Hi, I have just updated manjaro and it won’t boot up,
It stuck(I am in unstable branch btw)
Hi @MHT130, and welcome!
I’m going to tell you that if you don’t know what to do in this situation, you shouldn’t use the unstable branch, as that’s, well, unstable and could lead to breakages.
That said, I recommend you chroot
into your system, change to the stable branch, and resync your system.
How to chroot
Ensure you’ve got a relatively new ISO or at least one with a still supported LTS kernel.
Write/copy/
dd
the ISO to a USB thumb drive. -
When done, boot with the above mentioned USB thumb drive into the live environment.
Once booted, open a terminal and enter the following command to enter the
chroot
encironment:
manjaro-chroot -a
- If you have more than one Linux installation, select the correct one to use from the list provided.
When done, you should now be in the chroot
environment.
But, be careful, as you’re now in an actual root environment on your computer, so any changes you make will persist after a restart.
If successful, change to the stable branch by running:
sudo pacman-mirrors --api --set-branch stable
Followed by updating your mirror list and syncing your system:
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
Hope this helps!
Edit:
Further reading:
Tnx, I wasn’t using unstable branch since recently, I got into unstable because dota2 freezes on libx11 1.8.4 and I wanted to install new version
IMHO not worth it. But you’ll have to decide for yourself.
