I installed the McMojave theme, light and dark versions, and now I can’t get rid of the Windows style taskbar’s theme. I’ve tried switching to new themes and deleting config files:
No matter what I do, the taskbar remains where it is, same colour, same size, and with the Apple logo instead of the Manjaro logo. How do I get rid of this? I’m happy to reset my KDE desktop to factory settings, but I don’t want to completely reinstall Manjaro
You did not do everything yet. Go to Settings > Appearance > Plasma Style and select something else then apply. Uninstall McMojave if you do not want it. Log out and back in.
Stop using sudo in your home directory !
You might have to clear the cache folder instead. rm -r ~/.cache/*
Thank you!! Had some trouble removing McMojave from Plasma Style, was saying that it wasn’t installed, so I reinstalled it and then removed it again and it worked. Strange behaviour but there we go. Thank you again!
