mc can be fully controlled via keyboard
in xorg and wayland, when run in a terminal, the mouse can also be used
But somehow I don’t think that this is what you mean.
The term “mouse actions” in the context of KDE probably means something I don’t even know what it is.
In TTY, the mouse is only available when you also configure gpm and start and have the service running.
Thank you for reply!
I have checked the other (older) system where I can click the MC menu buttons via mouse, there is no gpm.service enabled, but it works
sudo systemctl status gpm.service
○ gpm.service - Virtual console mouse server
Loaded: loaded (/usr/lib/systemd/system/gpm.service; disabled; preset: disabled)
Active: inactive (dead)
the new installation does show a mouse pointer in MC, also after activating the gpm.service, mc can only used via keyboard …
edit
xcursor-vanilla-dmz is in use
tail -n 500 /var/log/Xorg.0.log | grep -e WW -e EE
[ 7.523] Current Operating System: Linux hounddog 5.15.74-3-MANJARO #1 SMP PREEMPT Sat Oct 15 13:39:11 UTC 2022 x86_64
[ 8.473] (II) Initializing extension MIT-SCREEN-SAVER
this is only needed/intended for when you are in a TTY → not in a graphical session
I have no idea why the mouse would not work when mc is run in a terminal.
You could try a different terminal instead of Konsole - but I have used Konsole and it worked as in every other terminal app.
Some (mis)configuration, perhaps - no idea. I do not have KDE at the moment. But mc has always worked in any DE.
I very rarely use the mouse in mc, so I might not have noticed whether it was working or not.
