Dolphin fails to enter folders with long path name, or path name with unicode symbols, when Dolphin’s integrated terminal is open AND zsh is set by default with Manjaro-zsh-config.
How to reproduce:
- Open Dolphin with F4 terminal open. Enter any desired folder,
- Create “Пробная папка” folder
- Enter that folder
- Repeat from step 2
After 4-6 repeats Dolphin will fail to enter that folder and terminal will throw an error.
If terminal is closed, problem does not reproduce. If ~/.zshrc file is removed, or everything is commented, problem does not reproduce.
I’ve been searching on internet and found two similar bugs 472564 – Dolphin view glitches when oh-my-zsh used in konsole panel 470031 – Long name folder containing Chinese character make Dolphin with terminal panel & zsh unable to enter the folder
Tried to reconfigure p10k - didn’t help. Returned everything to default state and removed ~/.zshrc file, rebooted and problem has gone. Something is wrong in Manjaro’s config, I think.
pacman -Qs zsh
local/manjaro-zsh-config 0.26-1
local/zsh 5.9-4
local/zsh-autosuggestions 0.7.0-2
local/zsh-completions 0.35.0-1
local/zsh-history-substring-search 1.1.0-1
local/zsh-syntax-highlighting 0.8.0-1
local/zsh-theme-powerlevel10k 1.19.0-1
Dolphin 23.08.4
