 1-1.5:1.0: Entity type for entity Extension 3 was not initialized!
[ 20.575455] uvcvideo 1-1.5:1.0: Entity type for entity Processing 2 was not initialized!
[ 20.575457] uvcvideo 1-1.5:1.0: Entity type for entity Camera 1 was not initialized!
[ 23.969418] kauditd_printk_skb: 3 callbacks suppressed
[ 29.223504] kauditd_printk_skb: 4 callbacks suppressed
[ 36.007436] kauditd_printk_skb: 4 callbacks suppressed
[ 51.492458] kauditd_printk_skb: 6 callbacks suppressed
[ 844.872084] kauditd_printk_skb: 6 callbacks suppressed
