Hi,
can someone please suggest a possible solution to battery drain issue that I have when going in Suspend mode. It drains the battery to like 20% overnight from full.
I’ve switched to deep sleep, but even after suspending the fan is still on and laptop is hot.
I have a feeling it’s related to Nvidia, as I’ve googled around and there is a similar issue with laptops that have Intel/Nvidia videocards.
I ended up installing Optimus manager, but the issue kind of still there (I don’t really need nvidia, intel works fine for my needs).
Let me know if you’ve seen anything like that.
Windows didn’t have this problem.
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=7bce4791-9e31-40dd-bcb1-c013933a2c8f rw quiet apparmor=1
security=apparmor udev.log_priority=3 mem_sleep_default=deep
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HUAWEI product: MACH-WX9 v: M14
serial: <superuser required>
Mobo: HUAWEI model: MACH-WX9-PCB v: M14 serial: <superuser required>
UEFI: HUAWEI v: 1.28 date: 03/15/2019
ID-1: BAT0 charge: 39.1 Wh (80.1%) condition: 48.8/56.3 Wh (86.7%)
volts: 7.9 min: 7.6 model: DYNAPACK HB4593R1ECW type: Li-ion
serial: <filter> status: Discharging cycles: 218
RAM: total: 15.38 GiB used: 3.09 GiB (20.1%)
RAM Report:
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEA
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 400/4000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 32012
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm
lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx
pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36
pti pts rdrand rdseed rdtscp rep_good sdbg sep sgx smap smep ss ssbd sse
sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust
xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Huawei driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Huawei driver: nvidia
v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1d12
class-ID: 0302
Device-3: Cheng Uei Precision Industry (Foxlink) HD Camera type: USB
driver: uvcvideo bus-ID: 1-7:3 chip-ID: 05c8:03c0 class-ID: 0e02
Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3000x2000 s-dpi: 96 s-size: 793x529mm (31.2x20.8")
s-diag: 953mm (37.5")
Monitor-1: eDP-1 res: 3000x2000 hz: 60 dpi: 260
size: 293x196mm (11.5x7.7") diag: 353mm (13.9")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2)
v: 4.6 Mesa 21.3.2 direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Huawei
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
Device-1: Intel Wireless 8265 / 8275 vendor: Huawei driver: iwlwifi
v: kernel bus-ID: 3c:00.0 chip-ID: 8086:24fd class-ID: 0280
IF: wlp60s0 state: up mac: <filter>
bus-ID: 1-5:2 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 476.94 GiB used: 40.48 GiB (8.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: LITE-ON model: CA3-8D512
size: 476.94 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: C49640A
temp: 32.9 C scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
used: 40.48 GiB (8.6%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 7bce4791-9e31-40dd-bcb1-c013933a2c8f
label: NO_LABEL uuid: 6E9A-99A9
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-5:2 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-7:3 info: Cheng Uei Precision Industry (Foxlink) HD Camera
type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 05c8:03c0 class-ID: 0e02
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 41.0 C pch: 38.0 C mobo: N/A
Processes: 263 Uptime: 2h 39m wakeups: 265 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1180
pacman: 1177 lib: 331 flatpak: 0 snap: 3 Shell: Bash v: 5.1.12
running-in: xfce4-terminal inxi: 3.3.12
