Maximum resolution and frequency not detected on an ultrawide display
Hello everyone,
I’m having a problem with my Philips Evnia 49M2C8900 monitor, which is stuck at a resolution of 3840x1080 60Hz.
The monitor can handle 5120x1440 240Hz. I have an AMD 7900XTX, which also handles it very well, logically.
It is detected perfectly in Windows 11 (2 cables tested).
I also tested a Manjaro and Ubuntu livecd version to confirm that I didn’t have a weird configuration on my OS.
Could you give me a hand to solve this problem?
  Kernel: 6.16.0-5-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    clocksource: kvm-clock avail: tsc,acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.16-x86_64
    root=UUID=0a8683e3-b234-4baf-8a02-d072ef85fbd2 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.17.0
    wm: kwin_wayland with: Docker vt: 1 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Kvm System: QEMU product: Standard PC (Q35 + ICH9, 2009) v: pc-q35-9.1
    serial: <superuser required> Chassis: type: 1 v: pc-q35-9.1
  Mobo: N/A model: N/A serial: N/A uuid: <superuser required> UEFI: EDK II
    v: N/A date: 02/02/2022
  System RAM: total: 60 GiB available: 58.85 GiB used: 5.93 GiB (10.1%)
  Array-1: capacity: 60 GiB slots: 1 modules: 1 EC: Multi-bit ECC
    max-module-size: 60 GiB note: est.
  Device-1: DIMM 0 type: RAM detail: N/A size: 60 GiB speed: N/A volts: N/A
    width: N/A manufacturer: Qemu part-no: N/A serial: N/A
  Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
    desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3394 min/max: N/A cores: 1: 3394 2: 3394 3: 3394 4: 3394
    5: 3394 6: 3394 7: 3394 8: 3394 9: 3394 10: 3394 11: 3394 12: 3394
    bogomips: 81446
  Flags: 3dnowprefetch abm adx aes apic arat arch_capabilities avx avx2
    bmi1 bmi2 clflush clflushopt clwb clzero cmov cmp_legacy cpuid cr8_legacy
    cx16 cx8 de erms extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt ht hypervisor ibpb ibrs invpcid lahf_lm lbrv lm mca mce
    misalignsse mmx mmxext movbe msr mtrr nopl npt nrip_save nx ospke osvw
    overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    pfthreshold pge pku pni popcnt pse pse36 rdpid rdrand rdseed rdtscp
    rep_good sep sha_ni smap smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3
    stibp succor svm syscall topoext tsc tsc_adjust tsc_deadline_timer
    tsc_known_freq tsc_scale umip v_vmsave_vmload vaes vgif vmcb_clean vme
    vmmcall vpclmulqdq wbnoinvd x2apic xgetbv1 xsave xsavec xsaveerptr
    xsaveopt xsaves xtopology
    affected
  Type: tsa status: Vulnerable: No microcode
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
    XTX/7900 GRE/7900M] vendor: XFX RX-79XMERCB9 driver: amdgpu v: kernel
    arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
    gen: 4 speed: 16 GT/s lanes: 16 ports: active: HDMI-A-1 empty: DP-1,
    DP-2, DP-3, Writeback-1 bus-ID: 04:00.0 chip-ID: 1002:744c class-ID: 0300
    temp: 44.0 C
  Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:22
    chip-ID: 046d:082d class-ID: 0102 serial: <filter>
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
  Monitor-1: HDMI-A-1 model: Philips 49M2C8900 serial: <filter> built: 2023
    res: mode: 3840x1080 hz: 60 scale: 100% (1) dpi: 81 gamma: 1.2 chroma: red:
    x: 0.686 y: 0.302 green: x: 0.235 y: 0.729 blue: x: 0.145 y: 0.047 white:
    x: 0.314 y: 0.329 size: 1197x339mm (47.13x13.35") diag: 1244mm (49")
    modes: 3840x1080, 3840x2160, 2560x1440, 1920x1080, 1680x1050, 1280x1024,
    1440x900, 1280x800, 1280x720, 1024x768, 832x624, 800x600, 720x576,
    720x480, 640x480, 720x400
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 96 2: parse_edid:
    unhandled CEA mode 97 3: parse_edid: unhandled CEA mode 117 4: parse_edid:
    unhandled CEA mode 118
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.7-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XTX (radeonsi
    navi31 LLVM 20.1.8 DRM 3.64 6.16.0-5-MANJARO) device-ID: 1002:744c
    memory: 23.44 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.321 layers: 8 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 25.1.7-arch1.1
    device-ID: 1002:744c surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: amdgpu_top
    wl: wayland-info,wlr-randr x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    bus-ID: 05:00.0 chip-ID: 1002:ab30 class-ID: 0403
  Device-2: Kingston HyperX Cloud Flight S
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-3:20 chip-ID: 0951:16ea class-ID: 0300
    serial: <filter>
  Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.16.0-5-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
  Device-1: Red Hat Virtio 1.0 network driver: virtio-pci v: 1 pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 01:00.0 chip-ID: 1af4:1041
    class-ID: 0200
  IF-ID-1: enp1s0 state: up speed: -1 duplex: unknown mac: <filter>
  Local Storage: total: 2 TiB used: 1.34 TiB (67.0%)
  ID-1: /dev/vda maj-min: 254:0 model: N/A size: 2 TiB block-size:
    physical: 512 B logical: 512 B speed: <unknown> tech: N/A serial: N/A
    scheme: GPT
  ID-1: / raw-size: 2 TiB size: 1.97 TiB (98.38%) used: 1.34 TiB (68.1%)
    fs: ext4 dev: /dev/vda2 maj-min: 254:2 label: N/A
    uuid: 0a8683e3-b234-4baf-8a02-d072ef85fbd2
    used: 320 KiB (0.1%) fs: vfat dev: /dev/vda1 maj-min: 254:1 label: N/A
    uuid: 9E4B-CA99
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 15 rev: 2.0
  Device-1: 1-1:2 info: ROCCAT Kone XTD Optical Mouse type: mouse,keyboard
    lanes: 1 mode: 1.1 power: 200mA chip-ID: 1e7d:2e23 class-ID: 0300
  Device-2: 1-2:19 info: Turtle Beach Kone II type: mouse,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 10f5:5008 class-ID: 0300
  Device-3: 1-3:20 info: Kingston HyperX Cloud Flight S type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
    chip-ID: 0951:16ea class-ID: 0300 serial: <filter>
  Device-4: 1-4:21 info: Google Nexus/Pixel Device (charging + debug)
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.1
    chip-ID: 18d1:4ee7 class-ID: 0000 serial: <filter>
  Device-5: 1-5:22 info: Logitech HD Pro Webcam C920 type: video,audio
  Device-6: 1-6:23 info: ROCCAT Vulcan Pro type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1e7d:30f7 class-ID: 0300
  Hub-2: 2-0:1 info: super-speed hub ports: 15 rev: 3.0
  System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 51.0 C mem: 60.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 598
  Packages: pm: pacman pkgs: 1834 libs: 455 tools: pamac pm: flatpak pkgs: 0
    1: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    2: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    3: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    4: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    6: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    7: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    8: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 334
  1: cpu: 23.2% command: firefox pid: 3664 mem: 839.4 MiB (1.3%)
  2: cpu: 5.7% command: kwin_wayland pid: 883 mem: 420.7 MiB (0.6%)
  3: cpu: 5.0% command: firefox pid: 3881 mem: 491.0 MiB (0.8%)
  4: cpu: 4.8% command: firefox pid: 3969 mem: 461.5 MiB (0.7%)
  5: cpu: 4.6% command: firefox pid: 6297 mem: 335.1 MiB (0.5%)
  Memory top: 5 of 334
  1: mem: 839.4 MiB (1.3%) command: firefox pid: 3664 cpu: 23.2%
  2: mem: 598.0 MiB (0.9%) command: firefox pid: 4225 cpu: 2.8%
  3: mem: 553.6 MiB (0.9%) command: Telegram pid: 5828 cpu: 0.8%
  4: mem: 540.8 MiB (0.8%) command: plasmashell pid: 1139 cpu: 0.7%
  5: mem: 491.0 MiB (0.8%) command: firefox pid: 3881 cpu: 5.0%
  Processes: 334 Power: uptime: 15m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 23.51 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 20.1.8 gcc: 15.1.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.3.3 running-in: konsole inxi: 3.3.38
kscreen-doctor --outputs         ✔
Output: 1 HDMI-A-1
        enabled
        connected
        priority 1
        HDMI
        Modes:  1:3840x1080@60*!  2:3840x2160@120  3:3840x2160@120  4:3840x2160@100  5:3840x2160@60  6:3840x2160@60  7:3840x2160@50  8:2560x1440@120  9:2560x1440@60  10:1920x1080@120  11:1920x1080@120  12:1920x1080@60  13:1920x1080@60  14:1920x1080@60  15:1920x1080@50  16:1680x1050@60  17:1280x1024@75  18:1280x1024@60  19:1440x900@60  20:1280x800@60  21:1280x720@60  22:1280x720@60  23:1280x720@50  24:1024x768@120  25:1024x768@100  26:1024x768@75  27:1024x768@70  28:1024x768@60  29:832x624@75  30:800x600@120  31:800x600@100  32:800x600@75  33:800x600@72  34:800x600@60  35:800x600@56  36:720x576@50  37:720x576@50  38:720x480@60  39:720x480@60  40:720x480@60  41:720x480@60  42:640x480@120  43:640x480@100  44:640x480@75  45:640x480@73  46:640x480@67  47:640x480@60  48:640x480@60  49:640x480@60  50:720x400@70  51:1600x1200@60  52:1280x1024@60  53:1024x768@60  54:2560x1600@60  55:1920x1200@60  56:1280x800@60  57:3840x2160@60  58:3200x1800@60  59:2880x1620@60  60:2560x1440@60  61:1920x1080@60  62:1600x900@60  63:1368x768@60  64:1280x720@60
        Geometry: 0,0 3840x1080
        Scale: 1
        Rotation: 1
        Overscan: 0
        Vrr: Never
        RgbRange: Automatic
        HDR: disabled
        Wide Color Gamut: disabled
        ICC profile: none
        Color profile source: sRGB
        Color power preference: prefer efficiency and performance
        Brightness control: supported, set to 100% and dimming to 100%
Just stumbled over this:
https://catwithcode.moe/Blog/2025.06.14_Philips_OLED_49/Philips_OLED_49.html
drivers are not the same between linux and micro$oft
trouble is here on hdmi 2.1
prefers if possible DP
