Mate extensions?
How do I see if any are running? I only changed the theme since install, so unless I unknowenly turned one on, none are running. I only ask because a while back, my screen started randomly goibg black (Like sleep mode or a screensaver, but I checked & no to both) & was told that might be the prob.
“extensions” … like what?
As far as I know mate doesnt have ‘extensions’ … or some sort of manager for third party software/themes … you would just nab them from mate-look.org or similar and put them in the respective HOME directory.
For running processes I might suggest using a resource management tool or something like htop, etc.
