Hi all, thanks in advance for your help.
I am installing Manjaro on a laptop for the first time (running it right now from a USB). But I am unable to get past the bootloader stage as the system will become completely frozen when I attempt to install the bootloader (mouse won’t move, keyboard unresponsive). Only way to recover is to hold the power button.
I am using an Acer Aspire ES 15. From what I can tell from Googling, other users of this laptop have had similar issues. I had at first tried to boot Linux Mint from a Live USB, but that would literally get stuck at the start up screen showing the Mint logo and never progress. Failing that, I started to try Manjaro (although I am preferring it to Linux Mint now anyway, so happy accident?).
When I run the Manjaro install GUI, the entire process runs fine until about 90%, when the loading bar displays “Installing bootloader”. Then the system freezes. When I return to Manjaro (booting through the Live USB), I find that the hard drive partitioning has succeeded and that storage is available to Manjaro, but other steps (like creating users and installing the bootloader) has not succeeded.
Just now I took steps to install GRUB from the command like using these commands
sudo manjaro-chroot -a
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck --verbose efibootmgr -v
However, that results in the system freezing just as it did when the installation GUI attempted to install the bootloader.
I have recreated the Live USB a couple times using different tools and get the same result.
I am willing to try installing Manjaro with KDE or GNOME instead of XFCE, however I’d like to stick with XFCE if possible as it performs quite well on this laptop.
Here is the output of inxi -Fazy
Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
misobasedir=manjaro misolabel=MANJARO_XFCE_2011 quiet systemd.show_status=1
apparmor=1 security=apparmor
Desktop: Xfce 4.14.2 tk: Gtk 3.24.20 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: Acer product: Aspire ES1-533 v: V1.04 serial: <filter>
Mobo: Acer model: Stego_AP v: V1.04 serial: <filter> UEFI: Insyde v: 1.04
date: 09/07/2016
ID-1: BAT1 charge: 26.9 Wh condition: 26.9/36.7 Wh (73%) volts: 12.6/11.3
model: COMPAL 0038314234314341 type: Li-ion serial: <filter> status: Full
Topology: Quad Core model: Intel Pentium N4200 bits: 64 type: MCP
arch: Goldmont family: 6 model-id: 5C (92) stepping: 9 microcode: 38
L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 8756
Speed: 796 MHz min/max: 800/2500 MHz Core speeds (MHz): 1: 796 2: 796 3: 796
4: 796
Type: spec_store_bypass status: Not affected
Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Integrated
Graphics
vendor: Acer Incorporated ALI driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:5a84
Device-2: Quanta VGA Webcam type: USB driver: uvcvideo bus ID: 1-7:4
chip ID: 0408:a010 serial: <filter>
Display: x11 server: X.Org 1.20.9 driver: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 505 (APL 3) v: 4.6 Mesa 20.1.8
direct render: Yes
Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:0e.0 chip ID: 8086:5a98
Sound Server: ALSA v: k5.8.11-1-MANJARO
vendor: Acer Incorporated ALI driver: r8169 v: kernel port: 1000
bus ID: 01:00.0 chip ID: 10ec:8168
IF: enp1s0 state: down mac: <filter>
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel port: 1000 bus ID: 02:00.0 chip ID: 8086:24fb
Local Storage: total: 938.73 GiB used: 168.6 MiB (0.0%)
ID-1: /dev/sda vendor: Toshiba model: MQ01ABD100 size: 931.51 GiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 3J scheme: GPT
ID-2: /dev/sdb type: USB vendor: Verbatim model: STORE N GO size: 7.22 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: PMAP
scheme: MBR
ID-1: / raw size: N/A size: 5.70 GiB used: 168.6 MiB (2.9%) fs: overlay
source: ERR-102
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 191 Uptime: 6m Memory: 7.60 GiB used: 1.44 GiB (18.9%)
Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1140 lib: 314
flatpak: 0 Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.05
