The package of manjaro repos is the same that arch? is a question but i guess that yes.
Because in arch community repo say “orphan” in manteiners. https://archlinux.org/packages/community/x86_64/mate-utils/
Finding what provides mate-screenshot I found that is mate-utils, looking the Mate github repo and using pacman -Fy mate-screenshot, I found that is mate-utils.
The PKGBUILD does not have provides field.
Here example from Manjaro repo and a pkg builded by me (using PKGBUILD from arch), adding the provides field with the others binaries in the GitHub of mate.
Stock package:
LANG=C pacman -Si mate-utils
Repository : community
Version : 1.26.0-1
Description : Common MATE utilities for viewing disk usage, logs and fonts, taking screenshots, managing dictionaries and searching files
Architecture : x86_64
URL : http://mate-desktop.org
Licenses : GPL
Groups : mate-extra
Provides : None <-----!!!!
Depends On : mate-desktop gettext libcanberra libgtop libsm udisks2
Optional Deps : mate-panel: Look up words in dictionaries from the panel
Conflicts With : mate-utils-gtk3
Replaces : mate-utils-gtk3
Download Size : 6.65 MiB
Installed Size : 24.50 MiB
Packager : Antonio Rojas <arojas@archlinux.org>
Build Date : Sun Aug 8 16:23:34 2021
Validated By : MD5 Sum SHA-256 Sum Signature
Modified PKGBUILD recompiled package:
LANG=C pacman -Qi mate-utils
Version : 1.26.0-2
Licenses : GPL
Groups : mate-extra
Provides : mate-screenshot mate-dictionary logview baobab gsearchtool mate-disk-image-mounter
Optional Deps : mate-panel: Look up words in dictionaries from the panel [installed]
Required By : None
Optional For : None
Installed Size : 22.88 MiB
Packager : Unknown Packager
Build Date : Tue Feb 15 00:15:24 2022
Install Date : Tue Feb 15 00:20:12 2022
Install Reason : Explicitly installed
Install Script : No
Validated By : None
Is only a suggestion recompile it.
Post the PKGBUILD that I used here.
# Maintainer: Brad Fanella <cesura@archlinux.org>
# Contributor: Martin Wimpress <code@flexion.org>
pkgname=mate-utils
pkgver=1.26.0
pkgrel=2
pkgdesc="Common MATE utilities for viewing disk usage, logs and fonts, taking screenshots, managing dictionaries and searching files"
url="http://mate-desktop.org"
arch=('x86_64')
license=('GPL')
depends=('mate-desktop' 'gettext' 'libcanberra' 'libgtop' 'libsm' 'udisks2')
makedepends=('inkscape' 'itstool' 'mate-panel' 'python')
optdepends=('mate-panel: Look up words in dictionaries from the panel')
groups=('mate-extra')
provides=('mate-screenshot' 'mate-dictionary' 'logview' 'baobab' 'gsearchtool' 'mate-disk-image-mounter')
conflicts=('mate-utils-gtk3')
replaces=('mate-utils-gtk3')
source=("https://pub.mate-desktop.org/releases/${pkgver%.*}/${pkgname}-${pkgver}.tar.xz")
sha256sums=('7ca56ab242e8efaa64f93ffb84f6e4bf8d4d0df01e20b3b6ef8956ce3192782e')
build() {
cd "${pkgname}-${pkgver}"
./configure \
--prefix=/usr \
--libexecdir=/usr/lib/${_pkgbase} \
--sysconfdir=/etc \
--disable-maintainer-flags
#https://bugzilla.gnome.org/show_bug.cgi?id=656231
sed -i -e 's/ -shared / -Wl,-O1,--as-needed\0/g' libtool
make
package() {
make DESTDIR="${pkgdir}" install
Best regards.
