Manjaro update failing
Hello,
could anyone help with #pacman -Syu
It keeps failing at some point.
(150/320) upgrading kirigami2 [######################] 100%
(151/320) upgrading plasma-framework [######################] 100%
(152/320) installing ttf-comfortaa [######################] 100%
(153/320) upgrading less [######################] 100%
(154/320) upgrading calamares [######################] 100%
(155/320) upgrading fmt [######################] 100%
(156/320) upgrading xmlsec [######################] 100%
(157/320) upgrading ceph-libs [######################] 100%
(158/320) upgrading chromaprint [######################] 100%
(159/320) upgrading tevent [######################] 100%
(160/320) upgrading ldb [######################] 100%
(161/320) upgrading smbclient [######################] 100%
(162/320) upgrading cifs-utils [######################] 100%
(163/320) upgrading gcc [######################] 100%
error: could not extract /usr/lib/gcc/x86_64-pc-linux-gnu/12.2.0/cc1plus (Write failed)
error: could not extract /usr/lib/gcc/x86_64-pc-linux-gnu/12.2.0/collect2 (Write failed)
error: could not extract /usr/lib/gcc/x86_64-pc-linux-gnu/12.2.0/crtbegin.o (Write failed)
error: could not extract /usr/lib/gcc/x86_64-pc-linux-gnu/12.2.0/crtbeginS.o (Write failed)
error: could not extract /usr/lib/gcc/x86_64-pc-linux-gnu/12.2.0/crtbeginT.o (Write failed)
error: could not extract /usr/lib/gcc/x86_64-pc-linux-gnu/12.2.0/crtend.o (Write failed)
error: could not extract /usr/lib/gcc/x86_64-pc-linux-gnu/12.2.0/crtendS.o (Write failed)
error: could not extract /usr/lib/gcc/x86_64-pc-linux-gnu/12.2.0/crtfastmath.o (Write failed)
error: could not extract /usr/lib/gcc/x86_64-pc-linux-gnu/12.2.0/crtprec32.o (Write failed)
error: could not extract /usr/lib/gcc/x86_64-pc-linux-gnu/12.2.0/crtprec64.o (Write failed)
error: could not extract /usr/lib/gcc/x86_64-pc-linux-gnu/12.2.0/crtprec80.o (Write failed)
error: could not extract /usr/lib/gcc/x86_64-pc-linux-gnu/12.2.0/include-fixed/README (Write failed)
error: could not extract /usr/lib/gcc/x86_64-pc-linux-gnu/12.2.0/include-fixed/limits.h (Write failed)
error: problem occurred while upgrading gcc
error: could not commit transaction
error: failed to commit transaction (transaction aborted)
Hi @iTom79, and welcome!
This indicates that it could not write in the directory, which in turn would be a permissions problem. Indeed, if you executed
pacman -Syu
…without sudo this would be the case. Try:
sudo pacman -Syu
…instead. Or as I always recommendd, use pamac instead of pacman:
pamac upgrade --enable-downgrade --aur --devel
Hope it helps!
Tip:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
Might be a full disk
A post was split to a new topic: Ceph-libs build problem
