Manual btrfs management
Thanks to forum and especially @eugen-b I know a lot about btrfs.
I would like to ask about one more.
I feel that I can’t be wrong.
If I have btrfs formatted partition. Let’s call it sda1
On this partition I have 2 subvolumes
@ for /
@home for /home
Fstab configured to boot from @
Can I in RUNNING system mount sda1 in /mnt with subvolud=5
So in mnt I’ll have @ and @home subvolumes visible
Then create snapshot of @ and @home
Let’s say @_bak @home_bak
Unmount /mnt
Do some things with the system
For example install Firefox and its configuration
Then mount sda1 in mnt again
Do btrfs subvolume delete for @ and for @home
Then do snapshots of @_bak and @home_bak
With original names so @ and @home
Can I do something like this on running system ?
Will this revert all changes made to @ and @home ?
If it’s not possible then can I just run live system and mount my hard disk inside and then do the btrfs operations ?
I would risk an experiment on a test system. I bet btrfs has some kind of precaution not to delete a subvolume of a running system.
I’ll try and let know
But a live cd way is proper right?
I can just do a snapshot of system partition and if I decide that I don’t like changes then I can just boot into live cd, delete subvolume with system and rename snapshot to the name of deleted subvolume.
Ok
I decided to try in my system
I have 3 subvolumes
@home
@cache
I did snapshots of ebery one with suffixes _test
In fstab I changed subvolumes
From @ to @_test
Etc
After reboot my system booted from test subvolumes
Then I did
mount -o subvolid=5 /dev/sda2 /mnt
I deleted subvilumes @_test, @home_test, @cache_test
Those actively mounted
Enter deletion I did edition of my fstab
@_test -> @
@home_test -> @home
@cache_rest -> @cache
After reboot everything is working.
On test subvolumes I did some tests. Crated folders on desktop
Everything is gone :slight_smile:
