Maxima, error on start up
On attempting to start wxmaxima (AUR package), I got an error.
So switched to command-line maxima but still the same error:
$ maxima
Condition of type: SIMPLE-TYPE-ERROR
In function <, the value of the second argument is
  NIL
which is not of the expected type REAL
No restarts available.
Top level in: #<process TOP-LEVEL 0x76610742af00>.
Although the Manjaro/Arch package is relatively recent:
$ pacman -Qi maxima
Version         : 5.47.0-21
Packager        : Antonio Rojas <arojas@archlinux.org>
Build Date      : Thu 10 Apr 2025 17:40:10 BST
Install Date    : Mon 05 May 2025 08:43:53 BST
The actual release of maxima is 2 or 3 years old and I’ve certainly used it since then, so my conjecture is a problem interfacing to a library somewhere.(ecl?). I do notice that though ecl is the correct version the build date is more recent than for maxima
Did you rebuild the AUR package?
The latest version of maxima in all Manjaro repos is 5.47.0-23
I don’t think the AUR package is relevant since the error occurs with maxima as well as wxmaxima.
I see that there is a new set of stable updates now available that hadn’t showed up on my panel this morning, include an update 5.47.0-22. Can’t apply those right now, but will do so and then check.
Indeed - I must have misread when I looked at:
Branch compare for Manjaro
https://manjaristas.org/branch_compare?q=maxima
Problem has gone away with the update.
