Manjaro with Luks + LVM and XFCE takes one hour to boot
Hello,
I changed my system SSD to a larger M.2 SSD. Therefore I copied the drive with dd. As a second step I copied my dual-boot windows from one to another SSD.
Everything worked, but then I started windows from the new SSD the first time. Windows did (fully automated) some “reparations” and then booted to desktop.
From this point on, my Manjaro installation was broken: When I started Manjaro first time the after the Windows shutdown, it asks for the passphrase for the LUKS drive. I enterd it. The system shows it was encrypted successfully. And then nothing happens for ~60 minutes and it just shows the screen with the passphrase prompt:
A password is required to access the lvm_desktop1 volume:
Enter passphrase for /dev/nvme0n1p5:
/dev/mapper/lvm_desktop1-root: clean, 884732/13107200 files, 14767013/52420000 blocks
After 60 minutes the XFCE desktop is shown. It was more or less luck, because I left the computer untouched to get to an appointment. When I came back, I saw the booted system.
I have absolutely no clue where to start searching.
I checked this log file for the last boot (from a tutorial):
wolf@wolf-desktop:~$ journalctl --boot=-1 --priority=3 --catalog --no-pager
Nov 12 14:04:52 wolf-desktop systemd-modules-load[435]: Failed to find module 'v4l2loopback-dc'
Nov 12 14:04:52 wolf-desktop systemd-modules-load[435]: Failed to find module 'vboxdrv'
Nov 12 14:04:52 wolf-desktop systemd-modules-load[435]: Failed to find module 'vboxnetadp'
Nov 12 14:04:52 wolf-desktop systemd-modules-load[435]: Failed to find module 'vboxnetflt'
Nov 12 15:03:47 wolf-desktop lightdm[1436]: gkr-pam: couldn't unlock the login keyring.
Nov 12 15:03:48 wolf-desktop pulseaudio[1548]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NameHasNoOwner: Could not activate remote peer 'org.bluez': unit failed
Nov 12 16:01:34 wolf-desktop dbus-broker-launch[1260]: Activation request for 'org.freedesktop.nm_dispatcher' failed.
Nov 12 16:01:36 wolf-desktop kernel: watchdog: watchdog0: watchdog did not stop!
So I would really get my old boot time back. 60 minutes is really long to wait :smiley:
Here we are. Get rid of this nasty destroyer. Or at least don’t mess with it on the same drive.
Not sure quite which part it’s getting hung up on, but I’d be interested to see the results of
systemctl status bluetooth
… when the machine has finally booted. Do you actually use Bluetooth?
It’s quite possible Windows wasn’t fully shut down. This can cause issues with hardware such as this. In an elevated command prompt, in Windows:
powercfg -h off
Cheers! :wink:
Windows is on a different drive.
wolf@wolf-desktop:~$ systemctl status bluetooth
○ bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
     Active: inactive (dead)
       Docs: man:bluetoothd(8)
Nov 12 16:01:38 wolf-desktop systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Nov 12 18:40:46 wolf-desktop systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
Nov 12 18:40:47 wolf-desktop systemd[1]: Bluetooth service was skipped because of an unmet condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
I don’t use bluetooth. To be honest I’m not sure if I really have bluetooth on my desktop. (Motherboard is Gigabyte B550 GAMING X V2 ATX, so no bluetooth)
In that case, maybe try disabling Bluetooth:
sudo systemctl disable bluetooth
You can enable it again if it’s needed. I guess the main issue here is it might not have the desired effect. (It is persistent across reboots).
Or the opposite, if it isn’t running (check with bluetooth list) and if it’s “Off” try substituting enable in the above command.
Note: I’ll ignore the VirtualBox errors until later as I don’t think they are the cause.
I suggest uninstall PulseAudio metapackage and Bluetooth support
pamac remove manjaro-pulse pulsaudio-bluetooth
Can you post more information about your computer ?
inxi -Fza
fdisk -l or blkid ?
The question is: Where is the ESP?
I have a :crystal_ball: that you can borrow.
I have disabled bluetooth, but no change.
wolf@wolf-desktop:~$ inxi -Fza
  Kernel: 6.10.13-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/vmlinuz-6.10-x86_64
    root=/dev/mapper/lvm_desktop1-root rw
    cryptdevice=UUID=75589c4a-2b7d-43f6-a10a-f269d28f7959:lvm_desktop1 quiet
    udev.log_priority=3
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: avail: light-locker,xfce4-screensaver vt: 7 dm:
    1: LightDM v: 1.32.0 2: SDDM note: stopped Distro: Manjaro
    base: Arch Linux
  Type: Desktop System: Gigabyte product: B550 GAMING X V2 v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: B550 GAMING X V2 v: x.x serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: FE
    date: 03/22/2024
  Info: model: AMD Ryzen 5 5600 bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA20120E
    desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 2974 min/max: 2200/4467 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2974 2: 2974 3: 2974
    4: 2974 5: 2974 6: 2974 7: 2974 8: 2974 9: 2974 10: 2974 11: 2974 12: 2974
    bogomips: 83876
    affected
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nouveau v: kernel
    non-free: 550.xx+ status: current (as of 2024-09; EOL~2026-12-xx)
    arch: Pascal code: GP10x process: TSMC 16nm built: 2016-2021 pcie: gen: 1
    speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
    active: DP-1,HDMI-A-1 empty: DVI-D-1 bus-ID: 05:00.0 chip-ID: 10de:1c82
    class-ID: 0300 temp: 32.0 C
  Display: x11 server: X.Org v: 21.1.14 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: modesetting alternate: fbdev,vesa dri: nouveau gpu: nouveau
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 5120x1440 s-dpi: 96 s-size: 1354x381mm (53.31x15.00")
    s-diag: 1407mm (55.38")
  Monitor-1: DP-1 pos: primary,left model: Dell U2518D serial: <filter>
    built: 2017 res: 2560x1440 hz: 60 dpi: 118 gamma: 1.2
    size: 553x311mm (21.77x12.24") diag: 634mm (25") ratio: 16:9 modes:
    max: 2560x1440 min: 720x400
  Monitor-2: HDMI-A-1 mapped: HDMI-1 pos: right model: Dell U2518D
    serial: <filter> built: 2017 res: 2560x1440 hz: 60 dpi: 118 gamma: 1.2
  API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
    device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau x11:
    drv: nouveau inactive: wayland
  API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.2.4-arch1.0.1
    glx-v: 1.4 direct-render: yes renderer: NV137 device-ID: 10de:1c82
    memory: 3.88 GiB unified: no
  Device-1: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s bus-ID: 05:00.1 chip-ID: 10de:0fb9 class-ID: 0403
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 07:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.10.13-3-MANJARO status: kernel-api
  Server-2: PipeWire v: 1.2.5 status: off tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
    lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Info: services: NetworkManager, nfsd, sshd, systemd-timesyncd
  Local Storage: total: 9.77 TiB used: 3.35 TiB (34.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 EVO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 0B2QKXJ7 temp: 37.9 C
    scheme: MBR
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 240 GB
    size: 223.58 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 00RL scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD80EFAX-68KNBN0 size: 7.28 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 0A81
  ID-1: / raw-size: 200 GiB size: 196.55 GiB (98.28%) used: 52.89 GiB (26.9%)
    fs: ext4 dev: /dev/dm-1 maj-min: 254:1 mapped: lvm_desktop1-root
  ID-2: /boot raw-size: 5 GiB size: 4.91 GiB (98.11%)
    used: 500.9 MiB (10.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /boot/efi raw-size: 499 MiB size: 486 MiB (97.40%)
    used: 128.8 MiB (26.5%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-4: /home raw-size: 1.62 TiB size: 259.62 GiB (15.67%)
    used: 212.62 GiB (81.9%) fs: ext4 dev: /dev/dm-2 maj-min: 254:2
    mapped: lvm_desktop1-home
  System Temperatures: cpu: 46.2 C mobo: 30.0 C gpu: nouveau temp: 32.0 C
  Fan Speeds (rpm): N/A
  Memory: total: 64 GiB note: est. available: 62.72 GiB used: 2.7 GiB (4.3%)
  Processes: 357 Power: uptime: 1h 1m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 25.06 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 256
  Packages: 2181 pm: pacman pkgs: 2158 libs: 562 tools: pamac,yay
    pm: flatpak pkgs: 3 pm: snap pkgs: 20 Compilers: clang: 18.1.8 gcc: 14.2.1
    Shell: Bash v: 5.2.37 running-in: tilda inxi: 3.3.36
and
wolf@wolf-desktop:~$ sudo fdisk -l
[sudo] Passwort für wolf:
Festplatte /dev/sda: 465,76 GiB, 500107862016 Bytes, 976773168 Sektoren
Festplattenmodell: Samsung SSD 850
Einheiten: Sektoren von 1 * 512 = 512 Bytes
Sektorgröße (logisch/physikalisch): 512 Bytes / 512 Bytes
E/A-Größe (minimal/optimal): 512 Bytes / 512 Bytes
Festplattenbezeichnungstyp: gpt
Festplattenbezeichner: F8AE0CC8-3B64-4000-960E-308B4EC28A7E
Gerät       Anfang      Ende  Sektoren Größe Typ
/dev/sda1     2048   1023999   1021952  499M Windows-Wiederherstellungsumgebung
/dev/sda2  1024000   1228799    204800  100M EFI-System
/dev/sda3  1228800   1261567     32768   16M Microsoft reserviert
/dev/sda4  1261568 468875263 467613696  223G Microsoft Basisdaten
Festplatte /dev/sdb: 223,58 GiB, 240065183744 Bytes, 468877312 Sektoren
Festplattenmodell: SanDisk SSD PLUS
Festplatte /dev/sdc: 7,28 TiB, 8001563222016 Bytes, 15628053168 Sektoren
Festplattenmodell: WDC WD80EFAX-68K
Sektorgröße (logisch/physikalisch): 512 Bytes / 4096 Bytes
E/A-Größe (minimal/optimal): 4096 Bytes / 4096 Bytes
Festplatte /dev/nvme0n1: 1,82 TiB, 2000398934016 Bytes, 3907029168 Sektoren
Festplattenmodell: Samsung SSD 990 EVO 2TB
Festplattenbezeichnungstyp: dos
Festplattenbezeichner: 0x0006406a
Gerät          Boot   Anfang       Ende   Sektoren Größe Kn Typ
/dev/nvme0n1p1 *        2048    2099199    2097152    1G  b W95 FAT32
/dev/nvme0n1p2       2099200   12584959   10485760    5G 83 Linux
/dev/nvme0n1p3      12584960 3907028991 3894444032  1,8T  5 Erweiterte
/dev/nvme0n1p5      12587008 3907028991 3894441984  1,8T 83 Linux
Festplatte /dev/mapper/lvm_desktop1: 1,81 TiB, 1993952198656 Bytes, 3894437888 Sektoren
Festplatte /dev/mapper/lvm_desktop1-root: 200 GiB, 214748364800 Bytes, 419430400 Sektoren
Festplatte /dev/mapper/lvm_desktop1-home: 1,62 TiB, 1779202785280 Bytes, 3475005440 Sektoren
Festplatte /dev/loop0: 44,3 MiB, 46456832 Bytes, 90736 Sektoren
Festplatte /dev/loop1: 4 KiB, 4096 Bytes, 8 Sektoren
Festplatte /dev/loop2: 103,99 MiB, 109043712 Bytes, 212976 Sektoren
Festplatte /dev/loop3: 104,19 MiB, 109252608 Bytes, 213384 Sektoren
Festplatte /dev/loop4: 55,66 MiB, 58363904 Bytes, 113992 Sektoren
Festplatte /dev/loop5: 55,36 MiB, 58052608 Bytes, 113384 Sektoren
Festplatte /dev/loop6: 63,97 MiB, 67080192 Bytes, 131016 Sektoren
Festplatte /dev/loop7: 63,7 MiB, 66789376 Bytes, 130448 Sektoren
Festplatte /dev/loop8: 74,25 MiB, 77852672 Bytes, 152056 Sektoren
Festplatte /dev/loop9: 73,88 MiB, 77463552 Bytes, 151296 Sektoren
Festplatte /dev/loop10: 164,82 MiB, 172830720 Bytes, 337560 Sektoren
Festplatte /dev/loop11: 164,82 MiB, 172830720 Bytes, 337560 Sektoren
Festplatte /dev/loop12: 218,39 MiB, 228999168 Bytes, 447264 Sektoren
Festplatte /dev/loop13: 218,39 MiB, 228999168 Bytes, 447264 Sektoren
Festplatte /dev/loop14: 349,69 MiB, 366678016 Bytes, 716168 Sektoren
Festplatte /dev/loop15: 349,7 MiB, 366682112 Bytes, 716176 Sektoren
Festplatte /dev/loop16: 496,98 MiB, 521121792 Bytes, 1017816 Sektoren
Festplatte /dev/loop17: 505,09 MiB, 529625088 Bytes, 1034424 Sektoren
Festplatte /dev/loop18: 140 KiB, 143360 Bytes, 280 Sektoren
Festplatte /dev/loop19: 81,26 MiB, 85209088 Bytes, 166424 Sektoren
Festplatte /dev/loop20: 91,69 MiB, 96141312 Bytes, 187776 Sektoren
Festplatte /dev/loop21: 116,48 MiB, 122138624 Bytes, 238552 Sektoren
Festplatte /dev/loop22: 139,75 MiB, 146534400 Bytes, 286200 Sektoren
Festplatte /dev/loop23: 212,1 MiB, 222400512 Bytes, 434376 Sektoren
Festplatte /dev/loop24: 212,24 MiB, 222547968 Bytes, 434664 Sektoren
Festplatte /dev/loop25: 258,67 MiB, 271233024 Bytes, 529752 Sektoren
Festplatte /dev/loop26: 258,67 MiB, 271233024 Bytes, 529752 Sektoren
Festplatte /dev/loop27: 111,53 MiB, 116944896 Bytes, 228408 Sektoren
Festplatte /dev/loop28: 182 MiB, 190844928 Bytes, 372744 Sektoren
Festplatte /dev/loop29: 181,82 MiB, 190648320 Bytes, 372360 Sektoren
Festplatte /dev/loop30: 217,88 MiB, 228462592 Bytes, 446216 Sektoren
Festplatte /dev/loop31: 217,93 MiB, 228519936 Bytes, 446328 Sektoren
Festplatte /dev/loop32: 129,3 MiB, 135581696 Bytes, 264808 Sektoren
Festplatte /dev/loop33: 130,32 MiB, 136646656 Bytes, 266888 Sektoren
Festplatte /dev/mapper/hd_data01: 7,28 TiB, 8001561124864 Bytes, 15628049072 Sektoren
manjaro-pulse removed but pulsaudio-bluetooth was not installed. No change.
wolf@wolf-desktop:~$ sudo pamac remove manjaro-pulse pulsaudio-bluetooth
Fehler: Ziel nicht gefunden: pulsaudio-bluetooth
Vorbereitung...
Abhängigkeiten werden überprüft...
Wird entfernt (1):
  manjaro-pulse  20240817-1    extra
Transaktion anwenden ? [j/N] j
Entferne manjaro-pulse (20240817-1)...        [1/1]
Vorgang erfolgreich abgeschlossen.
You need a second ESP partition.
  • Is your $ESP created within an LVM2 container?
  • You seem to have both MBR/DOS and GPT partitioning schemes defined. This may add complication.
Okay, ESP is the /boot/efi partition, right?
This is how my partition looks like:
So it is NOT insight the lvm2 container.
Why would I need a second ESP?
And how do I fix this? I don’t have the understanding needed of how this all works. :smiley:
I recommend to try another Kernel.
I would also remove quiet from Grub, that you can see where the boot is stuck for so long.
No and Yes.
The /boot/efi is not a partition; in fact, it’s only the mount point that points to the $ESP location. However, the fat32 EFI System Partition (ESP) that it points to should indeed be the $ESP.
In most cases, you don’t (it’s generally not recommended); however, some like to create an extra partition to overcome some perceived difficulties.
That I can’t help you with, but I can point out a few things I’ve noticed, which may be of interest to others wishing to help:
/dev/nvme0n1p3 appears to be an extended partition type. This might indicate that the disk partitions were created atop an MSDOS/MBR partition table. For the purposes of UEFI booting, the $ESP and all patitions need to be created on a GUID Partition Table (GPT).
Because of this, the (ESP) partition would be invalid; just a plain fat32 formatted partition, instead of a fully qualified #ESP.
To further support this, I note that /dev/nvme0n1 clearly shows a DOS/MBR partitioning scheme.
With an LVM2 configuration also thrown into the mix, I don’t know of an easy way to recover from this situation, without a full reinstallation using recommended settings.
Perhaps someone might be kind enough to point you in the right direction; to install Manjaro purely as UEFI; and how to make the correct choices before and during installation.
Manjaro Install media must alo boot in UEFI mode. :eyes:
I’m afraid I might not have the time, or patience.
Good luck.
I found a strange behaviour:
The system boots up perfectly, as soon as I disconnect the windows drive from the motherboard. I tried to describe the problem in the a new thread:
