runlevel 3 keeps networking on … so if you have saved wifi profile it should be connected
( you can test with something like ping 8.8.8.8 [and exit with ctrl+c] )
it says “ping: connect: Network is unreachable” after ping 8.8.8.8
OK … that means no network.
You could go through the manual wifi connection attempts … or find an ethernet chord…
Or moveo n to the USB+chroot I suppose.
ok im using the chroot method in a live usb, its saying “operation to slow. less then one bytes/sec transfered in the last 10 seconds7” does that mean my wifi is to slow to preform an update?
Maybe.
Or theres something wrong with the connection.
Or you need to sort your mirrors.
I suggest updating like
sudo pacman-mirrors -f && sudo pacman -Syyu
i think its the wifi… i will try updating in the morning. Thanks again for all your help.
ok so its the next morning and the wifi is working a lot better, i was browsing the forum and came across a post and it sounds like his problem was with drivers, how would i update/install new drivers? Also ran
and it seems the system is up to date now, but its still not booting.
