Hello, So, Everytime I startup my laptop, the following message shows for a few seconds and then I see the login screen as usual. The message doesn’t cause any problems except for time delay of approximately 10-15 seconds on EVERY STARTUP. What does it say or is there any way to fix it?
I run Manjaro Linux on my Dell Inspiron laptop as the ONLY OS on the machine.
Machine checks are a hardware problem, not a software problem. They are often the result of overclocking or overheating. In some cases, the CPU will shut itself off once passing a thermal limit to avoid permanent damage. But they can also be caused by bus errors introduced by other failing components, like memory or I/O devices. Possible causes include:
Poor CPU cooling due to a CPU heatsink and fan that’s clogged with dust or has come loose.
Overclocking beyond the highest clock rate at which the CPU is still reliable.
Failing motherboard.
Failing processor.
Failing memory.
Failing I/O controllers, on either the motherboard or separate cards.
Failing I/O devices.
Inadequate or failing power supply.
Poor general case cooling due to inadequate or clogged case fans or filters.
As stated, it doesn’t cause any problems with any normal usage. So, why does it even show, that too for only few seconds.
Also, I have 64bit i5 processor, not pentium as stated in the artice.
Considering that overheating is often a cause ─ albeit not the only possible cause ─ you might want to clean out the fans. It may also be faulty memory ─ such faults don’t always show up when the module is new.
If it’s a faulty memory module, you could run memtest86+ and let it run for about 24 hours. Then you’ll know which module it is.
