Is there a way to make all fonts white? They are a bit hard to read being more dark gray. This will happen in Firefox also right?2023-10-29T04:00:00Z
I don’t use MATE, but in and of themselves, fonts do not have a color. The colors are all dictated by the chosen color scheme, or possibly by the chosen theme if it includes a color scheme.
Again, I don’t use MATE, but in Plasma one can customize the color scheme, so I suspect that it would be possible in MATE as well.
Hi @Edward78,
Short version is yes, there is.
Slightly longer version is that this is probably not what you’re looking for. I don’t know what DE you’re using, but look for a Dark theme for it. That’s probably what you’re looking for.
And no, it won’t automagically be that way in Firefox. Firefox uses it’s own theme, so you need to get a dark theme for it as well.
I know there are also automatic switchers based on the time of day. But I don’t know how these work, since I don’t use 'em.
Have a look here:
I think Firefox uses GTK3, and if I’m not mistaken, then MATE uses a fork of GTK2. But GTK2 and GTK3 should normally be compatible when it comes to themes.
@Edward78, as I said, I use KDE Plasma, but I use e17gtk from the AUR for my GTK2/GTK3-based applications. Of course, I don’t know your taste, and to be honest, the theme is flagged out of date on the AUR, but I haven’t had any problems with it so far, so you may want to try that. It looks like this… ![]()
It works really well alongside Qt-based applications if you set the Qt style to the default kvantum style — you do need to have kvantum installed, though.
Here’s the theme on mate-look.org. ![]()
This one looks good to me:
That looks very… Adwaita to me. ![]()
I’m waiting for the flood of this theme sucks comments.
The people that says that live in denial.
Looks like your spiel choker is da b0rk3n again. ![]()
1t h@pp3n5.
