Ok, but a little elaboration please. Debian Grub is also fairly complicated. In the coming days I will diff
the two concerned grub.cfg files to evaluate how difficult manjaro grub is in comparison to Debian grub. But some initial input would definitely help.
I have no issues letting manjaro grub have the 1st control. I could always, I assume, have the grub.cfg modified to have Debian and Knoppix lines included there.
No, not very very old or legacy. My laptop’s hardinfo report is attached. I would have liked to attach a text document, but I am not sure if a text file could be attached. So am compelled to post the hardinfo report herein, bloating the posting.
Computer
Summary
-Computer-
Processor : Intel(R) Core(TM) i3-4005U CPU @ 1.70GHz
Memory : 3950MB (2640MB used)
Machine Type : Notebook
Operating System : Debian GNU/Linux 11 (bullseye)
User Name : root (root)
Date/Time : Mon 29 May 2023 07:28:20 AM IST
-Display-
Resolution : 1366x768 pixels
OpenGL Renderer : Mesa DRI Intel(R) HD Graphics 4400 (HSW GT2)
X11 Vendor : The X.Org Foundation
-Audio Devices-
Audio Adapter : HDA-Intel - HDA Intel HDMI
Audio Adapter : HDA-Intel - HDA Intel PCH
-Input Devices-
AT Translated Set 2 keyboard
Lid Switch
Power Button
Power Button
Video Bus
SynPS/2 Synaptics TouchPad
YSPRINGTECH USB OPTICAL MOUSE
HP Wireless hotkeys
PC Speaker
HP WMI hotkeys
HDA Intel HDMI HDMI/DP,pcm:3
HDA Intel HDMI HDMI/DP,pcm:7
HDA Intel HDMI HDMI/DP,pcm:8
HDA Intel HDMI HDMI/DP,pcm:9
HDA Intel HDMI HDMI/DP,pcm:10
HDA Digital PCBeep
HDA Intel PCH Mic
HDA Intel PCH Headphone
HP Truevision HD: HP Truevision
-Printers-
No printers found
Display
-Display-
Version : 1.20.11
Current Display Name : :0
-Monitors-
Monitor 0 : 1366x768 pixels
-OpenGL-
Vendor : Intel Open Source Technology Center
Version : 3.0 Mesa 20.3.5
Direct Rendering : Yes
-Extensions-
Composite
DAMAGE
DOUBLE-BUFFER
DPMS
DRI2
DRI3
GLX
Generic Event Extension
MIT-SCREEN-SAVER
MIT-SHM
Present
RANDR
RECORD
RENDER
SECURITY
SHAPE
SYNC
X-Resource
XC-MISC
XFIXES
XFree86-DGA
XFree86-VidModeExtension
XINERAMA
XInputExtension
XKEYBOARD
XTEST
XVideo
default screen number: 0
Devices
Processor
-Processors-
Package Information
Intel(R) Core(TM) i3-4005U CPU @ 1.70GHz 0 0:0 1600.00 MHz
Intel(R) Core(TM) i3-4005U CPU @ 1.70GHz 1 0:1 1600.00 MHz
Intel(R) Core(TM) i3-4005U CPU @ 1.70GHz 2 0:0 1600.00 MHz
Intel(R) Core(TM) i3-4005U CPU @ 1.70GHz 3 0:1 1600.00 MHz
Memory
-Memory-
MemTotal Total Memory 3950768 KiB
MemFree Free Memory 373996 KiB
MemAvailable 847500 KiB
Buffers 59448 KiB
Cached 867476 KiB
SwapCached Cached Swap 92996 KiB
Active 1524084 KiB
Inactive 1768432 KiB
Active(anon) 1129832 KiB
Inactive(anon) 1508472 KiB
Active(file) 394252 KiB
Inactive(file) 259960 KiB
Unevictable 17908 KiB
Mlocked 64 KiB
SwapTotal Virtual Memory 19529724 KiB
SwapFree Free Virtual Memory 18675152 KiB
Dirty 688 KiB
Writeback 0 KiB
AnonPages 2307948 KiB
Mapped 377120 KiB
Shmem 272688 KiB
KReclaimable 52180 KiB
Slab 125088 KiB
SReclaimable 52180 KiB
SUnreclaim 72908 KiB
KernelStack 13344 KiB
PageTables 38888 KiB
NFS_Unstable 0 KiB
Bounce 0 KiB
WritebackTmp 0 KiB
CommitLimit 21505108 KiB
Committed_AS 8628856 KiB
VmallocTotal -1 KiB
VmallocUsed 46356 KiB
VmallocChunk 0 KiB
Percpu 2960 KiB
HardwareCorrupted 0 KiB
AnonHugePages 206848 KiB
ShmemHugePages 0 KiB
ShmemPmdMapped 0 KiB
FileHugePages 0 KiB
FilePmdMapped 0 KiB
HugePages_Total 0
HugePages_Free 0
HugePages_Rsvd 0
HugePages_Surp 0
Hugepagesize 2048 KiB
Hugetlb 0 KiB
DirectMap4k 269372 KiB
DirectMap2M 3850240 KiB
DirectMap1G 1048576 KiB
PCI Devices
-PCI Devices-
Host bridge : Intel Corporation Haswell-ULT DRAM Controller (rev 0b)
VGA compatible controller : Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 0b) (prog-if 00 [VGA controller])
Audio device : Intel Corporation Haswell-ULT HD Audio Controller (rev 0b)
Signal processing controller : Intel Corporation Haswell-ULT Thermal Subsystem (rev 0b)
USB controller : Intel Corporation 8 Series USB xHCI HC (rev 04) (prog-if 30 [XHCI])
Communication controller : Intel Corporation 8 Series HECI #0 (rev 04)
Audio device : Intel Corporation 8 Series HD Audio Controller (rev 04)
PCI bridge : Intel Corporation 8 Series PCI Express Root Port 1 (rev e4) (prog-if 00 [Normal decode])
PCI bridge : Intel Corporation 8 Series PCI Express Root Port 3 (rev e4) (prog-if 00 [Normal decode])
PCI bridge : Intel Corporation 8 Series PCI Express Root Port 5 (rev e4) (prog-if 00 [Normal decode])
PCI bridge : Intel Corporation 8 Series PCI Express Root Port 6 (rev e4) (prog-if 00 [Normal decode])
ISA bridge : Intel Corporation 8 Series LPC Controller (rev 04)
SATA controller : Intel Corporation 8 Series SATA Controller 1 [AHCI mode] (rev 04) (prog-if 01 [AHCI 1.0])
SMBus : Intel Corporation 8 Series SMBus Controller (rev 04)
Signal processing controller : Intel Corporation 8 Series Thermal (rev 04)
Ethernet controller : Realtek Semiconductor Co., Ltd. RTL810xE PCI Express Fast Ethernet controller (rev 07)
Display controller : Advanced Micro Devices, Inc. [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile] (rev 83)
Network controller : Broadcom Inc. and subsidiaries BCM43142 802.11b/g/n (rev 01)
USB Devices
-USB Devices-
Linux Foundation 3.0 root hub
Chicony Electronics Co., Ltd HP Truevision HD
Broadcom Corp. BCM43142A0 Bluetooth 4.0
Xiaomi Inc. Mi/Redmi series (RNDIS)
Silicon Labs USB OPTICAL MOUSE
Linux Foundation 2.0 root hub
Printers
-Printers-
No printers found
Battery
-Battery: BAT1-
State : Charging
Capacity : 90 / Normal
Battery Technology : Li-ion
Manufacturer : COMPAL
Model Number : PABAS0241231
Serial Number : 41167
Sensors
-Sensors-
../../thermal_zone0/temp1 Temperature 27.80°C
../../BAT1/in0 Voltage 16.66V
../../thermal_zone2/temp1 Temperature 48.00°C
coretemp/temp1 Temperature 55.00°C
coretemp/temp2 Temperature 52.00°C
coretemp/temp3 Temperature 50.00°C
thermal/thermal_zone2 Temperature 48.00°C
thermal/thermal_zone0 Temperature 27.80°C
thermal/thermal_zone3 Temperature 54.05°C
thermal/thermal_zone1 Temperature 20.00°C
thermal/thermal_zone4 Temperature 54.00°C
Input Devices
-Input Devices-
Lid Switch
Power Button
Power Button
Video Bus
HP Wireless hotkeys
PC Speaker
HP WMI hotkeys
HDA Digital PCBeep
HDA Intel PCH Mic
Storage
DMI
-Product-
Name : HP Notebook (Hewlett-Packard, www.hp.com)
Family : 103C_5335KV G=N L=CON B=HP (Hewlett-Packard, www.hp.com)
Vendor : Hewlett-Packard (Hewlett-Packard, www.hp.com)
Version : Type1ProductConfigId
-BIOS-
Date : 03/24/2015
Vendor : Insyde
Version : F.02
-Board-
Version : 96.02
Serial Number : PFEJDH31W8PJJ9
Asset Tag : Type2 - Board Asset Tag
-Chassis-
Type : [10] Notebook
Version : Chassis Version
Serial Number : Chassis Serial Number
Asset Tag : Chassis Asset Tag
Memory SPD
-SPD-
Please load the eeprom module to obtain information about memory SPD
Resources
-I/O Ports-
<tt>0000-0cf7 </tt> : PCI Bus 0000:00
<tt> 0000-001f </tt> : dma1
<tt> 0020-0021 </tt> : pic1
<tt> 0040-0043 </tt> : timer0
<tt> 0050-0053 </tt> : timer1
<tt> 0060-0060 </tt> : keyboard
<tt> 0062-0062 </tt> : PNP0C09:00
<tt> 0062-0062 </tt> : EC data
<tt> 0064-0064 </tt> : keyboard
<tt> 0066-0066 </tt> : PNP0C09:00
<tt> 0066-0066 </tt> : EC cmd
<tt> 0070-0077 </tt> : rtc0
<tt> 0080-008f </tt> : dma page reg
<tt> 00a0-00a1 </tt> : pic2
<tt> 00c0-00df </tt> : dma2
<tt> 00f0-00ff </tt> : fpu
<tt> 03c0-03df </tt> : vga+
<tt> 0680-069f </tt> : pnp 00:00
<tt>0cf8-0cff </tt> : PCI conf1
<tt>0d00-ffff </tt> : PCI Bus 0000:00
<tt> 164e-164f </tt> : pnp 00:00
<tt> 1800-18fe </tt> : pnp 00:00
<tt> 1800-1803 </tt> : ACPI PM1a_EVT_BLK
<tt> 1804-1805 </tt> : ACPI PM1a_CNT_BLK
<tt> 1808-180b </tt> : ACPI PM_TMR
<tt> 1810-1815 </tt> : ACPI CPU throttle
<tt> 1830-1833 </tt> : iTCO_wdt.1.auto
<tt> 1830-1833 </tt> : <b><small>Module</small></b> Intel TCO WatchDog Timer Driver
<tt> 1850-1850 </tt> : ACPI PM2_CNT_BLK
<tt> 1854-1857 </tt> : pnp 00:02
<tt> 1860-187f </tt> : iTCO_wdt.1.auto
<tt> 1860-187f </tt> : <b><small>Module</small></b> Intel TCO WatchDog Timer Driver
<tt> 1880-189f </tt> : ACPI GPE0_BLK
<tt> 2000-2fff </tt> : PCI Bus 0000:01
<tt> 3000-3fff </tt> : PCI Bus 0000:03
<tt> 3000-30ff </tt> : <b><small>PCI</small></b> Advanced Micro Devices, Inc. [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile] (rev 83)
<tt> 4000-4fff </tt> : PCI Bus 0000:02
<tt> 4000-40ff </tt> : <b><small>PCI</small></b> Realtek Semiconductor Co., Ltd. RTL810xE PCI Express Fast Ethernet controller (rev 07)
<tt> 5000-503f </tt> : <b><small>PCI</small></b> Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 0b) (prog-if 00 [VGA controller])
<tt> 5040-505f </tt> : <b><small>PCI</small></b> Intel Corporation 8 Series SMBus Controller (rev 04)
<tt> 5040-505f </tt> : i801_smbus
<tt> 5060-507f </tt> : <b><small>PCI</small></b> Intel Corporation 8 Series SATA Controller 1 [AHCI mode] (rev 04) (prog-if 01 [AHCI 1.0])
<tt> 5060-507f </tt> : <b><small>Module</small></b> AHCI SATA low-level driver
<tt> 5080-5087 </tt> : <b><small>PCI</small></b> Intel Corporation 8 Series SATA Controller 1 [AHCI mode] (rev 04) (prog-if 01 [AHCI 1.0])
<tt> 5080-5087 </tt> : <b><small>Module</small></b> AHCI SATA low-level driver
<tt> 5088-508f </tt> : <b><small>PCI</small></b> Intel Corporation 8 Series SATA Controller 1 [AHCI mode] (rev 04) (prog-if 01 [AHCI 1.0])
<tt> 5088-508f </tt> : <b><small>Module</small></b> AHCI SATA low-level driver
<tt> 5090-5093 </tt> : <b><small>PCI</small></b> Intel Corporation 8 Series SATA Controller 1 [AHCI mode] (rev 04) (prog-if 01 [AHCI 1.0])
<tt> 5090-5093 </tt> : <b><small>Module</small></b> AHCI SATA low-level driver
<tt> 5094-5097 </tt> : <b><small>PCI</small></b> Intel Corporation 8 Series SATA Controller 1 [AHCI mode] (rev 04) (prog-if 01 [AHCI 1.0])
<tt> 5094-5097 </tt> : <b><small>Module</small></b> AHCI SATA low-level driver
<tt> 6000-6fff </tt> : PCI Bus 0000:04
<tt> fd60-fd63 </tt> : pnp 00:00
<tt> ffff-ffff </tt> : pnp 00:00
-Memory-
<tt>00000000-00000fff </tt> : Reserved
<tt>00001000-0009e7ff </tt> : System RAM
<tt>0009e800-0009ffff </tt> : Reserved
<tt>000a0000-000bffff </tt> : PCI Bus 0000:00
<tt>000c0000-000cfdff </tt> : Video ROM
<tt>000e0000-000fffff </tt> : Reserved
<tt> 000f0000-000fffff </tt> : System ROM
<tt>00100000-9c10dfff </tt> : System RAM
<tt> 8b200000-8be01e47 </tt> : Kernel code
<tt> 8c000000-8c760fff </tt> : Kernel rodata
<tt> 8c800000-8ca7a2bf </tt> : Kernel data
<tt> 8d0a9000-8d5fffff </tt> : Kernel bss
<tt>9c10e000-9cc8dfff </tt> : Reserved
<tt>9cc8e000-9cf8dfff </tt> : ACPI Non-volatile Storage
<tt>9cf8e000-9cffdfff </tt> : ACPI Tables
<tt>9cffe000-9cffefff </tt> : System RAM
<tt>9cfff000-9f9fffff </tt> : Reserved
<tt> 9cfff000-9cffffff </tt> : MSFT0101:00
<tt> 9da00000-9f9fffff </tt> : Graphics Stolen Memory
<tt>9fa00000-feafffff </tt> : PCI Bus 0000:00
<tt> 9fa00000-9fa0ffff </tt> : pnp 00:06
<tt> 9fa10000-9fa1ffff </tt> : pnp 00:06
<tt> 9fb00000-9fcfffff </tt> : PCI Bus 0000:01
<tt> 9fd00000-9fefffff </tt> : PCI Bus 0000:01
<tt> a0000000-afffffff </tt> : PCI Bus 0000:03
<tt> a0000000-afffffff </tt> : <b><small>PCI</small></b> Advanced Micro Devices, Inc. [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile] (rev 83)
<tt> b0000000-bfffffff </tt> : <b><small>PCI</small></b> Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 0b) (prog-if 00 [VGA controller])
<tt> c0000000-c03fffff </tt> : <b><small>PCI</small></b> Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 0b) (prog-if 00 [VGA controller])
<tt> c0400000-c04fffff </tt> : PCI Bus 0000:02
<tt> c0400000-c0403fff </tt> : <b><small>PCI</small></b> Realtek Semiconductor Co., Ltd. RTL810xE PCI Express Fast Ethernet controller (rev 07)
<tt> c0500000-c05fffff </tt> : PCI Bus 0000:04
<tt> c0500000-c0507fff </tt> : <b><small>PCI</small></b> Broadcom Inc. and subsidiaries BCM43142 802.11b/g/n (rev 01)
<tt> c0500000-c0507fff </tt> : bcma-pci-bridge
<tt> c0600000-c06fffff </tt> : PCI Bus 0000:03
<tt> c0600000-c063ffff </tt> : <b><small>PCI</small></b> Advanced Micro Devices, Inc. [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile] (rev 83)
<tt> c0640000-c065ffff </tt> : <b><small>PCI</small></b> Advanced Micro Devices, Inc. [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile] (rev 83)
<tt> c0700000-c07fffff </tt> : PCI Bus 0000:02
<tt> c0700000-c0700fff </tt> : <b><small>PCI</small></b> Realtek Semiconductor Co., Ltd. RTL810xE PCI Express Fast Ethernet controller (rev 07)
<tt> c0700000-c0700fff </tt> : <b><small>Module</small></b> RealTek RTL-8169 Gigabit Ethernet driver
<tt> c0800000-c080ffff </tt> : <b><small>PCI</small></b> Intel Corporation 8 Series USB xHCI HC (rev 04) (prog-if 30 [XHCI])
<tt> c0800000-c080ffff </tt> : xhci-hcd
<tt> c0810000-c0817fff </tt> : <b><small>PCI</small></b> Intel Corporation Haswell-ULT Thermal Subsystem (rev 0b)
<tt> c0818000-c081bfff </tt> : <b><small>PCI</small></b> Intel Corporation Haswell-ULT HD Audio Controller (rev 0b)
<tt> c0818000-c081bfff </tt> : ICH HD audio
<tt> c081c000-c081ffff </tt> : <b><small>PCI</small></b> Intel Corporation 8 Series HD Audio Controller (rev 04)
<tt> c081c000-c081ffff </tt> : ICH HD audio
<tt> c0820000-c08200ff </tt> : <b><small>PCI</small></b> Intel Corporation 8 Series SMBus Controller (rev 04)
<tt> c0821000-c082101f </tt> : <b><small>PCI</small></b> Intel Corporation 8 Series HECI #0 (rev 04)
<tt> c0821000-c082101f </tt> : <b><small>Module</small></b> Intel(R) Management Engine Interface
<tt> c0823000-c0823fff </tt> : <b><small>PCI</small></b> Intel Corporation 8 Series Thermal (rev 04)
<tt> c0823000-c0823fff </tt> : Intel PCH thermal driver
<tt> c0824000-c08247ff </tt> : <b><small>PCI</small></b> Intel Corporation 8 Series SATA Controller 1 [AHCI mode] (rev 04) (prog-if 01 [AHCI 1.0])
<tt> c0824000-c08247ff </tt> : <b><small>Module</small></b> AHCI SATA low-level driver
<tt> c0900000-c0afffff </tt> : PCI Bus 0000:04
<tt> e0000000-efffffff </tt> : PCI MMCONFIG 0000 [bus 00-ff]
<tt> e0000000-efffffff </tt> : Reserved
<tt> e0000000-efffffff </tt> : pnp 00:06
<tt>feb00000-feb03fff </tt> : Reserved
<tt>fec00000-fec00fff </tt> : Reserved
<tt> fec00000-fec003ff </tt> : IOAPIC 0
<tt>fed00000-fed003ff </tt> : HPET 0
<tt> fed00000-fed003ff </tt> : PNP0103:00
<tt>fed10000-fed19fff </tt> : Reserved
<tt> fed10000-fed17fff </tt> : pnp 00:06
<tt> fed18000-fed18fff </tt> : pnp 00:06
<tt> fed19000-fed19fff </tt> : pnp 00:06
<tt>fed1c000-fed1ffff </tt> : Reserved
<tt> fed1c000-fed1ffff </tt> : pnp 00:06
<tt> fed1f410-fed1f414 </tt> : iTCO_wdt.1.auto
<tt> fed1f410-fed1f414 </tt> : iTCO_wdt.1.auto iTCO_wdt.1.auto
<tt> fed1f800-fed1f9ff </tt> : intel-spi
<tt>fed20000-fed3ffff </tt> : pnp 00:06
<tt>fed70000-fed70fff </tt> : MSFT0101:00
<tt>fed90000-fed93fff </tt> : pnp 00:06
<tt>fee00000-fee00fff </tt> : Local APIC
<tt> fee00000-fee00fff </tt> : Reserved
<tt>ff000000-ff000fff </tt> : pnp 00:06
<tt>ff010000-ffffffff </tt> : INT0800:00
<tt> ffa00000-ffffffff </tt> : Reserved
<tt>100000000-15f5fffff </tt> : System RAM
<tt>15f600000-15fffffff </tt> : RAM buffer
-DMA-
<tt> 4</tt> : cascade
The system has VEFI which Doze used, but I have removed Doze and have installed a new HDD.
I use the legacy boot option as I am not conversant with VEFI boot.
I just want to keep things simple, within my comprehension.
No offence taken. I am aware and fully relaxed that I will remain a perpetual novice in computing related matters. Actually, I don’t want to unduly mess with systems. I just want to have a system and do my work, which is mostly text editing, watching videos and mathematical data processing.
I prefer a WM as I don’t want to waste system resources in undue ornamentation of my system so long as it remains functional.
We have already had a thorough conversation on OpenBox and LXDE. I won’t use OpenBox that isn’t under active development (as is LXDE). Like Debian LXDE comes packed with OpenBox WM, I expected KDE Fusion to have some WM packed with it, so that I could most of the time use the WM, only returning to full-fledged DE when special setting up demands it.
Yes, thought so. Thank you very much for responding to my messages.
