I don’t have an .iso – I just built the persistent system using Phil’s instructions on his Alma github page (linked in my previous post). Then I added the graphical desktop environment (Gnome in my case) and configured everything as though I’d installed a minimal system to a physical hard drive. Give it a try – it’s easier than I thought it would be.
Thanks, Phil. I booted into Linux54 and tried again, but I get the same error. Tried a different USB, and also tried formatting to both Fat32 and Ext4, but it doesn’t seem to make a difference. I also tried reinstalling alma-git with its arch script dependency, but the error pops up again. I noticed that this started happening after GRUB and OS-Prober went through their recent “upgrades.”
@philm Issuing sudo downgrade grub I see multiple instances of version 2.04 (my current version) along with one 2.06. Would any of these work for testing purposes here?
for some reason i always get
“ERROR: device ‘UUID=foobar’ not found skipping fsck
mount: /new_root: cant find UUID=foobar,
You are now being dropped to emerygency shell
sh: cant access tty: job control turned off”
I even created a new img using your tutorials but it also gives this error.
I buildt with kernel 5.10 and it did work. In the first run i got some errors. But when i did it again after a reboot and 10 Minutes it worked without error. Because i know that the USB-Stick is formated and therefor deleted this seems odd to me.
Later then i switched successfully to btrfs
I converted etx4 to btrfs with the stick at my desktop linux and the partition not mounted btrfs-convert /dev/*partition*
got the new UUID from lsblk -dno LABEL /dev/*partition*
mounted the Partition “1” and changed the grub.cfg with mc. Replacing every old UUID with the new one
mounted the partition “3” and changed the /etc/fstab. Commenting the first Line with “#” and adding a new line with UUID= … and 0 as last number instead of 1. I also added “,compress=zstd”
P.S.: I did forget to mention that i used a preset. manjaro-xfce
P.S.2: Now i deleted “ext2_saved”, and did compress everything i had installed with zstd:9 and the usage got down from 7.4G to 3.2G
I booted to the tty1, manually installed the xfce desktop, but am unable to log in to any user account. I created the account using useradd -m chris -p password
but now that I booted into the xfce login screen, I cannot login.
Help would be appreciated
Edit:
I looked again at the user file and I think the problem was it wasn’t actually configured to save the passwords.
All working now
TIP for next time:
When you use a preset (like manjaro-xfce ) the USER will be created automatic. You only export the ALMA_USER for alma. Alma will ask you for the password when it is needed:
sudo su
export ALMA_USER=myUsername
alma create --presets ./presets/xfce-manjaro
But beforehand you have to download the presets to the directory you choose to start alma in.
P.S.: and the user is in sudoers
Oh! I click on the word direct below the paragraph that talks about a downloadable image and then it takes me to a page where I can download the ready-made USB-Image. I wish that had been more clearly explained.
Today the image is manjaro-xfce-20.0.3-20200704-USB8GB-unstable.img.gz. The forum will not permit me to put the link to this image. It is now saying 4hours to download the 1.6GB file.
I was also able to generate a working live USB with no GUI desktop on a Manjaro PC with the following:
sudo pamac install alma-git
ls /dev/disk/by-id/usb*
sudo alma create /dev/disk/by-id/usb-Generic_USB_Flash_Disk-0:0
Then create a newuser with root privileges and install a GUI desktop.
