Manjaro zsh customizations on macos
Hello :wave:everyone,
Context: In my next job I’ll have to use a macos and I was wondering if it’s possible to use manjaro-zsh-config under the mac somehow.
Thanks in advance!
Hullo,
On mac:
touch ~/.zshrc
Put stuff in there.
A good amount of it should … or could … work.
Though the way it is currently set up it appears it sources other files - which you may wish to just combine into the .zshrc
Also note you will need a few things, like powerlevel10k.
(the exact deps of the package are : zsh-autosuggestions zsh-syntax-highlighting zsh-completions zsh-history-substring-search zsh ttf-meslo-nerd-font-powerlevel10k zsh-theme-powerlevel10k)
Here is just an example guide that came up from search:
https://v-char.medium.com/now-let-customize-your-native-macos-terminal-with-oh-my-zsh-and-powerlevel10k-b48b9c30d39f
I already applied the changes following the article that you provided https://v-char.medium.com/now-let-customize-your-native-macos-terminal-with-oh-my-zsh-and-powerlevel10k-b48b9c30d39f and the shell feels very better now!
Thanks a lot @cscs !
