This issue seems to not occur all the time, but is annoying nonetheless. I connect my Tuxedo Sirius 16 Gen 1 from its HDMI port to one of my two monitors via HDMI. It displays just fine, but if I maximise any window: nautilus, firefox, spotify etc then my monitor randomly disconnects. The system attempts to reconnect my monitor and when it does succeed the monitor then disconnects again, thus causing an endless cycle with no stability. Only when I move the full screen window or unmaximise it does the issue go away. The second monitor is connected via DisplayPort and does not exhibit any such issue. I am using GNOME (latest on stable) as my DE. Here’s my system info:
Kernel: 6.7.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.7-x86_64
root=UUID=6262c975-d7aa-4b9f-83f5-d9dd532daaa3 rw quiet
cryptdevice=UUID=fd7f02da-e318-4549-be1d-898aee3b8669:luks-fd7f02da-e318-4549-be1d-898aee3b8669
root=/dev/mapper/luks-fd7f02da-e318-4549-be1d-898aee3b8669 splash
resume=/dev/mapper/luks-e9c9afb0-86e7-48d7-9507-d1b1608086ab
udev.log_priority=3
Desktop: GNOME v: 45.4 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 45.0.1 Distro: Manjaro
base: Arch Linux
Type: Laptop System: TUXEDO product: TUXEDO Sirius 16 Gen1 v: N/A
Mobo: NB04 model: APX958 serial: <superuser required> part-nu: SIRIUS1601
uuid: <superuser required> UEFI: American Megatrends LLC. v: 1.00A00_20240108
date: 01/08/2024
ID-1: BAT0 charge: 80.1 Wh (100.0%) condition: 80.1/80.1 Wh (100.0%)
volts: 17.4 min: N/A model: AMD Battery Li-ion Real Battery type: Li-ion
serial: <filter> status: charging
System RAM: total: 64 GiB available: 62.03 GiB used: 6.92 GiB (11.2%)
Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 32 GiB speed: 5600 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMS5X32G2A56C48A2 serial: N/A
Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 7840HS w/ Radeon 780M Graphics bits: 64 type: MT MCP
arch: Zen 4 gen: 5 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
family: 0x19 (25) model-id: 0x74 (116) stepping: 1 microcode: 0xA704103
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB desc: 8x1024 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1912 high: 2367
min/max: 400/5293:5137:5449:6080:5764:5924:5608 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 2337 2: 2178 3: 1330
4: 2251 5: 1502 6: 1928 7: 2367 8: 2274 9: 2281 10: 2306 11: 400 12: 2315
13: 400 14: 2156 15: 2249 16: 2324 bogomips: 121432
Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avx avx2
avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fxsr fxsr_opt gfni
ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv lm
mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip user_shstk v_spec_ctrl v_vmsave_vmload vaes
vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS, IBPB: conditional,
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Navi 33 [Radeon RX 7700S/7600/7600S/7600M XT/PRO W7600]
vendor: Emdoor Digital driver: amdgpu v: kernel arch: RDNA-3 code: Navi-33
built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 8 ports: active: HDMI-A-1
empty: DP-1,eDP-1 bus-ID: 03:00.0 chip-ID: 1002:7480 class-ID: 0300
Device-2: AMD Phoenix1 vendor: Emdoor Digital driver: amdgpu v: kernel
arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm) built: 2023+ pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-3,eDP-2 empty: DP-2, DP-4,
DP-5, DP-6, DP-7, DP-8, DP-9 bus-ID: 68:00.0 chip-ID: 1002:15bf
class-ID: 0300 temp: 34.0 C
Device-3: Microdia Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0c45:6362
Display: wayland server: X.org v: 1.21.1.11 with: Xwayland v: 23.2.4
compositors: 1: gnome-shell 2: Tabby driver: gpu: amdgpu display-ID: 0
Monitor-1: DP-3 model: VA27D serial: <filter> built: 2022 res: 1920x1080
dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23") diag: 686mm (27")
ratio: 16:9 modes: max: 1920x1080 min: 720x400
Monitor-2: HDMI-A-1 model: Dell S2721DGF serial: <filter> built: 2021
res: 2560x1440 dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23")
diag: 685mm (27") ratio: 16:9 modes: max: 2560x1440 min: 720x400
Monitor-3: eDP-2 model: BOE Display 0x09e5 built: 2020 res: 2560x1440
dpi: 183 gamma: 1.2 size: 355x200mm (13.98x7.87") diag: 407mm (16")
ratio: 16:9 modes: max: 2560x1440 min: 640x480
device: 1 drv: radeonsi device: 2 drv: swrast surfaceless: drv: radeonsi
wayland: drv: radeonsi x11: drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
gfx1103_r1 LLVM 16.0.6 DRM 3.57 6.7.7-1-MANJARO) device-ID: 1002:15bf
memory: 500 MiB unified: no display-ID: :0.0
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu name: AMD
Radeon RX 7600M XT (RADV NAVI33) driver: mesa radv v: 24.0.2-manjaro1.1
device-ID: 1002:7480 surfaces: xcb,xlib,wayland device: 1
type: integrated-gpu name: AMD Radeon Graphics (RADV GFX1103_R1)
driver: mesa radv v: 24.0.2-manjaro1.1 device-ID: 1002:15bf
Device-1: AMD Navi 31 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 8 bus-ID: 03:00.1 chip-ID: 1002:ab30
class-ID: 0403
Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 68:00.1
chip-ID: 1002:1640 class-ID: 0403
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Emdoor Digital
driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x, snd_rn_pci_acp3x,
snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 68:00.5
chip-ID: 1022:15e2 class-ID: 0480
Device-4: AMD Family 17h/19h HD Audio vendor: Emdoor Digital
bus-ID: 68:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.7.7-1-MANJARO status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 14c3:0608
class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
Device-3: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1.3:4
chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
IF: enp104s0f3u1u3 state: down mac: <filter>
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:6 chip-ID: 0e8d:0608
Device-1: luks-fd7f02da-e318-4549-be1d-898aee3b8669 maj-min: 254:0
type: LUKS dm: dm-0 size: 1.81 TiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 1.81 TiB
Device-2: luks-e9c9afb0-86e7-48d7-9507-d1b1608086ab maj-min: 254:1
type: LUKS dm: dm-1 size: 8.8 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 8.8 GiB
Local Storage: total: 1.82 TiB used: 46.93 GiB (2.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 0B2QJXG7 temp: 40.9 C
scheme: GPT
ID-1: / raw-size: 1.81 TiB size: 1.78 TiB (98.37%) used: 46.93 GiB (2.6%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-fd7f02da-e318-4549-be1d-898aee3b8669 label: N/A
uuid: 6262c975-d7aa-4b9f-83f5-d9dd532daaa3
used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 68DC-C0CA
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-e9c9afb0-86e7-48d7-9507-d1b1608086ab label: swap
uuid: 67b80173-2edf-4956-b84c-b767b1fef856
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 5 rev: 2.0
Hub-2: 1-1:2 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
Hub-3: 1-1.4:5 info: System76 USB4216 Smart Hub ports: 5 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 3384:4216
Device-1: 1-1.4.2:9 info: SHARKOON GmbH 2.4GHz Wireless rechargeable
vertical mouse [More&Better] type: mouse driver: hid-generic,usbhid
interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
Device-2: 1-1.4.4:10 info: Yubicom Yubikey 4/5 OTP+U2F+CCID
type: keyboard,HID,smart card driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
chip-ID: 1050:0407 class-ID: 0b00
Device-3: 1-1.4.5:8 info: System76 Launch Configurable Keyboard (launch_1)
type: keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 1.1
chip-ID: 3384:0001 class-ID: 0300
Device-4: 1-1.5:7 info: Anker Innovations USB-C Hub Device type: billboard
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 100mA chip-ID: 291a:8380 class-ID: 1100 serial: <filter>
Device-5: 1-3:3 info: Shenzhen Goodix USB2.0 MISC type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 100mA chip-ID: 27c6:60c2 class-ID: ef00 serial: <filter>
Device-6: 1-4:4 info: Integrated Express ITE Device type: keyboard
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:8910 class-ID: 0301
Device-7: 1-5:6 info: MediaTek Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 0e8d:0608 class-ID: e001 serial: <filter>
Hub-4: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-5: 2-1:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
Device-1: 2-1.2:3 info: Genesys Logic SD Card Reader and Writer
type: mass storage driver: usb-storage interfaces: 1 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 896mA
chip-ID: 05e3:0749 class-ID: 0806 serial: <filter>
Device-2: 2-1.3:4 info: Realtek RTL8153 Gigabit Ethernet Adapter
type: Network driver: r8152 interfaces: 1 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 288mA
Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 3-1:2 info: Microdia Integrated Camera type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 0c45:6362 class-ID: 0e02 serial: <filter>
Hub-7: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-8: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-9: 6-0:1 info: super-speed hub ports: 1 rev: 3.1
Hub-10: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-11: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 43.0 C mobo: N/A
Fan Speeds (rpm): N/A
GPU: device: amdgpu temp: 38.0 C mem: 40.0 C fan: 0 watts: 0.00
device: amdgpu temp: 39.0 C watts: 52.24
Processes: 432 Power: uptime: 6h 54m states: freeze,mem,disk suspend: s2idle
image: 24.79 GiB services: gsd-power,upowerd Init: systemd v: 255
Packages: 1046 pm: pacman pkgs: 1037 libs: 321 tools: gnome-software,pamac
pm: snap pkgs: 9 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: systeminfo
default: fish v: 3.7.0 running-in: tabby inxi: 3.3.33
Are we aware of any issues relating to HDMI → HDMI on AMD GPUs?
