Im on Manjaro XFCE:
System: Host: mrcrabs-gwagon Kernel: 5.10.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1 Desktop: Xfce 4.16.0
tk: Gtk 3.24.24 wm: xfwm4 dm: LightDM Distro: Manjaro Linux
Machine: Type: Desktop Mobo: ASRock model: H110M-DVS R3.0 serial: <superuser required> UEFI [Legacy]: American Megatrends
v: P1.20 date: 04/17/2017
CPU: Info: Quad Core model: Intel Core i5-7400 bits: 64 type: MCP arch: Kaby Lake rev: 9 L2 cache: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 24008
Speed: 800 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Graphics: Device-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nvidia v: 460.39 bus ID: 01:00.0 chip ID: 10de:1c03
Display: x11 server: X.Org 1.20.10 driver: loaded: nvidia resolution: 1: 1920x1080~60Hz 2: 1920x1080~75Hz s-dpi: 96
OpenGL: renderer: GeForce GTX 1060 6GB/PCIe/SSE2 v: 4.6.0 NVIDIA 460.39 direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASRock driver: snd_hda_intel v: kernel
bus ID: 00:1f.3 chip ID: 8086:a170
Device-2: NVIDIA GP106 High Definition Audio driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:10f1
Device-3: Corsair VOID PRO Surround USB Adapter type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-10:5
chip ID: 1b1c:0a18
Device-4: Generalplus 808 Camera type: USB driver: snd-usb-audio,uvcvideo bus ID: 1-2:3 chip ID: 1b3f:2002
Sound Server: ALSA v: k5.10.15-1-MANJARO
Network: Device-1: Realtek RTL8192CE PCIe Wireless Network Adapter driver: rtl8192ce v: kernel port: d000 bus ID: 02:00.0
chip ID: 10ec:8178
IF: wlp2s0 state: down mac: 02:41:c8:4b:59:5b
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASRock driver: r8169 v: kernel port: c000
bus ID: 03:00.0 chip ID: 10ec:8168
IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: 70:85:c2:45:72:8b
Drives: Local Storage: total: 1.38 TiB used: 155.85 GiB (11.1%)
ID-1: /dev/sda vendor: Silicon Power model: SPCC Solid State Disk size: 476.94 GiB speed: 6.0 Gb/s
serial: C6380799116A00116718
ID-2: /dev/sdb vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB speed: 6.0 Gb/s serial: 1919E20206DF
Partition: ID-1: / size: 907.23 GiB used: 155.85 GiB (17.2%) fs: ext4 dev: /dev/sdb1
Swap: ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdb2
Sensors: System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia temp: 33 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 25%
Info: Processes: 255 Uptime: 2m Memory: 15.59 GiB used: 2.95 GiB (18.9%) Init: systemd v: 247 Compilers: gcc: 10.2.0
clang: 11.0.1 Packages: 1657 pacman: 1632 flatpak: 11 snap: 14 Shell: Zsh v: 5.8 running in: xfce4-terminal
inxi: 3.3.01
I installed Manjaro yesterday, clean install, I have Nvidia so I chose proprietary drivers. I changed my kernel to 5.10
using the GUI (I removed the previous Kernel).
Crashed starts by first freezing the whole DE or parts of it sequentially. These crashes happen both on heavy and very lightweight workloads. The system just freezes and I cannot do anything so I just press the power button and restart. Upon restart when loading the DE there are some visual glitches visible for a split second but they don’t seem to be anything unusual for Linux DEs tbh
I know I should append some logs, just tell me which ones. For start here is my journalctl > journal.txt
and dmesg > dmsg.txt
. Yes it’s 4am here, and also my DateTime is set to polish because I hate Anglo-Saxon formatting lol
Because this forum does not let me upload text files here is a link to a drive where I uploaded these 2 files:
https://drive.google.com/drive/folders/1WggKV7LgmzGjkqJGYoAZWtHG58zsUiGE?usp=sharing
Please help…I just want to do some work done
