Hello. I had an update today for Manjaro (did not really pay attention to what it was, said manjaro someting) and something failed and then i only had Video-Nvidia and Video-Nvidia-390xx in my hardware configuration. Then i messed something up so i did a fresh install of Manjaro and now i only have 390xx. I am pretty sure i used 455xx before. Is there anything going on with Manjaro at the moment or is there something i can do to fix this? My knowledge about these kind of things is very limited.
Thanks for your time.
Hello, I think you mean the manjaro-system 20210101-3 update.
Maybe your system got cleaned up and it deleted all the unused nvidia drivers. However I think you can still manually change the drivers.
This should be a good starting point:
How to go to nVidia only:
Log off
Switch to TTY2 by pressing Ctrl+Alt+F2
Log in there
Execute:
mhwd --listinstalled
Execute:
sudo mhwd --remove pci xxx
where xxx are all the lines shown by the previous command
Execute:
sudo mhwd --install pci video-nvidia-440xx
(if your card is supported by the 440 series driver , take another version if not)
Execute:
sudo reboot
Presto! nVidia only! (and the way I run)
Fabby
2 January 2021 10:53
3
Emphasis mine , so please read this:
https://archived.forum.manjaro.org/t/how-to-provide-good-information-in-your-posts/37102
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
an nvidia-smi would also be welcome
I have same issue. I clean installed Manjaro KDE on my PC today and before system update I had option to select nvidia driver 455 from KDE settings (mhwd gui). Now I only have nvidia driver 390.
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=870bf0a7-a4ca-48c1-b438-b9c5511d8203 rw quiet apparmor=1
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Desktop Mobo: MSI model: Z270 PC MATE (MS-7A72) v: 1.0
serial: <filter> UEFI: American Megatrends v: 1.A0 date: 07/04/2018
RAM: total: 7.73 GiB used: 2.3 GiB (29.8%)
Info: Dual Core model: Intel Pentium G4560 bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: DE
L2 cache: 3 MiB bogomips: 28009
Speed: 800 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800
Flags: 3dnowprefetch abm acpi aes aperfmperf apic arat arch_perfmon art bts
clflush clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl
dtes64 dtherm dts epb ept ept_ad erms est flexpriority flush_l1d fpu
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs intel_pt
invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr
pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: NVIDIA GK106 [GeForce GTX 650 Ti] vendor: Micro-Star MSI
driver: nouveau v: kernel alternate: nvidia_drm,nvidia bus ID: 01:00.0
chip ID: 10de:11c6
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: nouveau
unloaded: modesetting alternate: fbdev,nv,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 2880x900 s-dpi: 96 s-size: 762x238mm (30.0x9.4")
s-diag: 798mm (31.4")
Monitor-1: DVI-I-1 res: 1440x900 dpi: 89 size: 410x257mm (16.1x10.1")
diag: 484mm (19.1")
Monitor-2: DVI-D-1 res: 1440x900 hz: 60 dpi: 90 size: 408x255mm (16.1x10.0")
diag: 481mm (18.9")
OpenGL: renderer: NVE6 v: 4.3 Mesa 20.3.1 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a2f0
Device-2: NVIDIA GK106 HDMI Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0e0b
Sound Server: ALSA v: k5.10.2-2-MANJARO
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: f000 bus ID: 00:1f.6 chip ID: 8086:15b8
IF: enp0s31f6 state: up speed: 100 Mbps duplex: full mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
Local Storage: total: 698.65 GiB used: 10.81 GiB (1.5%)
model: SSD 970 EVO Plus 250GB size: 232.89 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 2B2QEXM7
temp: 32.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500DM002-1BD142
size: 465.76 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: KC44
ID-1: / raw size: 232.38 GiB size: 232.27 GiB (99.95%)
used: 10.81 GiB (4.7%) fs: xfs dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 870bf0a7-a4ca-48c1-b438-b9c5511d8203
ID-2: /boot/efi raw size: 512 MiB size: 511 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: F38A-AE5E
ID-1: /dev/sda1 maj-min: 8:1 size: 465.75 GiB fs: ntfs label: N/A
uuid: 20FC5B65FC5B346E
Hub: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Device-1: 1-11:2 info: Microsoft Wired Keyboard 600 (model 1576)
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 1.5 Mb/s chip ID: 045e:07f8
Device-2: 1-12:3 info: A4Tech USB Device type: Keyboard,Mouse,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s
chip ID: 09da:768c
Hub: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.0 speed: 5 Gb/s
chip ID: 1d6b:0003
Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s
chip ID: 1d6b:0002
Hub: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 26.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1080
Processes: 191 Uptime: 16m wakeups: 0 Init: systemd v: 247 Compilers:
gcc: N/A Packages: pacman: 1227 lib: 373 flatpak: 0 Shell: Bash v: 5.1.0
running in: konsole inxi: 3.2.01```
nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
Understandable because I’m using nouveau now
mhwd
NAME VERSION FREEDRIVER TYPE
video-nvidia-390xx 2020.11.30 false PCI
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
I can add that this problem is not related to kernel update because I didn’t had 455 version on stock linux-5.9 too. My card is supported by 455 version.
Fabby
2 January 2021 19:49
5
No you don’t:
t0ssox:
So that’s normal with nouveau.
t0ssox:
I have same issue.
So what’s the problem? What doesn’t work???
What doesn’t work? I can’t install latest nvidia drivers (455). After installing that available 390 my GPU is very slow and when I’m launching any game I have literally 4 fps.
Have you installed the 390 drivers? What you uploaded says you are using the nouveau drivers or was that before?
I did a clean install using proprietary drivers and then 455 did install. When i starten to updade it was back just showing 390 but it seemes like 455 is installed and beeing used. Might just be in the hardware configuration there is some issues.
That was been before (when I posted those logs). After installing those 390 drivers mhwd still not showing any newer version available and system went to be very unstable and lagging everywhere. Going back to open source drivers (nouveau) fixed this performance problem (but you know, still not like true proprietary drivers. Still there is problem with only 390 driver showing.
cscs
3 January 2021 01:06
10
find /var/lib/mhwd -type f -name "*.old"
t0ssox
3 January 2021 01:41
11
I will not help further because I changed distro but will back if those nvidia issues will be resolved.
cscs
3 January 2021 01:46
12
cant solve if you leave and refuse to provide information or follow directions.
have fun wherever you are
