Hello everybody,
I’ve just set up my Surface Book with a new install of Manjaro (KDE Plasma) including the arch surface Kernel (Running 6.3.6).
The system works fine - including sleep and wake up - EXCEPT if I connect the Laptop to my Dock which has three external Monitors (Configuration is to disable Surface Screen and enable the three others).
If it goes to sleep in this configuration it won’t wake up. Usually I have to force-turn off the system and reboot. Once or twice I got the message that the screen locker is broken:
The screen locker is broken and unlocking is not possible anymore.
In order to unlock switch to a virtual terminal (e.g. Ctrl+Alt+F2),
log in and execute the command:
loginctl unlock session ...
Excerpt from the journalctl (deleted NetworkManager entries):
Jun 09 23:59:57 hostname kernel: Filesystems sync: 0.010 seconds
Jun 09 23:59:57 hostname kernel: Freezing user space processes
Jun 09 23:59:57 hostname kernel: Freezing user space processes completed (elapsed 0.002 seconds)
Jun 09 23:59:57 hostname kernel: OOM killer disabled.
Jun 09 23:59:57 hostname kernel: Freezing remaining freezable tasks
Jun 09 23:59:57 hostname kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
Jun 09 23:59:57 hostname kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Jun 09 23:59:57 hostname kernel: ipts 0000:00:16.4-3e8d0870-271a-4208-8eb5-9acb9402ae04: Stopping IPTS
Jun 09 23:59:57 hostname kernel: ACPI: EC: interrupt blocked
Jun 09 23:59:57 hostname kernel: intel_pch_thermal 0000:00:14.2: CPU-PCH is cool [35C]
Jun 09 23:59:57 hostname kernel: ACPI Warning: Time parameter 255 us > 100 us violating ACPI spec, please fix the firmware. (20221020/exsystem-141)
Jun 09 23:59:57 hostname kernel: ACPI: EC: interrupt unblocked
Jun 09 23:59:57 hostname kernel: r8152-cfgselector 2-4.2: reset SuperSpeed USB device number 5 using xhci_hcd
Jun 09 23:59:57 hostname kernel: r8152 2-4.2:1.0: skip request firmware
Jun 09 23:59:57 hostname kernel: r8152 2-4.2:1.0: load rtl8153a-3 v2 02/07/20 successfully
Jun 09 23:59:57 hostname kernel: usb 1-4.1.2: reset high-speed USB device number 9 using xhci_hcd
Jun 09 23:59:57 hostname kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to get ACT after 3000ms, last status: 00
Jun 09 23:59:57 hostname kernel: ipts 0000:00:16.4-3e8d0870-271a-4208-8eb5-9acb9402ae04: Starting IPTS
Jun 09 23:59:57 hostname kernel: OOM killer enabled.
Jun 09 23:59:57 hostname kernel: Restarting tasks ...
Jun 09 23:59:57 hostname kernel: ipts 0000:00:16.4-3e8d0870-271a-4208-8eb5-9acb9402ae04: IPTS EDS Version: 1
Jun 09 23:59:57 hostname iptsd[400]: [23:59:57.351] [warning] Input/output error
Jun 09 23:59:57 hostname kernel: done.
Jun 09 23:59:57 hostname kernel: random: crng reseeded on system resumption
Jun 09 23:59:57 hostname kernel: ipts 0000:00:16.4-3e8d0870-271a-4208-8eb5-9acb9402ae04: IPTS running in event mode
Jun 09 23:59:57 hostname kernel: input: IPTS 1B96:005E Touchscreen as /devices/pci0000:00/0000:00:16.4/0000:00:16.4-3e8d0870-271a-4208-8eb5-9acb940>
Jun 09 23:59:57 hostname kernel: input: IPTS 1B96:005E as /devices/pci0000:00/0000:00:16.4/0000:00:16.4-3e8d0870-271a-4208-8eb5-9acb9402ae04/0000:1>
Jun 09 23:59:57 hostname iptsd[400]: [23:59:57.452] [warning] Input/output error
Jun 09 23:59:57 hostname systemd[1]: Stopping Intel Precise Touch & Stylus Daemon...
Jun 09 23:59:57 hostname kernel: hid-generic 0000:1B96:005E.0009: input,hidraw7: <UNKNOWN> HID v0.00 Device [IPTS 1B96:005E] on
Jun 09 23:59:57 hostname iptsd[400]: [23:59:57.552] [info] Stopping
Jun 09 23:59:57 hostname iptsd[400]: [23:59:57.552] [error] No such device
Jun 09 23:59:57 hostname systemd[1]: Condition check resulted in /dev/hidraw7 being skipped.
Jun 09 23:59:57 hostname systemd[1]: Started Intel Precise Touch & Stylus Daemon.
Jun 09 23:59:57 hostname kernel: input: IPTS Touch as /devices/virtual/input/input36
Jun 09 23:59:57 hostname iptsd[2459]: [23:59:57.614] [info] Connected to device 1B96:005E
Jun 09 23:59:57 hostname kernel: input: IPTS Stylus as /devices/virtual/input/input37
Jun 09 23:59:57 hostname kernel: PM: suspend exit
Jun 09 23:59:57 hostname systemd-sleep[2327]: System returned from sleep state.
Jun 09 23:59:57 hostname systemd[1]: systemd-suspend.service: Deactivated successfully.
Jun 09 23:59:57 hostname systemd[1]: Finished System Suspend.
Jun 09 23:59:57 hostname systemd[1]: Stopped target Sleep.
Jun 09 23:59:57 hostname systemd[1]: Reached target Suspend.
Jun 09 23:59:57 hostname systemd[1]: Stopped target Suspend.
Jun 09 23:59:57 hostname systemd-logind[343]: Operation 'sleep' finished.
Jun 09 23:59:57 hostname ModemManager[360]: <info> [sleep-monitor-systemd] system is resuming
Jun 09 23:59:57 hostname bluetoothd[448]: Failed to set mode: Failed (0x03)
Jun 09 23:59:57 hostname kded5[642]: kf.bluezqt: PendingCall Error: "Failed"
Jun 09 23:59:58 hostname kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp0s20f0u4u2: link becomes ready
Jun 09 23:59:58 hostname kernel: r8152 2-4.2:1.0 enp0s20f0u4u2: carrier on
Jun 09 23:59:58 hostname kwin_wayland[582]: kwin_wayland_drm: disabling connector "LA2405/CN412304V9" without a crtc
Jun 09 23:59:58 hostname kwin_wayland[582]: kwin_core: Parse error in tiles configuration for monitor "866f31c4-e8a2-53a3-8cc7-c3e5d994396a" : "ill>
Jun 09 23:59:58 hostname kwin_wayland[582]: kwin_core: Parse error in tiles configuration for monitor "b81ef7de-82fa-5631-8e75-d449aa0dfb6e" : "ill>
Jun 09 23:59:58 hostname kwin_wayland[582]: kwin_core: Parse error in tiles configuration for monitor "351c78cf-2f87-5861-bf23-78eedca1bb06" : "ill>
Jun 09 23:59:58 hostname kernel: ipts 0000:00:16.4-3e8d0870-271a-4208-8eb5-9acb9402ae04: Starting IPTS
Jun 09 23:59:58 hostname kernel: ipts 0000:00:16.4-3e8d0870-271a-4208-8eb5-9acb9402ae04: IPTS EDS Version: 1
Jun 09 23:59:58 hostname kernel: ipts 0000:00:16.4-3e8d0870-271a-4208-8eb5-9acb9402ae04: IPTS running in doorbell mode
Jun 09 23:59:58 hostname systemd[1]: iptsd@dev-hidraw6.service: Deactivated successfully.
Jun 09 23:59:58 hostname systemd[1]: Stopped Intel Precise Touch & Stylus Daemon.
Jun 09 23:59:58 hostname plasmashell[688]: qt.qpa.wayland: Creating a fake screen in order for Qt not to crash
Jun 09 23:59:58 hostname plasmashell[688]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
Jun 09 23:59:59 hostname plasmashell[688]: file:///usr/share/plasma/wallpapers/org.kde.color/contents/ui/main.qml:12: TypeError: Cannot read proper>
Jun 09 23:59:59 hostname plasmashell[688]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
Jun 09 23:59:59 hostname kwin_wayland[582]: kwin_wayland_drm: failed to open drm device at ""
Jun 10 00:00:00 hostname kwin_wayland[582]: kwin_wayland_drm: failed to open drm device at ""
Jun 10 00:00:00 hostname ModemManager[360]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:14.0/usb2/2-4>
Jun 10 00:00:00 hostname ModemManager[360]: <info> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1d.3/0000:03:>
Jun 10 00:00:01 hostname systemd[1]: Starting Rotate log files...
Jun 10 00:00:01 hostname systemd[1]: Starting pkgfile database update...
Jun 10 00:00:01 hostname systemd[1]: Started Verify integrity of password and group files.
Jun 10 00:00:01 hostname kded5[642]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/4”"
Jun 10 00:00:01 hostname kdeconnectd[889]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/4”"
Jun 10 00:00:01 hostname kded5[642]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/2”"
Jun 10 00:00:01 hostname kdeconnectd[889]: "Object does not exist at path “/org/freedesktop/NetworkManager/ActiveConnection/2”"
Jun 10 00:00:01 hostname kernel: mwifiex_pcie 0000:03:00.0: info: trying to associate to bssid BSSID
Jun 10 00:00:01 hostname systemd[1]: logrotate.service: Deactivated successfully.
Jun 10 00:00:01 hostname systemd[1]: Finished Rotate log files.
Jun 10 00:00:01 hostname systemd[1]: shadow.service: Deactivated successfully.
Jun 10 00:00:01 hostname kernel: mwifiex_pcie 0000:03:00.0: info: associated to bssid BSSID successfully
Jun 10 00:00:01 hostname kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
Jun 10 00:00:02 hostname plasmashell[1324]: [1324:1329:0610/000002.089009:ERROR:ssl_client_socket_impl.cc(978)] handshake failed; returned -1, SSL >
Jun 10 00:00:02 hostname plasmashell[1324]: [1324:1329:0610/000002.093587:ERROR:ssl_client_socket_impl.cc(978)] handshake failed; returned -1, SSL >
Jun 10 00:00:02 hostname plasmashell[1324]: [1324:1329:0610/000002.095782:ERROR:ssl_client_socket_impl.cc(978)] handshake failed; returned -1, SSL >
Jun 10 00:00:03 hostname dbus-daemon[340]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop>
Jun 10 00:00:03 hostname systemd[1]: Starting Network Manager Script Dispatcher Service...
Jun 10 00:00:03 hostname dbus-daemon[340]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Jun 10 00:00:03 hostname systemd[1]: Started Network Manager Script Dispatcher Service.
Jun 10 00:00:04 hostname plasmashell[1324]: [1324:1329:0610/000004.086834:ERROR:ssl_client_socket_impl.cc(978)] handshake failed; returned -1, SSL >
Jun 10 00:00:04 hostname kwin_wayland[582]: kwin_wayland_drm: disabling connector "VVX14P048M00/1143017728" without a crtc
Jun 10 00:00:04 hostname kwin_wayland[582]: kwin_wayland_drm: disabling connector "DP-1-unknown" without a crtc
Jun 10 00:00:04 hostname kwin_wayland[582]: kwin_wayland_drm: disabling connector "HDMI-A-1-unknown" without a crtc
Jun 10 00:00:04 hostname kwin_wayland[582]: kwin_wayland_drm: disabling connector "DP-2-unknown" without a crtc
Jun 10 00:00:04 hostname kwin_wayland[582]: kwin_wayland_drm: disabling connector "HDMI-A-2-unknown" without a crtc
Jun 10 00:00:04 hostname kwin_wayland[582]: kwin_wayland_drm: disabling connector "DP-3-unknown" without a crtc
Jun 10 00:00:04 hostname kwin_wayland[582]: kwin_wayland_drm: disabling connector "DP-4-unknown" without a crtc
Jun 10 00:00:05 hostname kwin_wayland[582]: kwin_wayland_drm: disabling connector "VVX14P048M00/1143017728" without a crtc
Jun 10 00:00:05 hostname kwin_wayland[582]: kwin_wayland_drm: disabling connector "DP-1-unknown" without a crtc
Jun 10 00:00:05 hostname kwin_wayland[582]: kwin_wayland_drm: disabling connector "HDMI-A-1-unknown" without a crtc
Jun 10 00:00:05 hostname kwin_wayland[582]: kwin_wayland_drm: disabling connector "DP-2-unknown" without a crtc
Jun 10 00:00:05 hostname kwin_wayland[582]: kwin_wayland_drm: disabling connector "HDMI-A-2-unknown" without a crtc
Jun 10 00:00:05 hostname kwin_wayland[582]: kwin_wayland_drm: disabling connector "DP-3-unknown" without a crtc
Jun 10 00:00:05 hostname kwin_wayland[582]: kwin_wayland_drm: disabling connector "DP-4-unknown" without a crtc
Jun 10 00:00:05 hostname kwin_wayland_wrapper[582]: error in client communication (pid 688)
Jun 10 00:00:05 hostname plasmashell[688]: wl_registry@2: error 0: invalid global wl_output (62)
Jun 10 00:00:05 hostname plasmashell[688]: The Wayland connection experienced a fatal error: Protocol error
Jun 10 00:00:05 hostname kwin_wayland[582]: OpenGL vendor string: Intel
Jun 10 00:00:05 hostname kwin_wayland[582]: OpenGL renderer string: Mesa Intel(R) HD Graphics 520 (SKL GT2)
Jun 10 00:00:05 hostname kwin_wayland[582]: OpenGL version string: 4.6 (Core Profile) Mesa 23.0.3
Jun 10 00:00:05 hostname kwin_wayland[582]: OpenGL shading language version string: 4.60
Jun 10 00:00:05 hostname kwin_wayland[582]: Driver: Intel
Jun 10 00:00:05 hostname kwin_wayland[582]: GPU class: Skylake
Jun 10 00:00:05 hostname kwin_wayland[582]: OpenGL version: 4.6
Jun 10 00:00:05 hostname kwin_wayland[582]: GLSL version: 4.60
Jun 10 00:00:05 hostname kwin_wayland[582]: Mesa version: 23.0.3
Jun 10 00:00:05 hostname kwin_wayland[582]: X server version: 1.23.1
Jun 10 00:00:05 hostname kwin_wayland[582]: Linux kernel version: 6.3.6
Jun 10 00:00:05 hostname kwin_wayland[582]: Requires strict binding: no
Jun 10 00:00:05 hostname kwin_wayland[582]: GLSL shaders: yes
Jun 10 00:00:05 hostname kwin_wayland[582]: Texture NPOT support: yes
Jun 10 00:00:05 hostname kwin_wayland[582]: Virtual Machine: no
Jun 10 00:00:05 hostname systemd[548]: plasma-plasmashell.service: Main process exited, code=exited, status=1/FAILURE
Jun 10 00:00:05 hostname systemd[548]: plasma-ksystemstats.service: Consumed 11.770s CPU time.
Jun 10 00:00:05 hostname systemd[548]: plasma-plasmashell.service: Failed with result 'exit-code'.
Jun 10 00:00:05 hostname systemd[548]: plasma-plasmashell.service: Consumed 56.823s CPU time.
Jun 10 00:00:05 hostname kwin_wayland[582]: BlurConfig::instance called after the first use - ignoring
Jun 10 00:00:05 hostname kwin_wayland[582]: ZoomConfig::instance called after the first use - ignoring
Jun 10 00:00:05 hostname kwin_wayland[582]: WindowViewConfig::instance called after the first use - ignoring
Jun 10 00:00:05 hostname kwin_wayland[582]: SlidingPopupsConfig::instance called after the first use - ignoring
Jun 10 00:00:05 hostname kwin_wayland[582]: SlideConfig::instance called after the first use - ignoring
Jun 10 00:00:05 hostname kwin_wayland[582]: OverviewConfig::instance called after the first use - ignoring
Jun 10 00:00:05 hostname kwin_wayland[582]: KscreenConfig::instance called after the first use - ignoring
Jun 10 00:00:05 hostname kwin_wayland[582]: DesktopGridConfig::instance called after the first use - ignoring
Jun 10 00:00:05 hostname kwalletd5[561]: qt.qpa.wayland: Creating a fake screen in order for Qt not to crash
Jun 10 00:00:05 hostname kactivitymanagerd[727]: qt.qpa.wayland: Creating a fake screen in order for Qt not to crash
Jun 10 00:00:05 hostname kdeconnectd[889]: qt.qpa.wayland: Creating a fake screen in order for Qt not to crash
Jun 10 00:00:05 hostname pamac-tray-plasma[903]: qt.qpa.wayland: Creating a fake screen in order for Qt not to crash
Jun 10 00:00:05 hostname msm_kde_notifier[888]: qt.qpa.wayland: Creating a fake screen in order for Qt not to crash
Jun 10 00:00:05 hostname baloorunner[1177]: qt.qpa.wayland: Creating a fake screen in order for Qt not to crash
Jun 10 00:00:05 hostname polkit-kde-authentication-agent-1[736]: qt.qpa.wayland: Creating a fake screen in order for Qt not to crash
Jun 10 00:00:05 hostname kwrite[2182]: qt.qpa.wayland: Creating a fake screen in order for Qt not to crash
Jun 10 00:00:05 hostname kwin_wayland_wrapper[582]: error in client communication (pid 727)
Jun 10 00:00:05 hostname kwin_wayland_wrapper[582]: error in client communication (pid 561)
Jun 10 00:00:05 hostname kwin_wayland_wrapper[582]: error in client communication (pid 889)
Jun 10 00:00:05 hostname kwin_wayland_wrapper[582]: error in client communication (pid 903)
Jun 10 00:00:05 hostname kwin_wayland_wrapper[582]: error in client communication (pid 582)
Jun 10 00:00:05 hostname kwin_wayland_wrapper[582]: error in client communication (pid 2182)
Jun 10 00:00:05 hostname kactivitymanagerd[727]: wl_registry@2: error 0: invalid global wl_output (62)
Jun 10 00:00:05 hostname kwalletd5[561]: The Wayland connection experienced a fatal error: Protocol error
Jun 10 00:00:05 hostname kactivitymanagerd[727]: The Wayland connection experienced a fatal error: Protocol error
Jun 10 00:00:05 hostname kwin_wayland_wrapper[582]: error in client communication (pid 888)
Jun 10 00:00:05 hostname kwin_wayland_wrapper[582]: error in client communication (pid 1177)
Jun 10 00:00:05 hostname kwin_wayland_wrapper[582]: error in client communication (pid 736)
Jun 10 00:00:05 hostname kwin_wayland_wrapper[582]: error in client communication (pid 1990)
Jun 10 00:00:05 hostname baloorunner[1177]: The Wayland connection experienced a fatal error: Protocol error
Jun 10 00:00:05 hostname baloorunner[1177]: wl_registry@2: error 0: invalid global wl_output (62)
Jun 10 00:00:05 hostname msm_kde_notifier[888]: wl_registry@2: error 0: invalid global wl_output (62)
Jun 10 00:00:05 hostname pamac-tray-plasma[903]: wl_registry@2: error 0: invalid global wl_output (62)
Jun 10 00:00:05 hostname kdeconnectd[889]: wl_registry@2: error 0: invalid global wl_output (62)
Jun 10 00:00:05 hostname pamac-tray-plasma[903]: The Wayland connection experienced a fatal error: Protocol error
Jun 10 00:00:05 hostname kwin_wayland_wrapper[608]: (EE)
Jun 10 00:00:05 hostname kwin_wayland_wrapper[608]: Fatal server error:
Jun 10 00:00:05 hostname polkit-kde-authentication-agent-1[736]: wl_registry@2: error 0: invalid global wl_output (62)
Jun 10 00:00:05 hostname polkit-kde-authentication-agent-1[736]: The Wayland connection experienced a fatal error: Protocol error
Jun 10 00:00:05 hostname kdeconnectd[889]: The Wayland connection experienced a fatal error: Protocol error
Jun 10 00:00:05 hostname kwin_wayland_wrapper[608]: (EE) wl_registry@2: error 0: invalid global wl_output (62)
Jun 10 00:00:05 hostname plasmashell[2182]: wl_registry@2: error 0: invalid global wl_output (62)
Jun 10 00:00:05 hostname kwrite[2182]: The Wayland connection experienced a fatal error: Protocol error
Jun 10 00:00:05 hostname msm_kde_notifier[888]: The Wayland connection experienced a fatal error: Protocol error
Jun 10 00:00:05 hostname systemd[548]: plasma-baloorunner.service: Main process exited, code=exited, status=1/FAILURE
Jun 10 00:00:05 hostname systemd[548]: plasma-baloorunner.service: Failed with result 'exit-code'.
Jun 10 00:00:05 hostname polkitd[341]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.35, object path /org/kde/PolicyKit1>
Jun 10 00:00:05 hostname systemd[548]: app-msm_kde_notifier@autostart.service: Main process exited, code=exited, status=1/FAILURE
Jun 10 00:00:05 hostname systemd[548]: app-msm_kde_notifier@autostart.service: Failed with result 'exit-code'.
Jun 10 00:00:05 hostname systemd[548]: app-msm_kde_notifier@autostart.service: Consumed 1.548s CPU time.
Jun 10 00:00:05 hostname systemd[548]: plasma-plasmashell.service: Scheduled restart job, restart counter is at 1.
Jun 10 00:00:05 hostname systemd[548]: Stopped KDE Plasma Workspace.
Jun 10 00:00:05 hostname kaccess[898]: The X11 connection broke (error 1). Did the X11 server die?
Jun 10 00:00:05 hostname ksmserver[640]: The X11 connection broke (error 1). Did the X11 server die?
Jun 10 00:00:05 hostname xembedsniproxy[738]: The X11 connection broke (error 1). Did the X11 server die?
Jun 10 00:00:05 hostname gmenudbusmenuproxy[734]: The X11 connection broke (error 1). Did the X11 server die?
Jun 10 00:00:05 hostname systemd[548]: Starting KDE Plasma Workspace...
Jun 10 00:00:05 hostname systemd[548]: plasma-kactivitymanagerd.service: Main process exited, code=exited, status=1/FAILURE
Jun 10 00:00:05 hostname systemd[548]: plasma-kactivitymanagerd.service: Failed with result 'exit-code'.
Jun 10 00:00:05 hostname systemd[548]: plasma-polkit-agent.service: Main process exited, code=exited, status=1/FAILURE
Jun 10 00:00:05 hostname systemd[548]: plasma-polkit-agent.service: Failed with result 'exit-code'.
Jun 10 00:00:05 hostname systemd[548]: plasma-xembedsniproxy.service: Main process exited, code=exited, status=1/FAILURE
Jun 10 00:00:05 hostname systemd[548]: plasma-xembedsniproxy.service: Failed with result 'exit-code'.
Jun 10 00:00:05 hostname systemd[548]: plasma-gmenudbusmenuproxy.service: Main process exited, code=exited, status=1/FAILURE
Jun 10 00:00:05 hostname systemd[548]: plasma-gmenudbusmenuproxy.service: Failed with result 'exit-code'.
Jun 10 00:00:05 hostname systemd[548]: app-org.kde.kdeconnect.daemon@autostart.service: Main process exited, code=exited, status=1/FAILURE
Jun 10 00:00:05 hostname systemd[548]: app-org.kde.kdeconnect.daemon@autostart.service: Failed with result 'exit-code'.
Jun 10 00:00:05 hostname systemd[548]: app-kaccess@autostart.service: Main process exited, code=exited, status=1/FAILURE
Jun 10 00:00:05 hostname systemd[548]: app-kaccess@autostart.service: Failed with result 'exit-code'.
Jun 10 00:00:05 hostname systemd[548]: app-pamac\x2dtray\x2dplasma@autostart.service: Main process exited, code=exited, status=1/FAILURE
Jun 10 00:00:05 hostname systemd[548]: app-pamac\x2dtray\x2dplasma@autostart.service: Failed with result 'exit-code'.
Jun 10 00:00:05 hostname systemd[548]: app-pamac\x2dtray\x2dplasma@autostart.service: Consumed 2.341s CPU time.
Jun 10 00:00:05 hostname systemd[548]: plasma-ksmserver.service: Main process exited, code=exited, status=1/FAILURE
Jun 10 00:00:05 hostname systemd[548]: plasma-ksmserver.service: Failed with result 'exit-code'.
Jun 10 00:00:05 hostname systemd[548]: app-org.kde.kwrite-73375ceea14e4488b43e0d8081d864da.scope: Consumed 3.380s CPU time.
Jun 10 00:00:05 hostname systemd[548]: plasma-gmenudbusmenuproxy.service: Scheduled restart job, restart counter is at 1.
Jun 10 00:00:05 hostname systemd[548]: plasma-xembedsniproxy.service: Scheduled restart job, restart counter is at 1.
Jun 10 00:00:05 hostname systemd[548]: plasma-polkit-agent.service: Scheduled restart job, restart counter is at 1.
Jun 10 00:00:05 hostname systemd[548]: Stopped Proxies GTK DBus menus to a Plasma readable format.
Jun 10 00:00:05 hostname systemd[548]: Started Proxies GTK DBus menus to a Plasma readable format.
Jun 10 00:00:05 hostname systemd[548]: Stopped KDE PolicyKit Authentication Agent.
Jun 10 00:00:05 hostname systemd[548]: Starting KDE PolicyKit Authentication Agent...
Jun 10 00:00:05 hostname systemd[548]: Stopped Handle legacy xembed system tray icons.
Jun 10 00:00:05 hostname systemd[548]: Started Handle legacy xembed system tray icons.
Jun 10 00:00:06 hostname org_kde_powerdevil[737]: qt.qpa.wayland: Creating a fake screen in order for Qt not to crash
Jun 10 00:00:06 hostname kded5[642]: qt.qpa.wayland: Creating a fake screen in order for Qt not to crash
Jun 10 00:00:06 hostname kded5[642]: Service ":1.30" unregistered
Jun 10 00:00:06 hostname kded5[642]: Service ":1.31" unregistered
Jun 10 00:00:11 hostname systemd[548]: plasma-polkit-agent.service: start operation timed out. Terminating.
Jun 10 00:00:11 hostname systemd[548]: plasma-polkit-agent.service: Failed with result 'timeout'.
Jun 10 00:00:11 hostname systemd[548]: Failed to start KDE PolicyKit Authentication Agent.
Jun 10 00:00:11 hostname systemd[548]: plasma-polkit-agent.service: Scheduled restart job, restart counter is at 2.
Jun 10 00:00:11 hostname systemd[548]: Stopped KDE PolicyKit Authentication Agent.
Jun 10 00:00:11 hostname systemd[548]: Starting KDE PolicyKit Authentication Agent...
Jun 10 00:00:13 hostname systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Jun 10 00:00:16 hostname systemd[548]: plasma-polkit-agent.service: start operation timed out. Terminating.
Jun 10 00:00:16 hostname systemd[548]: plasma-polkit-agent.service: Failed with result 'timeout'.
Jun 10 00:00:16 hostname systemd[548]: Failed to start KDE PolicyKit Authentication Agent.
Jun 10 00:00:16 hostname systemd[548]: plasma-polkit-agent.service: Scheduled restart job, restart counter is at 3.
Jun 10 00:00:16 hostname systemd[548]: Stopped KDE PolicyKit Authentication Agent.
Jun 10 00:00:16 hostname systemd[548]: Starting KDE PolicyKit Authentication Agent...
Jun 10 00:00:22 hostname systemd[548]: plasma-polkit-agent.service: start operation timed out. Terminating.
Jun 10 00:00:22 hostname systemd[548]: plasma-polkit-agent.service: Failed with result 'timeout'.
Jun 10 00:00:22 hostname systemd[548]: Failed to start KDE PolicyKit Authentication Agent.
Jun 10 00:00:22 hostname systemd[548]: plasma-polkit-agent.service: Scheduled restart job, restart counter is at 4.
Jun 10 00:00:22 hostname systemd[548]: Stopped KDE PolicyKit Authentication Agent.
Jun 10 00:00:22 hostname systemd[548]: Starting KDE PolicyKit Authentication Agent...
Jun 10 00:00:27 hostname systemd[548]: plasma-polkit-agent.service: start operation timed out. Terminating.
Jun 10 00:00:27 hostname systemd[548]: plasma-polkit-agent.service: Failed with result 'timeout'.
Jun 10 00:00:27 hostname systemd[548]: Failed to start KDE PolicyKit Authentication Agent.
Jun 10 00:00:27 hostname systemd[548]: plasma-polkit-agent.service: Scheduled restart job, restart counter is at 5.
Jun 10 00:00:27 hostname systemd[548]: Stopped KDE PolicyKit Authentication Agent.
Jun 10 00:00:27 hostname systemd[548]: Starting KDE PolicyKit Authentication Agent...
Jun 10 00:00:33 hostname systemd[548]: plasma-polkit-agent.service: start operation timed out. Terminating.
Jun 10 00:00:33 hostname systemd[548]: plasma-polkit-agent.service: Failed with result 'timeout'.
Jun 10 00:00:33 hostname systemd[548]: Failed to start KDE PolicyKit Authentication Agent.
Jun 10 00:00:33 hostname systemd[548]: plasma-polkit-agent.service: Scheduled restart job, restart counter is at 6.
Jun 10 00:00:33 hostname systemd[548]: Stopped KDE PolicyKit Authentication Agent.
Jun 10 00:00:33 hostname systemd[548]: Starting KDE PolicyKit Authentication Agent...
Jun 10 00:00:38 hostname systemd[548]: plasma-polkit-agent.service: start operation timed out. Terminating.
Jun 10 00:00:38 hostname systemd[548]: plasma-polkit-agent.service: Failed with result 'timeout'.
Jun 10 00:00:38 hostname systemd[548]: Failed to start KDE PolicyKit Authentication Agent.
Jun 10 00:00:38 hostname systemd[548]: plasma-polkit-agent.service: Scheduled restart job, restart counter is at 7.
Jun 10 00:00:38 hostname systemd[548]: Stopped KDE PolicyKit Authentication Agent.
Jun 10 00:00:38 hostname systemd[548]: Starting KDE PolicyKit Authentication Agent...
Jun 10 00:00:44 hostname systemd[548]: plasma-polkit-agent.service: start operation timed out. Terminating.
Jun 10 00:00:44 hostname systemd[548]: plasma-polkit-agent.service: Failed with result 'timeout'.
Jun 10 00:00:44 hostname systemd[548]: Failed to start KDE PolicyKit Authentication Agent.
Jun 10 00:00:44 hostname systemd[548]: plasma-polkit-agent.service: Scheduled restart job, restart counter is at 8.
Jun 10 00:00:44 hostname systemd[548]: Stopped KDE PolicyKit Authentication Agent.
Jun 10 00:00:44 hostname systemd[548]: Starting KDE PolicyKit Authentication Agent...
Jun 10 00:00:45 hostname systemd[548]: plasma-plasmashell.service: start operation timed out. Terminating.
Jun 10 00:00:45 hostname systemd[548]: plasma-plasmashell.service: Failed with result 'timeout'.
Jun 10 00:00:45 hostname systemd[548]: Failed to start KDE Plasma Workspace.
Jun 10 00:00:46 hostname systemd[548]: plasma-plasmashell.service: Scheduled restart job, restart counter is at 2.
Jun 10 00:00:46 hostname systemd[548]: Stopped KDE Plasma Workspace.
Jun 10 00:00:46 hostname systemd[548]: Starting KDE Plasma Workspace...
Jun 10 00:00:49 hostname systemd[548]: plasma-polkit-agent.service: start operation timed out. Terminating.
Jun 10 00:00:49 hostname kernel: usb 1-4: USB disconnect, device number 3
Jun 10 00:00:49 hostname kernel: usb 1-4.1: USB disconnect, device number 5
Jun 10 00:00:49 hostname kernel: usb 1-4.1.1: USB disconnect, device number 7
Jun 10 00:00:49 hostname systemd[548]: plasma-polkit-agent.service: Failed with result 'timeout'.
Jun 10 00:00:49 hostname systemd[548]: Failed to start KDE PolicyKit Authentication Agent.
Jun 10 00:00:49 hostname systemd[548]: plasma-polkit-agent.service: Scheduled restart job, restart counter is at 9.
Jun 10 00:00:49 hostname systemd[548]: Stopped KDE PolicyKit Authentication Agent.
Jun 10 00:00:49 hostname systemd[548]: Starting KDE PolicyKit Authentication Agent...
Jun 10 00:00:49 hostname kernel: usb 1-4.1.2: USB disconnect, device number 9
Jun 10 00:00:49 hostname kernel: usb 1-4.1.4: USB disconnect, device number 10
Jun 10 00:00:50 hostname kernel: r8152 2-4.2:1.0 enp0s20f0u4u2: Stop submitting intr, status -71
Jun 10 00:00:50 hostname kernel: usb 1-4.3: USB disconnect, device number 6
Jun 10 00:00:50 hostname kernel: usb 2-4: USB disconnect, device number 3
Jun 10 00:00:50 hostname kernel: usb 2-4.1: USB disconnect, device number 4
Jun 10 00:00:50 hostname kernel: r8152-cfgselector 2-4.2: USB disconnect, device number 5
Jun 10 00:00:50 hostname kernel: usb 1-4.4: USB disconnect, device number 8
Jun 10 00:00:50 hostname dbus-daemon[340]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop>
Jun 10 00:00:50 hostname systemd[1]: Starting Network Manager Script Dispatcher Service...
Thanks for any help!
Best Regards
