Manjaro Wont Get Past loading screen unless I open Logs
So recently on my XPS 15 9510 I have tried installing Manjaro on it, everything is fine until I restart.
When starting up Manjaro on my laptop it gets to the Dell logo, and then reloads to the Dell and Manjaro loading screen with the 3 dots. During this time I can use Arrow Key to open Logs or use Escape Key. If I dont do anything the screen reloads (not sure what else to call it but it goes black, and makes the Manjaro Logo at the bottom bigger same with the Dell Logo) Once it “reloads” nothing works, logs, CTRL+ALT+F2 nothing, just loads with the three dots moving as they normally do. However if before this “reload” I press F2 or ESC it shows logs, and loads in normally.
Not sure what to do since this is a fresh install
I am brand new to Linux! So I would appreciate the help!
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information.
  1. Please press the three dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
Have you already :mag: for your problem in the forum ? (Wisdom lies in asking → listening → reading :wink: )
