No I don’t… can you run me through the steps please? Also from what I understood /var/run was a symlink to /run thats why I didnt think it was important…
It shows my filesystem… I think I should rename the run.bak symlink back to its original name… but I will await confirmation as to not mess anything more up…
The other issue I see here is the folder /var/run which doesn’t exist in my installation. Is it possible that you created that folder? If so I assume it’s safe to remove it and revert run.bak to run by: mv /var/run.bak /var/run
