Manjaro themed mpv skin
I decided to post my current MPV configuration here. Anyone who wants to can download and use it. The colour scheme has been adapted to the Manjaro theme. Currently, the options are set to ensure the best possible playback quality. I downloaded the script from GitHub and modified it slightly.
Here is a preview.
Here is file.
A question about the shader path:
What exactly do the path specifications in mpv.conf mean?
glsl-shader="~~/shaders/nnedi3-nns128-win8x4.hook"
glsl-shader="~~/shaders/ArtCNN_C4F32.glsl"
This path information confuses me a bit.
Where exactly in the home-directory does the shaders folder need to be copied?
It doesn’t really have any business in /home/vidar/.config/mpv/, does it? The path also says something completely different.
This is where you should copy the contents of the archive.
Matcha-azul based theme is here.
