Installing MariaDB/MySQL system tables in '/var/lib/mysql' ...
2022-10-18 19:36:51 0 [ERROR] InnoDB: Invalid flags 0x4800 in ./ibdata1
2022-10-18 19:36:51 0 [ERROR] InnoDB: Plugin initialization aborted with error Data structure corruption
2022-10-18 19:36:51 0 [ERROR] Plugin 'InnoDB' init function returned error.
2022-10-18 19:36:51 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
2022-10-18 19:36:51 0 [ERROR] Unknown/unsupported storage engine: InnoDB
2022-10-18 19:36:51 0 [ERROR] Aborting
Installation of system tables failed! Examine the logs in
/var/lib/mysql for more information.
The problem could be conflicting information in an external
my.cnf files. You can ignore these by doing:
shell> /usr/bin/mariadb-install-db --defaults-file=~/.my.cnf
You can also try to start the mysqld daemon with:
shell> /usr/bin/mariadbd --skip-grant-tables --general-log &
and use the command line tool /usr/bin/mariadb
to connect to the mysql database and look at the grant tables:
shell> /usr/bin/mysql -u root mysql
mysql> show tables;
Try 'mysqld --help' if you have problems with paths. Using
--general-log gives you a log in /var/lib/mysql that may be helpful.
The latest information about mysql_install_db is available at
https://mariadb.com/kb/en/installing-system-tables-mysql_install_db
You can find the latest source at https://downloads.mariadb.org and
the maria-discuss email list at https://launchpad.net/~maria-discuss
Please check all of the above before submitting a bug report
at https://mariadb.org/jira
I’ve tried running the first and second recommendations from the error log generated:
[user ~] /usr/bin/mariadb-install-db --defaults-file=~/.my.cnf
Could not open required defaults file: ~/.my.cnf
Fatal error in defaults handling. Program aborted
Installing MariaDB/MySQL system tables in './data' ...
./data for more information.
mysql> show tables;
--general-log gives you a log in ./data that may be helpful.
[user ~]# /usr/bin/mariadbd --skip-grant-tables --general-log &
[1] 10707
[user ~]# 2022-10-18 19:44:48 0 [Note] /usr/bin/mariadbd (server 10.9.3-MariaDB-log) starting as process 10707 ...
/usr/bin/mariadbd: Please consult the Knowledge Base to find out how to run mysqld as root!
2022-10-18 19:44:48 0 [ERROR] Aborting
> /usr/bin/mysql -u root mysql /usr/bin/mysql -u root mysql
ERROR 2002 (HY000): Can't connect to local server through socket '/run/mysqld/mysqld.sock' (2)
[1]+ Exit 1 /usr/bin/mariadbd --skip-grant-tables --general-log
[user ~]#
This is all while running the terminal as root. I’ve tried accessing the location /var/lib/mysql , but when I read the log files I get gibberish.
That’s no log file in the sense of error log to check. I can’t spot anything that looks like that in your ls listing.
Maybe they meant to check the journal, mariadb generates some entries there:
[user mysql]# journalctl -u mariadb
Oct 15 16:03:37 user systemd[1]: Starting MariaDB 10.9.3 database server...
Oct 15 16:03:38 user mariadbd[5854]: 2022-10-15 16:03:38 0 [Note] /usr/bin/mariadbd (server 10.9.3-MariaDB) starting as p>
Oct 15 16:03:38 user mariadbd[5854]: 2022-10-15 16:03:38 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
Oct 15 16:03:38 user mariadbd[5854]: 2022-10-15 16:03:38 0 [Note] InnoDB: Number of transaction pools: 1
Oct 15 16:03:38 user mariadbd[5854]: 2022-10-15 16:03:38 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
Oct 15 16:03:38 user mariadbd[5854]: 2022-10-15 16:03:38 0 [Note] InnoDB: Using Linux native AIO
Oct 15 16:03:38 user mariadbd[5854]: 2022-10-15 16:03:38 0 [Note] InnoDB: Initializing buffer pool, total size = 128.000M>
Oct 15 16:03:38 user mariadbd[5854]: 2022-10-15 16:03:38 0 [Note] InnoDB: Completed initialization of buffer pool
Oct 15 16:03:38 user mariadbd[5854]: 2022-10-15 16:03:38 0 [ERROR] InnoDB: Invalid flags 0x4800 in ./ibdata1
Oct 15 16:03:38 user mariadbd[5854]: 2022-10-15 16:03:38 0 [ERROR] InnoDB: Plugin initialization aborted with error Data >
Oct 15 16:03:38 user mariadbd[5854]: 2022-10-15 16:03:38 0 [Note] InnoDB: Starting shutdown...
Oct 15 16:03:38 user mariadbd[5854]: 2022-10-15 16:03:38 0 [ERROR] Plugin 'InnoDB' init function returned error.
Oct 15 16:03:38 user mariadbd[5854]: 2022-10-15 16:03:38 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE faile>
Oct 15 16:03:38 user mariadbd[5854]: 2022-10-15 16:03:38 0 [ERROR] Could not open mysql.plugin table: "Table 'mysql.plugi>
Oct 15 16:03:38 user mariadbd[5854]: 2022-10-15 16:03:38 0 [ERROR] Unknown/unsupported storage engine: InnoDB
Oct 15 16:03:38 user mariadbd[5854]: 2022-10-15 16:03:38 0 [ERROR] Aborting
Oct 15 16:03:38 user systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
Oct 15 16:03:38 user systemd[1]: mariadb.service: Failed with result 'exit-code'.
Oct 15 16:03:38 user systemd[1]: Failed to start MariaDB 10.9.3 database server.
Oct 15 16:06:50 user systemd[1]: Starting MariaDB 10.9.3 database server...
Oct 15 16:06:50 user mariadbd[6517]: 2022-10-15 16:06:50 0 [Note] /usr/bin/mariadbd (server 10.9.3-MariaDB) starting as p>
Oct 15 16:06:50 user mariadbd[6517]: 2022-10-15 16:06:50 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
Oct 15 16:06:50 user mariadbd[6517]: 2022-10-15 16:06:50 0 [Note] InnoDB: Number of transaction pools: 1
Oct 15 16:06:50 user mariadbd[6517]: 2022-10-15 16:06:50 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
Oct 15 16:06:50 user mariadbd[6517]: 2022-10-15 16:06:50 0 [Note] InnoDB: Using Linux native AIO
Oct 15 16:06:50 user mariadbd[6517]: 2022-10-15 16:06:50 0 [Note] InnoDB: Initializing buffer pool, total size = 128.000M>
Oct 15 16:06:50 user mariadbd[6517]: 2022-10-15 16:06:50 0 [Note] InnoDB: Completed initialization of buffer pool
Oct 15 16:06:50 user mariadbd[6517]: 2022-10-15 16:06:50 0 [ERROR] InnoDB: Invalid flags 0x4800 in ./ibdata1
Oct 15 16:06:50 user mariadbd[6517]: 2022-10-15 16:06:50 0 [ERROR] InnoDB: Plugin initialization aborted with error Data >
Oct 15 16:06:50 user mariadbd[6517]: 2022-10-15 16:06:50 0 [Note] InnoDB: Starting shutdown...
Oct 15 16:06:50 user mariadbd[6517]: 2022-10-15 16:06:50 0 [ERROR] Plugin 'InnoDB' init function returned error.
Oct 15 16:06:50 user mariadbd[6517]: 2022-10-15 16:06:50 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE faile>
Oct 15 16:06:50 user mariadbd[6517]: 2022-10-15 16:06:50 0 [ERROR] Could not open mysql.plugin table: "Table 'mysql.plugi>
Oct 15 16:06:50 user mariadbd[6517]: 2022-10-15 16:06:50 0 [ERROR] Unknown/unsupported storage engine: InnoDB
Oct 15 16:06:50 user mariadbd[6517]: 2022-10-15 16:06:50 0 [ERROR] Aborting
Oct 15 16:06:50 user systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
Oct 15 16:06:50 user systemd[1]: mariadb.service: Failed with result 'exit-code'.
Oct 15 16:06:50 user systemd[1]: Failed to start MariaDB 10.9.3 database server.
Oct 15 16:19:54 user systemd[1]: Starting MariaDB 10.9.3 database server...
Oct 15 16:19:55 user mariadbd[9076]: 2022-10-15 16:19:55 0 [Note] /usr/bin/mariadbd (server 10.9.3-MariaDB) starting as p>
Oct 15 16:19:55 user mariadbd[9076]: 2022-10-15 16:19:55 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
Oct 15 16:19:55 user mariadbd[9076]: 2022-10-15 16:19:55 0 [Note] InnoDB: Number of transaction pools: 1
Oct 15 16:19:55 user mariadbd[9076]: 2022-10-15 16:19:55 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
Oct 15 16:19:55 user mariadbd[9076]: 2022-10-15 16:19:55 0 [Note] InnoDB: Using Linux native AIO
Oct 15 16:19:55 user mariadbd[9076]: 2022-10-15 16:19:55 0 [Note] InnoDB: Initializing buffer pool, total size = 128.000M>
Oct 15 16:19:55 user mariadbd[9076]: 2022-10-15 16:19:55 0 [Note] InnoDB: Completed initialization of buffer pool
Oct 15 16:19:55 user mariadbd[9076]: 2022-10-15 16:19:55 0 [ERROR] InnoDB: Invalid flags 0x4800 in ./ibdata1
Oct 15 16:19:55 user mariadbd[9076]: 2022-10-15 16:19:55 0 [ERROR] InnoDB: Plugin initialization aborted with error Data >
Oct 15 16:19:55 user mariadbd[9076]: 2022-10-15 16:19:55 0 [Note] InnoDB: Starting shutdown...
Oct 15 16:19:55 user mariadbd[9076]: 2022-10-15 16:19:55 0 [ERROR] Plugin 'InnoDB' init function returned error.
Oct 15 16:19:55 user mariadbd[9076]: 2022-10-15 16:19:55 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE faile>
Oct 15 16:19:55 user mariadbd[9076]: 2022-10-15 16:19:55 0 [ERROR] Could not open mysql.plugin table: "Table 'mysql.plugi>
Oct 15 16:19:55 user mariadbd[9076]: 2022-10-15 16:19:55 0 [ERROR] Unknown/unsupported storage engine: InnoDB
Oct 15 16:19:55 user mariadbd[9076]: 2022-10-15 16:19:55 0 [ERROR] Aborting
Oct 15 16:19:55 user systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
Oct 15 16:19:55 user systemd[1]: mariadb.service: Failed with result 'exit-code'.
Oct 15 16:19:55 user systemd[1]: Failed to start MariaDB 10.9.3 database server.
-- Boot ea31bb894eae400e82cdcdeff5e69911 --
Oct 15 20:26:15 user systemd[1]: Starting MariaDB 10.9.3 database server...
Oct 15 20:26:27 user mariadbd[1184]: 2022-10-15 20:26:27 0 [Note] /usr/bin/mariadbd (server 10.9.3-MariaDB) starting as p>
Oct 15 20:26:28 user mariadbd[1184]: 2022-10-15 20:26:28 0 [Warning] WSREP: Failed to guess base node address. Set it exp>
Oct 15 20:26:28 user mariadbd[1184]: 2022-10-15 20:26:28 0 [Warning] WSREP: Guessing address for incoming client connecti>
Oct 15 20:26:28 user mariadbd[1184]: 2022-10-15 20:26:28 0 [Note] WSREP: Node addr:
Oct 15 20:26:30 user mariadbd[1184]: 2022-10-15 20:26:30 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
Oct 15 20:26:30 user mariadbd[1184]: 2022-10-15 20:26:30 0 [Note] InnoDB: Number of transaction pools: 1
Oct 15 20:26:30 user mariadbd[1184]: 2022-10-15 20:26:30 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
Oct 15 20:26:30 user mariadbd[1184]: 2022-10-15 20:26:30 0 [Note] InnoDB: Using Linux native AIO
Oct 15 20:26:30 user mariadbd[1184]: 2022-10-15 20:26:30 0 [Note] InnoDB: Initializing buffer pool, total size = 128.000M>
Oct 15 20:26:30 user mariadbd[1184]: 2022-10-15 20:26:30 0 [Note] InnoDB: Completed initialization of buffer pool
Oct 15 20:26:30 user mariadbd[1184]: 2022-10-15 20:26:30 0 [ERROR] InnoDB: Invalid flags 0x4800 in ./ibdata1
Oct 15 20:26:30 user mariadbd[1184]: 2022-10-15 20:26:30 0 [ERROR] InnoDB: Plugin initialization aborted with error Data >
Oct 15 20:26:30 user mariadbd[1184]: 2022-10-15 20:26:30 0 [Note] InnoDB: Starting shutdown...
Oct 15 20:26:30 user mariadbd[1184]: 2022-10-15 20:26:30 0 [ERROR] Plugin 'InnoDB' init function returned error.
Oct 15 20:26:30 user mariadbd[1184]: 2022-10-15 20:26:30 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE faile>
Oct 15 20:26:31 user mariadbd[1184]: 2022-10-15 20:26:31 0 [ERROR] Could not open mysql.plugin table: "Table 'mysql.plugi>
Oct 15 20:26:31 user mariadbd[1184]: 2022-10-15 20:26:31 0 [ERROR] Unknown/unsupported storage engine: InnoDB
Oct 15 20:26:31 user mariadbd[1184]: 2022-10-15 20:26:31 0 [ERROR] Aborting
Oct 15 20:26:31 user systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
Oct 15 20:26:31 user systemd[1]: mariadb.service: Failed with result 'exit-code'.
Oct 15 20:26:31 user systemd[1]: Failed to start MariaDB 10.9.3 database server.
-- Boot 4cf7dde9e87745fdb0924850feadd957 --
Oct 15 20:39:07 user systemd[1]: Starting MariaDB 10.9.3 database server...
Oct 15 20:39:15 user mariadbd[1172]: 2022-10-15 20:39:15 0 [Note] /usr/bin/mariadbd (server 10.9.3-MariaDB) starting as p>
Oct 15 20:39:16 user mariadbd[1172]: 2022-10-15 20:39:16 0 [Warning] WSREP: Failed to guess base node address. Set it exp>
Oct 15 20:39:16 user mariadbd[1172]: 2022-10-15 20:39:16 0 [Warning] WSREP: Guessing address for incoming client connecti>
Oct 15 20:39:16 user mariadbd[1172]: 2022-10-15 20:39:16 0 [Note] WSREP: Node addr:
Oct 15 20:39:18 user mariadbd[1172]: 2022-10-15 20:39:18 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
Oct 15 20:39:18 user mariadbd[1172]: 2022-10-15 20:39:18 0 [Note] InnoDB: Number of transaction pools: 1
Oct 15 20:39:18 user mariadbd[1172]: 2022-10-15 20:39:18 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
Oct 15 20:39:18 user mariadbd[1172]: 2022-10-15 20:39:18 0 [Note] InnoDB: Using Linux native AIO
Oct 15 20:39:18 user mariadbd[1172]: 2022-10-15 20:39:18 0 [Note] InnoDB: Initializing buffer pool, total size = 128.000M>
Oct 15 20:39:18 user mariadbd[1172]: 2022-10-15 20:39:18 0 [Note] InnoDB: Completed initialization of buffer pool
Oct 15 20:39:18 user mariadbd[1172]: 2022-10-15 20:39:18 0 [ERROR] InnoDB: Invalid flags 0x4800 in ./ibdata1
Oct 15 20:39:18 user mariadbd[1172]: 2022-10-15 20:39:18 0 [ERROR] InnoDB: Plugin initialization aborted with error Data >
Oct 15 20:39:18 user mariadbd[1172]: 2022-10-15 20:39:18 0 [Note] InnoDB: Starting shutdown...
Oct 15 20:39:18 user mariadbd[1172]: 2022-10-15 20:39:18 0 [ERROR] Plugin 'InnoDB' init function returned error.
Oct 15 20:39:18 user mariadbd[1172]: 2022-10-15 20:39:18 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE faile>
Oct 15 20:39:19 user mariadbd[1172]: 2022-10-15 20:39:19 0 [ERROR] Could not open mysql.plugin table: "Table 'mysql.plugi>
Oct 15 20:39:19 user mariadbd[1172]: 2022-10-15 20:39:19 0 [ERROR] Unknown/unsupported storage engine: InnoDB
Oct 15 20:39:19 user mariadbd[1172]: 2022-10-15 20:39:19 0 [ERROR] Aborting
Oct 15 20:39:19 user systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
Oct 15 20:39:19 user systemd[1]: mariadb.service: Failed with result 'exit-code'.
Oct 15 20:39:19 user systemd[1]: Failed to start MariaDB 10.9.3 database server.
-- Boot 56321d178d76438eaf0335ccc2127041 --
Oct 16 10:42:43 user systemd[1]: Starting MariaDB 10.9.3 database server...
Oct 16 10:42:49 user mariadbd[1191]: 2022-10-16 10:42:49 0 [Note] /usr/bin/mariadbd (server 10.9.3-MariaDB) starting as p>
Oct 16 10:42:49 user mariadbd[1191]: 2022-10-16 10:42:49 0 [Warning] WSREP: Failed to guess base node address. Set it exp>
Oct 16 10:42:49 user mariadbd[1191]: 2022-10-16 10:42:49 0 [Warning] WSREP: Guessing address for incoming client connecti>
Oct 16 10:42:49 user mariadbd[1191]: 2022-10-16 10:42:49 0 [Note] WSREP: Node addr:
Oct 16 10:42:50 user mariadbd[1191]: 2022-10-16 10:42:50 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
Oct 16 10:42:50 user mariadbd[1191]: 2022-10-16 10:42:50 0 [Note] InnoDB: Number of transaction pools: 1
Oct 16 10:42:50 user mariadbd[1191]: 2022-10-16 10:42:50 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
Oct 16 10:42:50 user mariadbd[1191]: 2022-10-16 10:42:50 0 [Note] InnoDB: Using Linux native AIO
Oct 16 10:42:50 user mariadbd[1191]: 2022-10-16 10:42:50 0 [Note] InnoDB: Initializing buffer pool, total size = 128.000M>
Oct 16 10:42:50 user mariadbd[1191]: 2022-10-16 10:42:50 0 [Note] InnoDB: Completed initialization of buffer pool
Oct 16 10:42:50 user mariadbd[1191]: 2022-10-16 10:42:50 0 [ERROR] InnoDB: Invalid flags 0x4800 in ./ibdata1
Oct 16 10:42:50 user mariadbd[1191]: 2022-10-16 10:42:50 0 [ERROR] InnoDB: Plugin initialization aborted with error Data >
Oct 16 10:42:50 user mariadbd[1191]: 2022-10-16 10:42:50 0 [Note] InnoDB: Starting shutdown...
Oct 16 10:42:51 user mariadbd[1191]: 2022-10-16 10:42:51 0 [ERROR] Plugin 'InnoDB' init function returned error.
Oct 16 10:42:51 user mariadbd[1191]: 2022-10-16 10:42:51 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE faile>
Oct 16 10:42:51 user mariadbd[1191]: 2022-10-16 10:42:51 0 [ERROR] Could not open mysql.plugin table: "Table 'mysql.plugi>
Oct 16 10:42:51 user mariadbd[1191]: 2022-10-16 10:42:51 0 [ERROR] Unknown/unsupported storage engine: InnoDB
Oct 16 10:42:51 user mariadbd[1191]: 2022-10-16 10:42:51 0 [ERROR] Aborting
Oct 16 10:42:51 user systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
Oct 16 10:42:51 user systemd[1]: mariadb.service: Failed with result 'exit-code'.
Oct 16 10:42:51 user systemd[1]: Failed to start MariaDB 10.9.3 database server.
-- Boot 1fcd020f0b4e4ab5aaa2f13f35648401 --
Oct 17 22:53:39 user systemd[1]: Starting MariaDB 10.9.3 database server...
Oct 17 22:53:46 user mariadbd[1066]: 2022-10-17 22:53:46 0 [Note] /usr/bin/mariadbd (server 10.9.3-MariaDB) starting as p>
Oct 17 22:53:47 user mariadbd[1066]: 2022-10-17 22:53:47 0 [Warning] WSREP: Failed to guess base node address. Set it exp>
Oct 17 22:53:47 user mariadbd[1066]: 2022-10-17 22:53:47 0 [Warning] WSREP: Guessing address for incoming client connecti>
Oct 17 22:53:47 user mariadbd[1066]: 2022-10-17 22:53:47 0 [Note] WSREP: Node addr:
Oct 17 22:53:48 user mariadbd[1066]: 2022-10-17 22:53:48 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
Oct 17 22:53:48 user mariadbd[1066]: 2022-10-17 22:53:48 0 [Note] InnoDB: Number of transaction pools: 1
Oct 17 22:53:48 user mariadbd[1066]: 2022-10-17 22:53:48 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
Oct 17 22:53:48 user mariadbd[1066]: 2022-10-17 22:53:48 0 [Note] InnoDB: Using Linux native AIO
Oct 17 22:53:48 user mariadbd[1066]: 2022-10-17 22:53:48 0 [Note] InnoDB: Initializing buffer pool, total size = 128.000M>
Oct 17 22:53:48 user mariadbd[1066]: 2022-10-17 22:53:48 0 [Note] InnoDB: Completed initialization of buffer pool
Oct 17 22:53:48 user mariadbd[1066]: 2022-10-17 22:53:48 0 [ERROR] InnoDB: Invalid flags 0x4800 in ./ibdata1
Oct 17 22:53:48 user mariadbd[1066]: 2022-10-17 22:53:48 0 [ERROR] InnoDB: Plugin initialization aborted with error Data >
Oct 17 22:53:48 user mariadbd[1066]: 2022-10-17 22:53:48 0 [Note] InnoDB: Starting shutdown...
Oct 17 22:53:48 user mariadbd[1066]: 2022-10-17 22:53:48 0 [ERROR] Plugin 'InnoDB' init function returned error.
Oct 17 22:53:48 user mariadbd[1066]: 2022-10-17 22:53:48 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE faile>
Oct 17 22:53:49 user mariadbd[1066]: 2022-10-17 22:53:49 0 [ERROR] Could not open mysql.plugin table: "Table 'mysql.plugi>
Oct 17 22:53:49 user mariadbd[1066]: 2022-10-17 22:53:49 0 [ERROR] Unknown/unsupported storage engine: InnoDB
Oct 17 22:53:49 user mariadbd[1066]: 2022-10-17 22:53:49 0 [ERROR] Aborting
Oct 17 22:53:49 user systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
Oct 17 22:53:49 user systemd[1]: mariadb.service: Failed with result 'exit-code'.
Oct 17 22:53:49 user systemd[1]: Failed to start MariaDB 10.9.3 database server.
-- Boot d1ad470f533747e69a4eb3f99bb299dd --
Oct 18 19:36:08 user systemd[1]: Starting MariaDB 10.9.3 database server...
Oct 18 19:36:09 user mariadbd[9996]: 2022-10-18 19:36:09 0 [Note] /usr/bin/mariadbd (server 10.9.3-MariaDB) starting as p>
Oct 18 19:36:09 user mariadbd[9996]: 2022-10-18 19:36:09 0 [Note] InnoDB: Compressed tables use zlib 1.2.12
Oct 18 19:36:09 user mariadbd[9996]: 2022-10-18 19:36:09 0 [Note] InnoDB: Number of transaction pools: 1
Oct 18 19:36:09 user mariadbd[9996]: 2022-10-18 19:36:09 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
Oct 18 19:36:09 user mariadbd[9996]: 2022-10-18 19:36:09 0 [Note] InnoDB: Using Linux native AIO
Oct 18 19:36:09 user mariadbd[9996]: 2022-10-18 19:36:09 0 [Note] InnoDB: Initializing buffer pool, total size = 128.000M>
Oct 18 19:36:09 user mariadbd[9996]: 2022-10-18 19:36:09 0 [Note] InnoDB: Completed initialization of buffer pool
Oct 18 19:36:09 user mariadbd[9996]: 2022-10-18 19:36:09 0 [ERROR] InnoDB: Invalid flags 0x4800 in ./ibdata1
Oct 18 19:36:09 user mariadbd[9996]: 2022-10-18 19:36:09 0 [ERROR] InnoDB: Plugin initialization aborted with error Data >
Oct 18 19:36:09 user mariadbd[9996]: 2022-10-18 19:36:09 0 [Note] InnoDB: Starting shutdown...
Oct 18 19:36:09 user mariadbd[9996]: 2022-10-18 19:36:09 0 [ERROR] Plugin 'InnoDB' init function returned error.
Oct 18 19:36:09 user mariadbd[9996]: 2022-10-18 19:36:09 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE faile>
Oct 18 19:36:09 user mariadbd[9996]: 2022-10-18 19:36:09 0 [ERROR] Could not open mysql.plugin table: "Table 'mysql.plugi>
Oct 18 19:36:09 user mariadbd[9996]: 2022-10-18 19:36:09 0 [ERROR] Unknown/unsupported storage engine: InnoDB
Oct 18 19:36:09 user mariadbd[9996]: 2022-10-18 19:36:09 0 [ERROR] Aborting
Oct 18 19:36:09 user systemd[1]: mariadb.service: Main process exited, code=exited, status=1/FAILURE
Oct 18 19:36:09 user systemd[1]: mariadb.service: Failed with result 'exit-code'.
Oct 18 19:36:09 user systemd[1]: Failed to start MariaDB 10.9.3 database server.
lines 140-173/173 (END)
That looks like it didn’t work: mariadb server did not start.
There are also no entries regarding the mariadb-install-db - only entries regarding mariadb service.
Best to start over:
stop mariadb server (shouldn’t be running as it failed to start)
