I bought a Tuxdeo Aura 15 Gen 1and I am facing difficulties with the keyboard lights. Currently the keyboard lights are blue and I can’t figure out how to change colors and use/activate/deactivate the lights?
I installed tuxedo-keyboard from the Manjaro repository but then, what is next?
Did you reboot after installing tuxedo-keyboard-dkms? It’s required to load the kernel module. I also suggest installing tuxedo-control-center if you haven’t already.
