I made a new entry in evdev.xml and evdev.lst just to be sure. (that same text as custom opts Ben davis is referring to). I get the working sort of, but just pressing the capslock (meta) gets the focus of the kickoff menu or (activate application launcher widget) but i can’t seem to unbind this key anywhere…
Thanks for replying, and taking the time for this! Thank you for the welcome!
unfortunately it doesn’t work, i already emptied it the shortcut, it’s not called excalibur but just activate application launcher. it already was empty. i emptied it at the system-settings. I even emptied the other Show alternatives but everyone activates at this default behaviour of just pressing the meta key.
the shortcut seems it’s a lot deeper into the system activated or something.
any other ideas?
