Hi,
I’m having troubles to find the sources for Docker Hub
@Strit, IIRC you are the author? Could you help me?
Hi,
This is the script that creates our docker images.
Thanks.
Could we add the info to the Overview pages maybe?
For the reference, https://hub.docker.com/r/archlinux/archlinux/ is much more detailed.
I can look into that, but I’m not sure how many is actually using these images, but yeah, I can describe what these docker images contain.
Thanks, I’ve created an issue:
I think there will be much more users of these very soon
I can see that you remove haveged because of the kernel version service restriction.
Do you have a good entropy ?
