I used Zoom on PCLinuxOS about a year ago and it was easy to install since it was in the archive, but it is not in manjaro. I have read a lot about how it is done on Manjaro. But there are obviously many ways to do it. I found this link https://snapcraft.io/install/zoom-client/manjaro
Is it a it a good way to install it on Manjaro.
Hi @Snubbi,
Have you looked at the AUR? Because it looks like itâs there.
$ pamac search zoom
zoom 5.5.2-1 AUR
Video Conferencing and Web Conferencing Service
I there is also the possibility to run it in a browser.
zoom-firefox 0.0.3-0 AUR
.desktop file for running Zoom in Firefox
Hope this helps!
It is a way yes. You also have Flatpak option, or simply the AUR or the browser as @Mirdarthos suggests.
If you prefer to avoid snaps, build it from the AUR:
pamac build zoom
I can see this
zoom-system-qt
zoom-firefox
zoom
Which is best? for a regular user
I have no idea, sice Iâve never used Soom for anything before. Youâll have to test and decide for yourself.
zoom is the actual software.
zoom-system-qt are libraries and zoom-firefox is a .desktop file.
Install zoom as I said above:
pamac build zoom
It was Zoom I was going to use I found out. Another question how do I update the program from Aur. I used pamac build zoom.
I also have another program from AUR. I can not update it with sudo pacman -Syu? Or can I
No, pacman canât build from the AUR. You will have to use pamac to update using:
pamac update -a
The -a tells pamac to check the AUR
Thanks
Iâ using zoom flatpacked from flathub for quite a while. It is maintained and regularly gets updates.
In case youâre using kde you can easily install it using KDEs âdiscoverâ installer.
