Running any of the following apps results in either the other apps crashing or blackscreening. VS Code, Brave Browser, obsidian, discord.
Output of lsof -U +c 15 | cut -f1 -d' ' | sort | uniq -c | sort -rn | head -3 :
1180 DesktopVideoUpd
256 Xwayland
250 ksmserver
inxi output:
Kernel: 6.1.71-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=f48d994e-c928-4379-8442-a607bddaabd8 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.12 info: latte-dock
wm: kwin_wayland dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: ASUS TUF Gaming A15 FA506IH_FA506IH
v: 1.0 serial: <filter>
Mobo: ASUSTeK model: FA506IH v: 1.0 serial: <filter>
UEFI: American Megatrends v: FA506IH.316 date: 03/12/2021
ID-1: BAT1 charge: 32.8 Wh (100.0%) condition: 32.8/48.1 Wh (68.3%)
volts: 12.3 min: 11.7 model: ASUS A32-K55 type: Li-ion serial: N/A
status: full
System RAM: total: 16 GiB available: 15.05 GiB used: 9.03 GiB (60.0%)
Device-1: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2 max: 1.2 width (bits):
data: 64 total: 64 manufacturer: Samsung part-no: M471A1K43DB1-CWE
serial: <filter>
Device-2: DIMM 0 type: DDR4 detail: synchronous unbuffered (unregistered)
serial: <filter>
Info: model: AMD Ryzen 5 4600H with Radeon Graphics socket: FP6 bits: 64
type: MT MCP arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600104
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1666 high: 3000 min/max: 1400/3000 boost: enabled
base/boost: 3000/4000 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 3000 12: 3000
bogomips: 71896
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spec_rstack_overflow mitigation: safe RET
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 545.29.06 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-11; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f99 class-ID: 0300
Device-2: AMD Renoir [Radeon RX Vega 6 ] vendor: ASUSTeK driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 05:00.0 chip-ID: 1002:1636 class-ID: 0300 temp: 54.0 C
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:2 chip-ID: 13d3:56a2
Display: server: X.Org v: 23.2.3 with: Xwayland v: 23.2.3
compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.00x11.26")
s-diag: 583mm (22.95")
Monitor-1: eDP-1 model: Najing CEC Panda 0x002d built: 2018 res: 1920x1080
hz: 60 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48") diag: 395mm (15.5")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm: drv: radeonsi
surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.3.3-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
LLVM 16.0.6 DRM 3.49 6.1.71-1-MANJARO) device-ID: 1002:1636 memory: 500 MiB
unified: no
API: Vulkan v: 1.3.274 layers: 2 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: nvidia v: 545.29.06
device-ID: 10de:1f99 surfaces: xcb,xlib device: 1 type: integrated-gpu
name: AMD Radeon Graphics (RADV RENOIR) driver: mesa radv
v: 23.3.3-manjaro1.1 device-ID: 1002:1636 surfaces: xcb,xlib
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
bus-ID: 05:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x,
snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir,
snd_sof_amd_rembrandt pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.1.71-1-MANJARO status: kernel-api with: aoss
Server-2: JACK v: 1.9.22 status: off tools: jack_control,qjackctl
Server-3: PipeWire v: 1.0.0 status: n/a (root, process) with:
1: pipewire-pulse status: active 2: pipewire-media-session status: active
3: pipewire-alsa type: plugin tools: pactl,pw-cat,pw-cli
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Lite-On driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:c822
class-ID: 0280
Device-1: Lite-On Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 04ca:4005
Local Storage: total: 942.7 GiB used: 185.03 GiB (19.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2210 MTFDHBA512QFD
lanes: 4 tech: SSD serial: <filter> fw-rev: P6MA001 temp: 46.9 C
scheme: GPT
SMART: yes health: PASSED on: 371d 1h cycles: 2,756
read-units: 66,066,234 [33.8 TB] written-units: 52,910,620 [27.0 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
family: Micron Client SSDs size: 465.76 GiB block-size: physical: 512 B
logical: 512 B type: USB rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: M3CR043
temp: 32 C scheme: MBR
SMART: yes state: enabled health: PASSED on: 66d 3h cycles: 651
written: 5.06 TiB
ID-1: / raw-size: 273.44 GiB size: 268.08 GiB (98.04%)
used: 157.94 GiB (58.9%) fs: ext4 block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5 label: N/A uuid: f48d994e-c928-4379-8442-a607bddaabd8
ID-2: /run/media/hydra/ExternalWin raw-size: 97.66 GiB
size: 97.65 GiB (100.00%) used: 26.1 MiB (0.0%) fs: exfat block-size: 512 B
dev: /dev/sda2 maj-min: 8:2 label: ExternalWin uuid: 67FE-BC8E
ID-3: /srv/mmedia raw-size: 368.1 GiB size: 361.26 GiB (98.14%)
used: 27.06 GiB (7.5%) fs: ext4 block-size: 4096 B dev: /dev/sda1
maj-min: 8:1 label: External-Linux
uuid: 1bcf4134-86d3-4721-9900-4bd126368ed5
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
uuid: E465-6F98
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: N/A label: N/A
uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 202.73 GiB fs: ntfs label: N/A
uuid: 648069A180697B06
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 674 MiB fs: ntfs label: N/A
uuid: B69804FD9804BE3D
Device-1: 1-4:2 info: IMC Networks USB2.0 HD UVC WebCam type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Device-1: 3-1:2 info: Lite-On Bluetooth Radio type: bluetooth driver: btusb
interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 500mA chip-ID: 04ca:4005 class-ID: e001 serial: <filter>
Device-1: 4-2:2 info: ASMedia ASM1051E SATA 6Gb/s bridge ASM1053E ASM1153
3Gb/s ASM1153E bridge type: mass storage driver: uas interfaces: 1 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 174c:55aa
class-ID: 0806 serial: <filter>
System Temperatures: cpu: 61.0 C mobo: N/A gpu: amdgpu temp: 54.0 C
Fan Speeds (rpm): cpu: 3000
Processes: 603 Uptime: 7m wakeups: 0 Init: systemd v: 255 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6 Packages: 2401
pm: pacman pkgs: 2344 libs: 489 tools: octopi,pamac,yay pm: flatpak pkgs: 57
Shell: Sudo (sudo) v: 1.9.15p5 default: Bash v: 5.2.21 running-in: yakuake
inxi: 3.3.31
I have 2 graphics drivers installed: video-hybrid-amd-nvidia-prime and nvidia-linux
UPDATE: Killing a few of the /usr/bin/DesktopVideoUpdater processes allowed me to run the apps(Except obsidian). But why are there so many of these processes?
