Nov 02 07:59:09 creapermann-g33500 kernel: x86/cpu: SGX disabled by BIOS.
Nov 02 07:59:09 creapermann-g33500 kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Nov 02 07:59:09 creapermann-g33500 kernel: #7 #8 #9 #10 #11
Nov 02 07:59:09 creapermann-g33500 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Nov 02 07:59:09 creapermann-g33500 kernel: hpet_acpi_add: no address or irqs in _CRS
Nov 02 07:59:09 creapermann-g33500 kernel: i8042: Warning: Keylock active
Nov 02 07:59:09 creapermann-g33500 kernel: usb: port power management may be unreliable
Nov 02 07:59:09 creapermann-g33500 kernel: vboxdrv: loading out-of-tree module taints kernel.
Nov 02 07:59:09 creapermann-g33500 kernel: VBoxNetAdp: Successfully started.
Nov 02 07:59:09 creapermann-g33500 kernel: VBoxNetFlt: Successfully started.
Nov 02 07:59:09 creapermann-g33500 systemd-udevd[322]: /etc/udev/rules.d/45-usb-stlink-v2.rules:1 Unknown group 'plugdev', ignoring.
Nov 02 07:59:09 creapermann-g33500 kernel: wmi_bus wmi_bus-PNP0C14:03: WQBC data block query control method not found
Nov 02 07:59:09 creapermann-g33500 kernel: mtd: partition "BIOS" extends beyond the end of device "0000:00:1f.5" -- size truncated to 0x800000
Nov 02 07:59:09 creapermann-g33500 kernel: r8169 0000:3b:00.0: can't disable ASPM; OS doesn't have ASPM control
Nov 02 07:59:09 creapermann-g33500 kernel: iwlwifi 0000:00:14.3: api flags index 2 larger than supported by driver
Nov 02 07:59:10 creapermann-g33500 kernel: nvidia: module license 'NVIDIA' taints kernel.
Nov 02 07:59:10 creapermann-g33500 kernel: Disabling lock debugging due to kernel taint
Nov 02 07:59:10 creapermann-g33500 kernel: thermal thermal_zone6: failed to read out thermal zone (-61)
Nov 02 07:59:10 creapermann-g33500 kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 535.113.01 Tue Sep 12 19:41:24 UTC 2023
Nov 02 07:59:10 creapermann-g33500 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
Nov 02 07:59:11 creapermann-g33500 kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Nov 02 07:59:11 creapermann-g33500 systemd-sysctl[820]: Couldn't write '1' to 'net/ipv6/conf/your-network-interface-name-here/disable_ipv6', ignoring: No such file or directory
Nov 02 07:59:11 creapermann-g33500 kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: sink widget AIF1TX overwritten
Nov 02 07:59:11 creapermann-g33500 kernel: snd_hda_codec_realtek ehdaudio0D0: ASoC: source widget AIF1RX overwritten
Nov 02 07:59:11 creapermann-g33500 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi3 overwritten
Nov 02 07:59:11 creapermann-g33500 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi2 overwritten
Nov 02 07:59:11 creapermann-g33500 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget hifi1 overwritten
Nov 02 07:59:11 creapermann-g33500 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Codec Output Pin1 overwritten
Nov 02 07:59:11 creapermann-g33500 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Codec Input Pin1 overwritten
Nov 02 07:59:11 creapermann-g33500 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Analog Codec Playback overwritten
Nov 02 07:59:11 creapermann-g33500 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Digital Codec Playback overwritten
Nov 02 07:59:11 creapermann-g33500 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: sink widget Alt Analog Codec Playback overwritten
Nov 02 07:59:11 creapermann-g33500 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Analog Codec Capture overwritten
Nov 02 07:59:11 creapermann-g33500 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Digital Codec Capture overwritten
Nov 02 07:59:11 creapermann-g33500 kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: source widget Alt Analog Codec Capture overwritten
Nov 02 07:59:11 creapermann-g33500 systemd[1]: nordvpnd.socket: TCP_NODELAY failed: Operation not supported
Nov 02 07:59:11 creapermann-g33500 (uetoothd)[849]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Nov 02 07:59:11 creapermann-g33500 bluetoothd[849]: src/plugin.c:plugin_init() System does not support csip plugin
Nov 02 07:59:11 creapermann-g33500 bluetoothd[849]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Nov 02 07:59:11 creapermann-g33500 bluetoothd[849]: src/plugin.c:plugin_init() System does not support micp plugin
Nov 02 07:59:11 creapermann-g33500 bluetoothd[849]: src/plugin.c:plugin_init() System does not support vcp plugin
Nov 02 07:59:11 creapermann-g33500 bluetoothd[849]: src/plugin.c:plugin_init() System does not support mcp plugin
Nov 02 07:59:11 creapermann-g33500 bluetoothd[849]: src/plugin.c:plugin_init() System does not support bass plugin
Nov 02 07:59:11 creapermann-g33500 bluetoothd[849]: src/plugin.c:plugin_init() System does not support bap plugin
Nov 02 07:59:11 creapermann-g33500 systemd[1]: snapd.service: Got notification message from PID 916, but reception only permitted for main PID 857
Nov 02 07:59:11 creapermann-g33500 systemd[1]: snapd.service: Got notification message from PID 919, but reception only permitted for main PID 857
Nov 02 07:59:11 creapermann-g33500 systemd[1]: snapd.service: Got notification message from PID 937, but reception only permitted for main PID 857
Nov 02 07:59:11 creapermann-g33500 systemd[1]: snapd.service: Got notification message from PID 939, but reception only permitted for main PID 857
Nov 02 07:59:11 creapermann-g33500 systemd[1]: Cannot find unit for notify message of PID 975, ignoring.
Nov 02 07:59:11 creapermann-g33500 eruption[855]: creapermann-g33500 eruption[855]: Not binding the device driver because it would require a lesser code maturity level
Nov 02 07:59:11 creapermann-g33500 eruption[855]: creapermann-g33500 eruption[855]: To enable this device driver, please change the 'driver_maturity_level' setting in eruption.conf respectively
Nov 02 07:59:11 creapermann-g33500 systemd[1]: snapd.service: Got notification message from PID 990, but reception only permitted for main PID 857
Nov 02 07:59:11 creapermann-g33500 systemd[1]: snapd.service: Got notification message from PID 991, but reception only permitted for main PID 857
Nov 02 07:59:11 creapermann-g33500 systemd[1]: snapd.service: Got notification message from PID 992, but reception only permitted for main PID 857
Nov 02 07:59:11 creapermann-g33500 systemd[1]: snapd.service: Got notification message from PID 993, but reception only permitted for main PID 857
Nov 02 07:59:11 creapermann-g33500 systemd[1]: snapd.service: Got notification message from PID 994, but reception only permitted for main PID 857
Nov 02 07:59:11 creapermann-g33500 systemd[1]: snapd.service: Got notification message from PID 995, but reception only permitted for main PID 857
Nov 02 07:59:12 creapermann-g33500 eruption[855]: creapermann-g33500 eruption[855]: Not binding the device driver because it would require a lesser code maturity level
Nov 02 07:59:12 creapermann-g33500 eruption[855]: creapermann-g33500 eruption[855]: To enable this device driver, please change the 'driver_maturity_level' setting in eruption.conf respectively
Nov 02 07:59:14 creapermann-g33500 kernel: ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20220331/nsarguments-61)
Nov 02 07:59:17 creapermann-g33500 systemd[1174]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Nov 02 07:59:17 creapermann-g33500 systemd[1174]: Failed to start Update XDG user dir configuration.
Nov 02 07:59:17 creapermann-g33500 sddm-greeter[1344]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffe18b70720), parent's thread is QThread(0x55c9ea576dc0), current thread is QThread(0x55c9ea6dcf40)
Nov 02 07:59:17 creapermann-g33500 sddm-greeter[1344]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Nov 02 07:59:18 creapermann-g33500 upowerd[1386]: Assuming system scope even though scope is Unknown
Nov 02 07:59:18 creapermann-g33500 sddm-greeter[1344]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Nov 02 07:59:18 creapermann-g33500 sddm-greeter[1344]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
Nov 02 07:59:18 creapermann-g33500 sddm-greeter[1344]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Nov 02 07:59:18 creapermann-g33500 sddm-greeter[1344]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Nov 02 07:59:19 creapermann-g33500 sddm-greeter[1344]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.30'
Nov 02 07:59:19 creapermann-g33500 sddm-greeter[1344]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.31'
Nov 02 07:59:19 creapermann-g33500 sddm-greeter[1344]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Nov 02 07:59:22 creapermann-g33500 sddm[1029]: Authentication information: SDDM::Auth::INFO_UNKNOWN "Web console: https://creapermann-g33500:9090/ or https://192.168.178.51:9090/\n"
Nov 02 07:59:22 creapermann-g33500 NetworkManager[875]: <warn> [1698908362.9329] device (wlp0s20f3): no secrets: No agents were available for this request.
Nov 02 07:59:22 creapermann-g33500 NetworkManager[875]: <warn> [1698908362.9332] device (wlp0s20f3): Activation: failed for connection 'FRITZ!Box 7590 ZG'
Nov 02 07:59:24 creapermann-g33500 eruption-proces[1441]: creapermann-g33500 eruption-process-monitor[1441]: Could not connect to a Wayland compositor, giving up: Could not find wayland compositor
Nov 02 07:59:24 creapermann-g33500 systemd[1401]: eruption-process-monitor.service: Failed with result 'exit-code'.
Nov 02 07:59:24 creapermann-g33500 eruption-audio-[1440]: creapermann-g33500 eruption-audio-proxy[1440]: Connection error: Could not query PulseAudio/PipeWire
Nov 02 07:59:24 creapermann-g33500 eruption[855]: creapermann-g33500 eruption[855]: Socket error: Audio proxy disconnected
Nov 02 07:59:24 creapermann-g33500 kwin_wayland[1452]: No backend specified, automatically choosing drm
Nov 02 07:59:25 creapermann-g33500 kwin_wayland[1452]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Nov 02 07:59:25 creapermann-g33500 kwin_wayland[1452]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Nov 02 07:59:25 creapermann-g33500 kernel: usb 1-2.4: Not enough bandwidth for new device state.
Nov 02 07:59:25 creapermann-g33500 kernel: usb 1-2.4: 1:1: usb_set_interface failed (-28)
Nov 02 07:59:25 creapermann-g33500 kernel: usb 1-2.4: 2:1: cannot get freq at ep 0x1
Nov 02 07:59:25 creapermann-g33500 wireplumber[1450]: <WpPortalPermissionStorePlugin:0x55ab245a9530> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
Nov 02 07:59:26 creapermann-g33500 ksplashqml[1455]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Nov 02 07:59:26 creapermann-g33500 ksplashqml[1455]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
Nov 02 07:59:26 creapermann-g33500 ksmserver[1601]: Qt: Session management error: networkIdsList argument is NULL
Nov 02 07:59:27 creapermann-g33500 plasmashell[1662]: Checking screens: available: (QScreen(0x55b9b92fa160, name="eDP-1")) redundant: QHash() fake: QSet() all: (QScreen(0x55b9b92fa160, name="eDP-1"))
Nov 02 07:59:27 creapermann-g33500 plasmashell[1662]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Nov 02 07:59:27 creapermann-g33500 plasmashell[1662]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Nov 02 07:59:27 creapermann-g33500 polkit-kde-authentication-agent-1[1716]: KXMessages used on non-X11 platform! This is an application bug.
Nov 02 07:59:27 creapermann-g33500 org_kde_powerdevil[1719]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Nov 02 07:59:27 creapermann-g33500 kded5[1603]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.30: cannot open shared object file: No such file or directory)"
Nov 02 07:59:27 creapermann-g33500 plasmashell[1662]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:265:13: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Nov 02 07:59:27 creapermann-g33500 plasmashell[1662]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
Nov 02 07:59:27 creapermann-g33500 kded5[1603]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Nov 02 07:59:27 creapermann-g33500 kded5[1603]: kscreen.kded: PowerDevil SuspendSession action not available!
Nov 02 07:59:27 creapermann-g33500 kded5[1603]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Nov 02 07:59:27 creapermann-g33500 kioslave5[1847]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
Nov 02 07:59:27 creapermann-g33500 org_kde_powerdevil[1719]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Nov 02 07:59:27 creapermann-g33500 DesktopVideoUpdater[1898]: qt.qpa.plugin: Could not find the Qt platform plugin "wayland" in ""
Nov 02 07:59:27 creapermann-g33500 plasmashell[1662]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Nov 02 07:59:28 creapermann-g33500 plasmashell[1662]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Nov 02 07:59:28 creapermann-g33500 plasmashell[1662]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Nov 02 07:59:28 creapermann-g33500 plasmashell[1662]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:95: TypeError: Cannot read property 'airplaneModeAvailable' of null
Nov 02 07:59:28 creapermann-g33500 plasmashell[1662]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
Nov 02 07:59:28 creapermann-g33500 plasmashell[1662]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Nov 02 07:59:28 creapermann-g33500 plasmashell[1662]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/ApplicationsPage.qml:178: TypeError: Cannot call method 'forceActiveFocus' of null
Nov 02 07:59:29 creapermann-g33500 plasmashell[1662]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Nov 02 07:59:30 creapermann-g33500 plasmashell[1662]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Nov 02 07:59:31 creapermann-g33500 kernel: usb 1-2.4: 2:1: cannot get freq at ep 0x1
Nov 02 07:59:31 creapermann-g33500 ksmserver-logout-greeter[2192]: qt.qpa.wayland: Wayland does not support QWindow::requestActivate()
Nov 02 07:59:31 creapermann-g33500 plasmashell[1662]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Nov 02 07:59:31 creapermann-g33500 plasmashell[1662]: kf5idletime_wayland: This plugin does not support polling idle time
Nov 02 07:59:32 creapermann-g33500 plasmashell[1662]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55b9bc6c4020) QQmlContext(0x55b9ba63ae70) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Nov 02 07:59:32 creapermann-g33500 plasmashell[1662]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Nov 02 07:59:32 creapermann-g33500 bluetoothd[849]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
Nov 02 07:59:33 creapermann-g33500 kaccess[1951]: The X11 connection broke (error 1). Did the X11 server die?
Nov 02 07:59:33 creapermann-g33500 systemd[1401]: app-kaccess@autostart.service: Failed with result 'exit-code'.
Nov 02 07:59:33 creapermann-g33500 kwin_wayland[1452]: QtDBus: cannot relay signals from parent QObject(0x55722b19c610 "") unless they are emitted in the object's thread QThread(0x55722af41078 "libinput-connection"). Current thread is QThread(0x55722af00e50 "").
Nov 02 07:59:33 creapermann-g33500 kwalletd5[1417]: The Wayland connection broke. Did the Wayland compositor die?
Nov 02 07:59:33 creapermann-g33500 kded5[1603]: The Wayland connection broke. Did the Wayland compositor die?
Nov 02 07:59:33 creapermann-g33500 plasmashell[1662]: The Wayland connection broke. Did the Wayland compositor die?
Nov 02 07:59:33 creapermann-g33500 kactivitymanagerd[1711]: The Wayland connection broke. Did the Wayland compositor die?
Nov 02 07:59:33 creapermann-g33500 flameshot[1900]: The Wayland connection broke. Did the Wayland compositor die?
Nov 02 07:59:33 creapermann-g33500 polkit-kde-authentication-agent-1[1716]: The Wayland connection broke. Did the Wayland compositor die?
Nov 02 07:59:33 creapermann-g33500 org_kde_powerdevil[1719]: The Wayland connection broke. Did the Wayland compositor die?
Nov 02 07:59:33 creapermann-g33500 pamac-tray-plasma[1961]: The Wayland connection broke. Did the Wayland compositor die?
Nov 02 07:59:33 creapermann-g33500 kdeconnectd[1921]: The Wayland connection broke. Did the Wayland compositor die?
Nov 02 07:59:33 creapermann-g33500 msm_kde_notifier[1916]: The Wayland connection broke. Did the Wayland compositor die?
Nov 02 07:59:33 creapermann-g33500 DiscoverNotifier[1954]: The Wayland connection broke. Did the Wayland compositor die?
Nov 02 07:59:33 creapermann-g33500 xdg-desktop-portal-kde[1720]: The Wayland connection broke. Did the Wayland compositor die?
Nov 02 07:59:33 creapermann-g33500 systemd[1401]: plasma-xdg-desktop-portal-kde.service: Failed with result 'exit-code'.
Nov 02 07:59:33 creapermann-g33500 systemd[1401]: plasma-powerdevil.service: Failed with result 'exit-code'.
Nov 02 07:59:33 creapermann-g33500 systemd[1401]: plasma-polkit-agent.service: Failed with result 'exit-code'.
Nov 02 07:59:33 creapermann-g33500 systemd[1401]: app-org.kde.kdeconnect.daemon@autostart.service: Failed with result 'exit-code'.
Nov 02 07:59:33 creapermann-g33500 systemd[1401]: app-msm_kde_notifier@autostart.service: Failed with result 'exit-code'.
Nov 02 07:59:33 creapermann-g33500 systemd[1401]: plasma-kactivitymanagerd.service: Failed with result 'exit-code'.
Nov 02 07:59:33 creapermann-g33500 systemd[1401]: app-Flameshot@autostart.service: Failed with result 'exit-code'.
Nov 02 07:59:33 creapermann-g33500 systemd[1401]: plasma-kded.service: Failed with result 'exit-code'.
Nov 02 07:59:33 creapermann-g33500 systemd[1401]: app-org.moson.matray@autostart.service: Failed with result 'exit-code'.
Nov 02 07:59:33 creapermann-g33500 systemd[1401]: app-org.kde.discover.notifier@autostart.service: Failed with result 'exit-code'.
Nov 02 07:59:33 creapermann-g33500 systemd[1401]: app-pamac\x2dtray\x2dplasma@autostart.service: Failed with result 'exit-code'.
Nov 02 07:59:33 creapermann-g33500 systemd[1401]: plasma-plasmashell.service: Failed with result 'exit-code'.
Nov 02 07:59:34 creapermann-g33500 polkit-kde-authentication-agent-1[2306]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:34 creapermann-g33500 systemd[1401]: plasma-polkit-agent.service: Main process exited, code=killed, status=6/ABRT
Nov 02 07:59:34 creapermann-g33500 systemd[1401]: plasma-polkit-agent.service: Failed with result 'signal'.
Nov 02 07:59:34 creapermann-g33500 systemd[1401]: Failed to start KDE PolicyKit Authentication Agent.
Nov 02 07:59:34 creapermann-g33500 systemd[1401]: plasma-powerdevil.service: Main process exited, code=dumped, status=6/ABRT
Nov 02 07:59:34 creapermann-g33500 systemd[1401]: plasma-powerdevil.service: Failed with result 'core-dump'.
Nov 02 07:59:34 creapermann-g33500 systemd[1401]: Failed to start Powerdevil.
Nov 02 07:59:34 creapermann-g33500 systemd[1401]: plasma-plasmashell.service: Main process exited, code=dumped, status=6/ABRT
Nov 02 07:59:34 creapermann-g33500 systemd[1401]: plasma-plasmashell.service: Failed with result 'core-dump'.
Nov 02 07:59:34 creapermann-g33500 systemd[1401]: Failed to start KDE Plasma Workspace.
Nov 02 07:59:34 creapermann-g33500 polkit-kde-authentication-agent-1[2324]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:34 creapermann-g33500 polkit-kde-authentication-agent-1[2348]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:34 creapermann-g33500 polkit-kde-authentication-agent-1[2369]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:34 creapermann-g33500 systemd[1401]: plasma-plasmashell.service: Start request repeated too quickly.
Nov 02 07:59:34 creapermann-g33500 systemd[1401]: plasma-polkit-agent.service: Start request repeated too quickly.
Nov 02 07:59:35 creapermann-g33500 systemd[1401]: plasma-powerdevil.service: Start request repeated too quickly.
Nov 02 07:59:35 creapermann-g33500 systemd[1401]: plasma-powerdevil.service: Failed with result 'core-dump'.
Nov 02 07:59:35 creapermann-g33500 systemd[1401]: Failed to start Powerdevil.
Nov 02 07:59:36 creapermann-g33500 baloo_file_extractor[2439]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:36 creapermann-g33500 baloo_file_extractor[2450]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:36 creapermann-g33500 baloo_file_extractor[2465]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:36 creapermann-g33500 baloo_file_extractor[2479]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:36 creapermann-g33500 baloo_file_extractor[2493]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:37 creapermann-g33500 baloo_file_extractor[2511]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:37 creapermann-g33500 baloo_file_extractor[2525]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:37 creapermann-g33500 baloo_file_extractor[2539]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:37 creapermann-g33500 baloo_file_extractor[2557]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:37 creapermann-g33500 xdg-desktop-portal-kde[2570]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:37 creapermann-g33500 baloo_file_extractor[2585]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:37 creapermann-g33500 systemd[2555]: xdg-user-dirs-update.service: Failed with result 'exit-code'.
Nov 02 07:59:37 creapermann-g33500 systemd[2555]: Failed to start Update XDG user dir configuration.
Nov 02 07:59:37 creapermann-g33500 systemd[1401]: plasma-xdg-desktop-portal-kde.service: Main process exited, code=dumped, status=6/ABRT
Nov 02 07:59:37 creapermann-g33500 systemd[1401]: plasma-xdg-desktop-portal-kde.service: Failed with result 'core-dump'.
Nov 02 07:59:37 creapermann-g33500 systemd[1401]: Failed to start Xdg Desktop Portal For KDE.
Nov 02 07:59:37 creapermann-g33500 baloo_file_extractor[2613]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:37 creapermann-g33500 sddm-greeter[2602]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffc1a3814f0), parent's thread is QThread(0x563c921f7dc0), current thread is QThread(0x563c9235d8f0)
Nov 02 07:59:37 creapermann-g33500 sddm-greeter[2602]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Nov 02 07:59:37 creapermann-g33500 baloo_file_extractor[2644]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:37 creapermann-g33500 baloo_file_extractor[2668]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:37 creapermann-g33500 sddm-greeter[2602]: file:///usr/share/sddm/themes/breath/components/VirtualKeyboard.qml:11:1: Type InputPanel unavailable
Nov 02 07:59:37 creapermann-g33500 sddm-greeter[2602]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
Nov 02 07:59:37 creapermann-g33500 sddm-greeter[2602]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Nov 02 07:59:38 creapermann-g33500 baloo_file_extractor[2684]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:38 creapermann-g33500 baloo_file_extractor[2698]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:38 creapermann-g33500 sddm-greeter[2602]: file:///usr/share/sddm/themes/breath/Main.qml:465:13: Unable to assign [undefined] to QUrl
Nov 02 07:59:38 creapermann-g33500 baloo_file_extractor[2715]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:38 creapermann-g33500 baloo_file_extractor[2730]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:38 creapermann-g33500 baloo_file_extractor[2744]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:38 creapermann-g33500 baloo_file_extractor[2758]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:38 creapermann-g33500 baloo_file_extractor[2772]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:39 creapermann-g33500 baloo_file_extractor[2786]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:39 creapermann-g33500 baloo_file_extractor[2800]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:39 creapermann-g33500 baloo_file_extractor[2814]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:39 creapermann-g33500 baloo_file_extractor[2831]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:39 creapermann-g33500 baloo_file_extractor[2845]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:39 creapermann-g33500 baloo_file_extractor[2859]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:39 creapermann-g33500 baloo_file_extractor[2874]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:40 creapermann-g33500 baloo_file_extractor[2888]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:40 creapermann-g33500 baloo_file_extractor[2901]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:40 creapermann-g33500 baloo_file_extractor[2913]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:40 creapermann-g33500 baloo_file_extractor[2930]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:40 creapermann-g33500 baloo_file_extractor[2944]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:40 creapermann-g33500 baloo_file_extractor[2958]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:40 creapermann-g33500 baloo_file_extractor[2970]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:41 creapermann-g33500 baloo_file_extractor[2986]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:41 creapermann-g33500 baloo_file_extractor[3000]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:41 creapermann-g33500 baloo_file_extractor[3014]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:41 creapermann-g33500 baloo_file_extractor[3028]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:41 creapermann-g33500 baloo_file_extractor[3046]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:41 creapermann-g33500 baloo_file_extractor[3060]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:41 creapermann-g33500 baloo_file_extractor[3074]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:42 creapermann-g33500 baloo_file_extractor[3088]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:42 creapermann-g33500 baloo_file_extractor[3102]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:42 creapermann-g33500 baloo_file_extractor[3116]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:42 creapermann-g33500 baloo_file_extractor[3130]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:42 creapermann-g33500 baloo_file_extractor[3144]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:42 creapermann-g33500 baloo_file_extractor[3158]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:42 creapermann-g33500 baloo_file_extractor[3171]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:43 creapermann-g33500 baloo_file_extractor[3186]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:43 creapermann-g33500 baloo_file_extractor[3200]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:43 creapermann-g33500 baloo_file_extractor[3214]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:43 creapermann-g33500 baloo_file_extractor[3228]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:43 creapermann-g33500 baloo_file_extractor[3242]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:43 creapermann-g33500 baloo_file_extractor[3255]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:43 creapermann-g33500 baloo_file_extractor[3270]: qt.qpa.xcb: could not connect to display
Nov 02 07:59:43 creapermann-g33500 xdg-desktop-por[1472]: Failed to get application states: The connection is closed
Nov 02 07:59:44 creapermann-g33500 systemd[1401]: xdg-document-portal.service: Failed with result 'exit-code'.
Nov 02 07:59:44 creapermann-g33500 systemd[1401]: xdg-permission-store.service: Failed with result 'exit-code'.
Nov 02 07:59:44 creapermann-g33500 systemd[1401]: obex.service: Failed with result 'exit-code'.
Nov 02 07:59:44 creapermann-g33500 eruption-audio-[1548]: creapermann-g33500 eruption-audio-proxy[1548]: Connection error: Could not query PulseAudio/PipeWire
Nov 02 07:59:44 creapermann-g33500 eruption[855]: creapermann-g33500 eruption[855]: Socket error: Audio proxy disconnected
Nov 02 07:59:44 creapermann-g33500 sddm[1029]: Authentication information: SDDM::Auth::INFO_UNKNOWN "Web console: https://creapermann-g33500:9090/ or https://192.168.178.51:9090/\n"
Nov 02 07:59:55 creapermann-g33500 NetworkManager[875]: <warn> [1698908395.1200] device (wlp0s20f3): no secrets: No agents were available for this request.
Nov 02 07:59:55 creapermann-g33500 NetworkManager[875]: <warn> [1698908395.1206] device (wlp0s20f3): Activation: failed for connection 'FRITZ!Box 7590 ZG'
Nov 02 08:01:54 creapermann-g33500 ksplashqml[3376]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Nov 02 08:01:54 creapermann-g33500 ksplashqml[3376]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
Nov 02 08:01:54 creapermann-g33500 eruption-proces[3406]: creapermann-g33500 eruption-process-monitor[3406]: Could not connect to a Wayland compositor, giving up: Could not find wayland compositor
Nov 02 08:01:54 creapermann-g33500 eruption-audio-[3405]: creapermann-g33500 eruption-audio-proxy[3405]: Connection error: Could not query PulseAudio/PipeWire
Nov 02 08:01:54 creapermann-g33500 eruption[855]: creapermann-g33500 eruption[855]: Socket error: Audio proxy disconnected
Nov 02 08:01:54 creapermann-g33500 ksmserver[3476]: Qt: Session management error: networkIdsList argument is NULL
Nov 02 08:01:56 creapermann-g33500 kwin_x11[3479]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Nov 02 08:01:56 creapermann-g33500 kwin_x11[3479]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Nov 02 08:01:56 creapermann-g33500 ksmserver[3476]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.21'
Nov 02 08:01:56 creapermann-g33500 kernel: usb 1-2.4: Not enough bandwidth for new device state.
Nov 02 08:01:56 creapermann-g33500 kernel: usb 1-2.4: 1:1: usb_set_interface failed (-28)
Nov 02 08:01:56 creapermann-g33500 plasmashell[3566]: Checking screens: available: (QScreen(0x55aeb739fb40, name="eDP-1")) redundant: QHash() fake: QSet() all: (QScreen(0x55aeb739fb40, name="eDP-1"))
Nov 02 08:01:56 creapermann-g33500 plasmashell[3566]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Nov 02 08:01:56 creapermann-g33500 plasmashell[3566]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Nov 02 08:01:56 creapermann-g33500 eruption-audio-[3561]: creapermann-g33500 eruption-audio-proxy[3561]: Connection error: Could not query PulseAudio/PipeWire
Nov 02 08:01:56 creapermann-g33500 eruption[855]: creapermann-g33500 eruption[855]: Socket error: Audio proxy disconnected
Nov 02 08:01:56 creapermann-g33500 org_kde_powerdevil[3626]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Nov 02 08:01:56 creapermann-g33500 kded5[3478]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.30: cannot open shared object file: No such file or directory)"
Nov 02 08:01:56 creapermann-g33500 wireplumber[3412]: <WpPortalPermissionStorePlugin:0x55fd4809e540> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
Nov 02 08:01:56 creapermann-g33500 kded5[3478]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Nov 02 08:01:56 creapermann-g33500 kded5[3478]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Nov 02 08:01:56 creapermann-g33500 plasmashell[3566]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:265:13: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Nov 02 08:01:56 creapermann-g33500 kded5[3478]: kscreen.kded: PowerDevil SuspendSession action not available!
Nov 02 08:01:57 creapermann-g33500 kioslave5[3757]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
Nov 02 08:01:57 creapermann-g33500 ksplashqml[3376]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Nov 02 08:01:57 creapermann-g33500 ksplashqml[3376]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath-dark.desktop/contents/splash/Splash.qml:82:29: Unable to assign int to QEasingCurve
Nov 02 08:01:57 creapermann-g33500 plasmashell[3566]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:265:13: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Nov 02 08:01:57 creapermann-g33500 plasmashell[3566]: Checking screens: available: (QScreen(0x7feba40043e0, name="HDMI-1-0"), QScreen(0x55aeb739fb40, name="eDP-1")) redundant: QHash() fake: QSet() all: (QScreen(0x7feba40043e0, name="HDMI-1-0"), QScreen(0x55aeb739fb40, name="eDP-1"))
Nov 02 08:01:57 creapermann-g33500 org_kde_powerdevil[3626]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Nov 02 08:01:57 creapermann-g33500 org_kde_powerdevil[3626]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Nov 02 08:01:57 creapermann-g33500 plasmashell[3566]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Nov 02 08:01:57 creapermann-g33500 plasmashell[3566]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Nov 02 08:01:57 creapermann-g33500 plasmashell[3566]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Nov 02 08:01:58 creapermann-g33500 plasmashell[3566]: file:///usr/share/plasma/plasmoids/org.kde.plasma.networkmanagement/contents/ui/main.qml:95: TypeError: Cannot read property 'airplaneModeAvailable' of null
Nov 02 08:01:58 creapermann-g33500 plasmashell[3566]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Nov 02 08:01:59 creapermann-g33500 plasmashell[3566]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Nov 02 08:01:59 creapermann-g33500 pipewire[3411]: spa.audioadapter: 0x55aa994b8d38: scheduling stopped node
Nov 02 08:02:00 creapermann-g33500 plasmashell[3566]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Nov 02 08:02:01 creapermann-g33500 plasmashell[3566]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Nov 02 08:02:02 creapermann-g33500 plasmashell[3566]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x55aeba686120) QQmlContext(0x55aeb8763900) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Nov 02 08:02:02 creapermann-g33500 plasmashell[3566]: file:///usr/share/plasma/plasmoids/org.kde.plasma.kickoff/contents/ui/ApplicationsPage.qml:178: TypeError: Cannot call method 'forceActiveFocus' of null
Nov 02 08:02:03 creapermann-g33500 bluetoothd[849]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
Nov 02 08:02:04 creapermann-g33500 plasmashell[3566]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Nov 02 08:02:04 creapermann-g33500 plasmashell[3566]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Nov 02 08:02:21 creapermann-g33500 plasmashell[3566]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:286: Unable to assign [undefined] to QString
Nov 02 08:04:29 creapermann-g33500 kstart5[4899]: Omitting both --window and --windowclass arguments is not recommended
Nov 02 08:06:46 creapermann-g33500 kwin_x11[3479]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Nov 02 08:09:18 creapermann-g33500 kstart5[5417]: Omitting both --window and --windowclass arguments is not recommended
Nov 02 08:09:19 creapermann-g33500 kstart5[5451]: Omitting both --window and --windowclass arguments is not recommended
